View Full Version : Tech / Misc
- The Truth About Unorthodox Racing...
- Alternator Dying?
- Does the IACV need coolant to work properly?
- please help! even acura's stumped...
- map sensor question?
- Will a D16Y or Z cam work on a Jdm D15B Vtec
- Idle prob in morn???
- plug order on distributor for y8?
- codes codes codes codes codes codes codes codes codes codes!!!!!11
- Need help with coolant line routing on a black top ZC.
- head from what engine?
- 1993 H22 Accord sputters aftet incident...
- torsion rods
- Honda engine specs?? please help, planning project!
- wipers quit working
- info on cartech fmu
- the little back box on the back of the block
- need help!! fuel problem
- what will rais my rpm
- Clutch slave cylinder
- torque specs for cam caps and plates???
- Anyone have experience with Recaro SRD seats?
- Would this work?
- ok, 2 questions about JDM B16 swap in a 4door EG
- just checked for lsd.......wtf?
- is a 11/16 safe to use to remove the flywheel bolts?
- Anyone Know how to install an AEM Tru-Power Pulley kit??
- Does any one know if this is correct?
- To MOld.. Or Not To MOld?.....Front Lip!
- how to ID a transmission?
- ecu help!
- Help Broken Speed Sensor
- blew my motor
- ecu codes
- Updat, Update, Update
- Is it okay to install springs without a spring compressor?
- Radiator leak I can't find it
- torque specs for 2piece rotor?
- B20/VTEC experts enter here
- Fouled out plugs?
- AEM EMS (I searched)
- p30 and p72 question.......
- manifold help
- What is so bad about OBD2?
- **** IS clutch out ***??
- Pulsates and Pulls to the left when I am accelerating. It is especially bad in first and second gear
- Bypassing knock sensor on a P72
- remote starter installed, now need neutral switch.
- What to use to get old headgasket off of head/block??
- Changing out clutch, Who makes a good Clutch?
- B16A2 crank angle sensor??
- Building LS/VTEC question is, is my valve-to-piston clearance safe??? HELP pls!
- Dropped Redline AND Code 31?WTF?I'm confused...
- Engine will not start!!!
- type r intake arm and ls intake arm
- AEM EMS and obd2.2: possible to program the ignition key chip lockout feature?
- resource for wheel specs?
- can I hook an msd 2 step up to a 6a?
- my speedometer is moving with my tach when the car is not in gear??
- Could i put a type r head on a b20 long block?!?!?!?!?!
- mugen motor mount question...
- Catless Integras - resistor mod to avoid CEL? (what ohm?)
- civic brake problem.. plz help..
- Tein Installation ?
- Broken crank Pulley???
- Revving High then low? IAC problem? or fast idle thermo valve?
- stupid ABS
- ITR brakes vs. GSR brakes...?
- Big problem not matching head to piston bore? 85mm with stock combustion chamber...
- McGard lug lock owners, any feedback on them?
- Anyone use Desktop dyno200 engine simulation
- sealant around butterfly on throttle body?
- j30 accord ..auto to manuel trans swap
- b18 vs b16 fuel pressure
- i have questions about a motor swap?!?!?
- d15 dist. and alt on a d16?
- Stupid post......
- Teggy is burning oil...
- Universal o2 sensor????
- Anyone have the S4C LSD tranny in their Car? How LSD works..?
- HELP !!!!!!!!!!!! O2 Sensor Wiring?
- Rear brakes from LS or EX Sedan? Same? Price?
- stainless steel air filters. any good?
- oil breather?
- vtec acutuators, interchangeable?
- Auto To Manual, 96 civic and 97 del sol.
- Lost Motion Assembly 2000 sohc vtec head
- Stroke for a B18C5?
- redline lowering problem
- How much does this help?
- Weight distribution
- Possible transmission problem??? Please help!!
- Skunk2 wrench
- Subframe reinforcement
- imobilizer
- Can colder air cause your motor to run lean?
- How to tell if ecu is in open loop mode?
- ls/vtec cost?
- may very well be a stupid question!
- Prelude piston swapping question....
- DC SPORT 4-2-1 VS DC SPORT 4-1 JDM VERSION
- HELP!!!!!!!my car wont start
- wrist pins , little part.... big problom!
- electronic shift computer for auto transmissions
- HONDATA PROBLEMS
- auto tranny wont shift up when floored....
- Crower B18A Head Questions
- By-Pass valve - WORTH IT?
- Difference between 13020-p30-000 and 1320-p30g00 pistons
- get my throttle body back after 5 weeks, put it on start the car and.......
- Oem sensor connectors
- callin all Illinios hondata and or ECU reprogammers. where you at???
- Greddy turbo kit dyno #'s on ep3
- Anyone know if a D series distributor shaft is the same as a B series?
- how do you feel about the tokico suspension package?
- Ground Control Coilover problem
- ctr vs itr flywheel
- cutting bumpstops
- What is a good 4-2-1 header for the buck?
- Has my Carsound Cat gone bad already?
- injector voltage and duty cycle cutting out at 1700-200 rpm?
- VAFC, how can you check w/o hooking it up?
- h22 in an integra
- help installing a clutch into a civic?
- Euro R h22 distributor...
- question about timing???
- Hooking up AFR gauge?
- Quick Q: Brake lines
- ls is knocking help please
- Turbo XS dual-stage MBC
- Help me figure out whats done to my motor?
- I have a 88 Civic Wagon 4WD... Will i be able to swap a B18B1 or B18A1 in without any modification??
- obd-1 b-16 from my 92 civic into my 96 civic
- Wierd thrust washer problem....
- what motor to put in the ek
- Parts for a B16A?
- AN thread tap set
- My friends argument
- Ground Control Torque...
- Clicking noise.....Need lots of help.
- motor sputtering when i floor it!
- Got a problem... but not sure of the source.
- failed CO emissions...need advice
- converting single wire o2 (92 eg) to four wire(92-95 dohc vtec)
- ABS code... CPU and wheel sensor??
- quick question regarding rear camber kit install
- help w/ identifying various intake manifolds
- Shuddering
- Have some questions about this thread (clicking noise search result)
- Problem with JDM B18c1, intake backfires... and cylinders 2,3 are not firing... help??
- What will it make LS VTEC related...
- need help
- Jun spring?
- Octane and Gas Mileage
- Anyone have a die grinder recommendation??
- under drive pullys
- who makes the best pistons
- ITR VALVE SPRING QUESTION...PORTFLOW ...PLEASE HELP!!!...
- Crower Rods Specs...
- what parts from a 90 integra ls will fit on my 90 crx si?
- Larger rims a hurt your performance
- obd2 to obd1 with a gsr in a 99 hb.....
- Who knows the gearing???
- has any ever did tom's (from the eg forum) easiet brake master upgrade for a eg
- 92 cx ecu???
- How to height-adjust Tein NAs?
- max capacity of stock fuel pump
- nitrous ?
- Coilovers Squeaking Help pls
- Help me diagnose: looking inside a B18A that uses more oil than gas.
- 2.0L b18cR, do I need to bore the cylinder head to match sleeve bore?
- no compression...can the motor not be blown?
- Length of these two headers???
- converting from obd0 to obd1 p28ecu ?
- Engine stalling!! HELP ME please!
- Upper pillow mounts
- how can i make sure i'm getting real R valvesprings?
- integra knock sensor-92-93? yay or nay
- ? about check engine light
- Bent valves: going SKUNK2 valvetrain
- Manual Swap, Now how do i wire up my reverse lights?
- Gasket between Cat and Catback system?
- Lug nut Studs stripped... 94 Integra... hard time taking them out.. help?
- cam install??
- Failed emissions - plz help
- help with broke ass tranny
- What Apex'i needs to do to solve hack problems.
- any hondata tuners around New england area ????
- stock oil pump question
- Stuck Alternator Bolt
- Steering wheel swap...
- can someone tell me the difference in gear ratios on these tranny's
- GReddy A/F ratio gauge users
- Went to the track last night, but.......
- the biggest bore possible for d serries...?
- anyone have the link to the 11 second d-series thread?
- why spend money on lighter lugnuts?
- SS valves ZC
- Stronger Axles for my B16a CRX
- Doable job or delusion of granduer?
- secoundary o2 sensor?
- need wiring help
- five lug set up for a 93 honda civic vx
- how to install new key on distrb?
- Dual Valve Springs on Street engine
- piston and rod sizing?
- Oil Cooler Canadian winter weather?
- Oil on plugs....dripping from threads down
- ODBI and VTEC E
- jdm h22a oil pump vs. usdm h22 oil pump
- code 71 and 73 misfire
- b&m regulator and guage install
- help needed with parts for d16z6
- What Should I DO
- Quaife Noise
- Tokico Reds strong enough?
- let go of clutch , and cars shuts off?
- cams seals????????
- Does this look like detonation??
- Help me figure out what is wrong.
- who makes the best locking wheel lug nuts
- OBD 2 ecu on OBD 1 car?
- bodykit installation on a 98 integra
- Straight forward ignition timing question
- AEM fuel rail... fuel pressure question
- Can I use my B18a ARP headstuds on my B20 with B18a head?
- Wideband roundup
- 99 Civic EX harness interchangable with 99 SI harness?
- B16 Won't turn over
- ***B18C1 clutch/flywheel bolt torque specs needed***
- Quality of Borbet wheels?
- sleeper exhaust
- spec. torque on header?
- Wiring fields vtec controller
- High Idling Problem. How To Fix? B16A
- Moms Ls weird problem
- d16y8 Rod Cap specs
- CAMBER WEAR?
- d series turbo manifold converted to a b series? anyone done this or have info?
- Are there any honda technicians on the board??? Need Help ASAP
- Piston Questions
- FITV and IACV
- Need help Y8 head on a Z6 Block
- 1997 Honda Civic Ex
- redone head on old block.
- 99-00 si harness in 97 hatch need help
- coil-over spring rates
- Cleaning Valve Seats
- Plop Plop sound from exhaust between shifts
- ::: Accord rear drum to disc brake conversion - HELP :::
