- where is the lowest priced place to buy a helm's manual for a b18c1?
- car wont hold idle..help
- Engine Code 63
- Deep Thoughts on Bore Sizing
- Can't seem to figure out this CEL problem...
- Engine Analyzer Software
- manifold pressure...
- fuel adjustment on a re written P28 ECU???
- What will a ITR bottom end handle??
- Reboring, honing block ... what is involved and how it is done .. ??
- fule presure
- quick question.......
- Good material to make heat shielding with?
- installing sidemarkers
- VAFC+FPR VS H22A injector.
- ??question on milling head in relation to compression??
- need help on ecu options/decisions
- radiator question....
- passing emissions
- radius arms on integra/DA
- Where to find Beaks kit? (Itr rear sway/ with brackets for a 92hatch )
- Mugen ECU????
- upper exhaust manifold gasket -- reusable?
- Clutch Master Cylinder
- question on aftermarket LCA's
- RS master cylinder in Dx hatch with stock brakes...
- summit racing battery relocation kit - what does it come with?
- a/f meter is fucked up car bog like hell"!/#"%?&
- need help i.d'ing my trans?? it says a1 but.....
- Should I get a new tranny???
- Wiring Vtec... Search function hurts.
- 3"=70mm????
- wats d spec on sponn hi-cams cant seem to get anything on the net
- HONDATA Programs?\
- Code 5 (Manifold Absolute Pressure)
- CEL flashes during driving!?
- USDM B16 vs.JDM B16???
- 99-00 si proportioning valve
- Steering Wheel and Strut Problem
- Would an aftermarket b-pipe made for a 92-95 Civic Si hatch fit a 2000 Si?
- Built LS or LS/VTEC
- Cam setup when to engauge vtec
- Anyone running a cut out pipe on there exhaust?
- Hard Start Problem After Motor Rebuild ??
- Check Engine Light and How to Read the Codes
- Need opinion on Aftermarket Distributor
- Breaking in new cam
- Weird noise from rear suspension
- Individual throttle bodies
- really squeaky suspsension....help!
- Tranny or clutch???
- please post suspension diagram
- Oil And Lube
- AEM FPR Instructions??
- Failing Va Emissions for too much hydrocarbons (unburnt gases)..are these needed?
- what is better: tokico blues or tokico premiums
- "Safe Mode"
- does the profile # of a tire matter, or just the amount of sidewall?
- problems with exhaust obstructing swaybar?
- Average Clutch Housing Price ?? (gsr)
- GRRRRRRRRRIT NOISE When putting in 3rd gear?
- Apexi VAFC
- New "clutchless" SMG tranny (as seen on new BMW M's)
- will running open header help...or hurt?
- 00 Si ECU pinout ? ? ?
- Junk yard engine (SOHC 94 vtec) making loud ticking noise...
- who discovered the LS/VTEC swap?
- bore strocked block
- Custom piping cat back exhaust
- z6 vs y8
- performance exhaust
- Gas pedal sticking on 2000 Civic Si. Need help plz.
- lude keeps staling
- throttle body is bigger better
- timing belt marks
- Erratic idle problem
- Chaging Valve Springs
- Cams for B16??
- MSD window
- over heated uhh?
- Cam Install.....Noise
- Brembo OE rotors...Rusting!
- Engine Question, please help
- Inline fuel pump concerns
- civic JDM ecu from automatic 2 manuel !!?!? how 2 ???
- i fu-ed up somthing please help
- Workshop manual
- ____Question______
- throttle body
- CRX refuses to go into reverse on occasion..
- Valve spring removal tools
- Bent wheels, can they be fixed?
- code 17 vss
- Ground Control coilovers?
- camberkits which one ?????
- help!!! CEL code 14
- Skunk2 cam gears?
- hondata question
- D16Y8
- valve clearance spec for a crv
- Problems installing Ground Controls! Pics inside!!
- How to take off headlights for G2 teg
- Turn Signals
- tire question..........
- firing order
- Scratched Pistons?
- Toyota Prius vs. 2003 Civic hybrid
- how do you guys remove a stuck compression tester?
- how much hp and torque does a 1999 honda civic SiR have???
- Saab Clutch-less
- HELP!!
- car wont start!
- 94 vx ecu to 95 ex ecu
- obd2 convert to obd1 ??
- lowering compression with new pistons...
- 2nd gear problems
- Axles - inner joint difference?
- ex intake manifold with throttle body on dx hatchback
- what honda comes stock with a 22mm rear sway??? and will it rip the subframe on a sol??
- Suspension.Green as grass and some help.
- Strange noise comming from muffler
- Help Me!!!!!!!!!!! Cam install gone bad
- NEUSPEED's Explanation of My Spring Sag...does this make sense to you?
- cv boot replacement
- Need your help..Electrical qstn? My car is dead . .
- 98 prelude 5 lug brake swap bolt up to 99 civic hatch?
- How to diagnose "spun bearing"??
- OBD2 motor into a OBD1 car?
- AC belt removal
- Fluidyne Radiator theory
- WHY ?? is it pulling 2 the side ?
- ******** HELP TRANNY Y20 PROBS *************** PLEASE HELP
- progressive springs??
- What does changing the valve seat angle do to performance
- Differentiel LSD Housing!!!!
- Coilovers in, something not right not???????????
- I think my "Arm Spring" broke on my tranny
- Best ECU\program?
- Should I Dyno?
- crank pulley removal
- Can someone tell me how to use this "Tie Rod" puller? Pics inside!!
- Any good news with Crower cams?????
- Anyone who has a helms manual that can help me??
- Engine Flush
- Head gasket question!!! HELP!
- wheel shaking
- 5 lug ITR conversion on the EF??? has it been done?
- does anyone have a pic of ground control coil overs on a hatch
- need info on b18c5 bottom end?
- Fastbrakes 4 piston kits fitment issues...
- What all needs to be done to PROPERLY install pistons\rods?
- wheres the oil pressure sending unit on my 94 integra rs?? need help fast!!!
- Newbie Questions
- can anyone help?
- water from exhaust?
- Car not starting need help???
- what does a gsr girldle look like and...
- Converting OBDII ---> OBDI
- camshafts(need help)
- How do you tell the difference from .......
- Transmission internals/housing swap..
- 174k miles on motor w/greddy turbo
- Ground Controls have to settle??
- JDM vs. USDM B16???
- Civic Water pump
- ls/vtec blockguard and girdle quesiton.
- best pads these days
- is my engine blown?
- WHY DOES THIS HAPPEN????!?!?!?!
- help with p-28 ecu problem skunk2 chip
- apexi???????
- Apexi???????
- Power steering parts
- Help w/MSD Fuel pump
- B16 Clutch on B18?
- type R O2 sensor hook up
- best place to buy OEM parts online?
- Where to get crank balanced and micro polished?
- about to adjust valve on my honda civic ex 96.. anyone know specs?
- What parts do you need for an axle swap?
- Header Question
- Crank pullies?
- Distrubutor install
- The Quick Fix
- Alternator Question
- I need help!! ODB2 specialist
- Emissions Help!!! Please take a second to see
- automatic b16 cams
- even more grinding?
- ball joint
- Are Tenzo R lowering springs any good?
- wheel weight
- ctr cam install
- My rants and raves about Frank motors and factory VTEC motors
- Anyone know anything about a Clutchnet aluminum flywheel?
- Auto won't shift at the right point! PLEASE HELP!
- brake bias and brake proportional valves
- A'pexi WS Coilovers???
- Why would i pass emissions at 15mph but fail at 25mph???
- proper cam breakin procedure
- How to lauch on 2000 GSR???
- Wheel/Tire experts........ 215/40/17 ok?
- Drive 3
- Difference between the D16Y8 and the D16Z6 heads
- ECU swap and immobilizer : help!
- plz help: cooling system problem
- Ground Control install instructions HERE!! 92-98 Civic!
- Header advice
- cooler engine?
- Question regarding master / slave cylinders
- hawk hps pads
- what does my gas cap have to do with emissions inspection?
- Is this true? Emissions question....
- Mugen dohc prog P28 ECU in my Hybrid?
- axles in a 96+ civic
- FYI cherry picker
- Distributor problem!
- B16 head on B18c block
- POLL: brake pads for street, come cast your vote
- HELP w/ ac removal
- GS-R Girdle on an LS Help (HX_Guy or any other)
- GSR fuel pump in a 92 hybrid?
- Will a differential from a cable tranny B16A?
- Aftermarket crank underdrive pulley. Are these safe?
- Larger pulley to reduce steering pump boost?
- when replacing nuts n bolts...
- How to deal with broken pulley bolt?
- Help.... OK Get this straight, obd-nothing B16 head use
- 2001 Prelude Turbo Setup...Help what do I do
- b20Z vs B18B block
- NEW Suspension question(s)...
- H22 distributor problems
- Spring behavior at diff compression levels?
- ecu chipping
- Anyway RHD is legal?
- likelihood of bending a cast 16 w/55 series tire
- Who makes a 22mm front sway bar?
- fuel mix
- Anyone running Spec B's with portflow inner/itr outer valve springs?
- vtec boggs
- Q about auto to manual conversion
- will 94-01 integra brake lines fit ek civic?
- need help with speedometer problems
- Autometer Tach with no instructions. How do I install this thing?
- Need help on engine rebuild
- normal opperating temp in degrees celcious
- I have done all I can, yet I am still plagued by wheel hop
- Suspension Spring Color Codes For Integras
- trw high-fire rings and comp cams valve springs, anybody have any knowledge of these?
- Checking for VTEC damage
