Brake question
Old Nov 25, 2003 | 08:28 AM
whatcivic's Avatar
Default Brake question
Will rear discs from a 90-93 integra fit my 93 civic coupe? Theis swap comes with the control arms but I can't get anyone to confirm if they will actually be a straight fit. Anyone done this brake swap? Thanks in advance for any intelligent input.
Old Nov 25, 2003 | 01:35 PM
dirty_d_cx's Avatar
Default Re: Brake question (whatcivic)
lets put it this way
almost anything from a 94-00 integra will fit on a 92-95 civic
i dont know of many interchangeable parts between 90-93 and 92-95
i do know that if you want to do a reag disk conversion you can use the rear assembly off of a rs integra or a ls, they use the same size disks and same calipers as the gsr and many junk yards will charge less because it isn't a "gsr" and the ls/rs doesn't have abs unless thew original buyer opted for the abs then they are identical
the same goes for front brakes on the 94-95 honda civic ex 4-door w/abs front brakes and the GSR front brakes, they both use the same, knuckle, hub, caliper and disk
Old Nov 26, 2003 | 07:29 AM
whatcivic's Avatar
Default Re: Brake question (dirty_d_cx)
thanks
Old Nov 26, 2003 | 01:44 PM
dirty_d_cx's Avatar
any time man
simplegreen7
Suspension & Brakes
Oct 2, 2013 12:00 PM
B16Civic93
Suspension & Brakes
Jun 19, 2010 08:20 PM
B16Civic93
11
Jun 19, 2010 08:08 PM
honvic21
Oct 1, 2008 04:46 PM
jus_spooln_wicha
May 14, 2007 12:40 AM
