oil turns black
Old Nov 24, 2003 | 12:55 PM
whitelightning's Avatar
Default oil turns black
anyone know what caused the engine oil to turn really black after a approx. 500 miles?
its a b18c with 110k miles,
oil changed every 3k miles, air filter cleaned every 30k miles.
thanks for any info.
Old Nov 24, 2003 | 02:54 PM
Chiovnidca's Avatar
Default Re: oil turns black (whitelightning)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whitelightning &raquo;</TD></TR><TR><TD CLASS="quote">anyone know what caused the engine oil to turn really black after a approx. 500 miles?
thanks for any info. </TD></TR></TABLE>
Is your PCV system in good working order?
Old Nov 24, 2003 | 04:08 PM
PhatOptimo's Avatar
carbon.
Put a can of gunk out in before your next oil change. I get it from autozone. Its cheap and in a grey bottle. It breaks up the sludge inside the engine. Read back of can for the proper instructions.
Old Nov 24, 2003 | 04:18 PM
Colin's Avatar
Default Re: oil turns black (PhatOptimo)
my impression was that vtec motor's turned the oil pretty dark fairly quickly.... I know mine does. But it won't hurt to do that flush.
Old Nov 25, 2003 | 05:24 AM
Default Re: oil turns black (Chiovnidca)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">
Is your PCV system in good working order?</TD></TR></TABLE>
yes changed about 10k mile, even though it was in working condition.
Old Nov 25, 2003 | 05:28 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PhatOptimo &raquo;</TD></TR><TR><TD CLASS="quote">carbon.
Put a can of gunk out in before your next oil change. I get it from autozone. Its cheap and in a grey bottle. It breaks up the sludge inside the engine. Read back of can for the proper instructions. </TD></TR></TABLE>
any repercussions from using this gunk out? if not i'll give it a try.
91integGS- i work on (3) b18c and the one in question has it bad. the others seem relatively clean compared to this one.
Old Nov 25, 2003 | 06:57 AM
PhatOptimo's Avatar
( </TD></TR></TABLE>
No it works good. I used it once. Mine wasn't too bad. I wanted to try it out because it was cheap. On the bottle it says you may have to remove the oil pan and wipe it out in extreme cases because it washes all the sluge to the oil pan then it sticks in there. It also says you can repeat the procees but I guess you'd have to refill with new oil and start all over. A waste of oil if you ask me.
Old Nov 25, 2003 | 07:39 AM
976's Avatar
976
New User
oil turns black </TD></TR></TABLE>
Then it doing it's job.
Try syn. oil, it won't turn black...
Old Nov 25, 2003 | 08:55 AM
doublejz's Avatar
Default Re: oil turns black (976)
mine does
Old Aug 13, 2004 | 03:26 AM
m0t0rhead's Avatar
Default Re: oil turns black (doublejz)
I wouldn't use an engine flush if your vehicle has over 100,000 miles.
You may start leaking.
Also, if you're going to use one, use BG's engine flush kit (quick clean and moa). Leave the cleaner in for a minimum of 30 min. before you drain.
vtec8200
Mar 14, 2010 09:11 AM
meanshyguy
Mar 10, 2009 05:07 AM
Delsolburger
27
Aug 30, 2005 07:32 AM
return_2020
Jul 31, 2005 07:33 PM
Ludester
Nov 14, 2003 09:17 PM
