View Full Version : Tech / Misc
- gsr intake
- Brand new ITR trans grinds into 5th at high RPM...
- Help with Fuel Line/Fuel Rail for B16a?
- Alternator swap, now car has 0 powaer. No lights, not ignition, wtf
- B18/B20 rods in D16
- Squealing noise after New motor install
- two step limiter control for $55
- STOCK SLEEVES, HP?
- car starts then stalls immediately???? need help
- SMOG HELP!
- Question about increasing displacement
- would you recommend a stock cam gear for this build?
- Can I re-use these?
- h23 intake mani on h22?
- Getting rid of AC add a roof scoop?
- Help on fog lights for civic EG6
- p28
- CTR piston + m22xx valve clearance issue?
- ways to remove scale build up between water jacket???
- converting speed sensor crx cable to electric question
- HELP!!! ==> Car won't start when pumped FULL TANK?? <==
- Will this damage my engine??????
- Need mesurements on apexi afc quick
- OBD two troubles emission failed 99 accord
- Brake Upgrade
- CIVIC exhaust piping size?
- Cat Converter
- usng resistor from a 6cyl on a 4cyl.
- d15b motor swap
- facing clutch disc
- synchronizer kit 1-2 gears
- TURBO CIVIC SI EMANGE SETTINGS?
- High Idle Problem
- More tranny probs - popping out of 2nd gear
- B16 OR F22
- need some help identifying some parts...
- brakes
- JDM ITR into 92 GS-R
- Car won't start - Clicking starter - loose ground?
- Timing belt woes!
- VTEC and hesitation / stuttering (goes away with raised crossover point)
- OBD0 to OBD1 conversion. codes 20, 23, 41. blink, blink...WTF!!!!????
- really need help picking this primer & clear
- Skunk2 pro2 cams won't idle! any suggestions?
- checked cel, pulled jumper, now no start
- Disassembling Motor?
- 5TH Gear pops out, please help......
- Good/Bad ??? synthetic royal purple tranny lube
- Transmissions
- is this going to replace the piston engine?
- Car steadily loses voltage when the car gets really hot? WTF?
- bogging out with one wire o2 sensor
- Auto Transmissions ?
- Radioshack logging cable
- identify my manifiold
- 5k rev limit
- uerdata tuners i Va beach?
- Bearing color codes
- Time to replace the timing belt
- Where to find first gen b16 fuel rail and regulator?
- Motor takes a long time To WARM up ###############
- ctr crank pully
- How tight do u guys have your Timing belts?!@
- turbo ls problems
- Newly built LS/vtec burning oil... valve seals i think.. help if ya can.
- White smoke from engine, black smoke from exhaust
- diffrence between gsr cams and b16a2 cams
- SCI igniton box on d16..starts ocasionally??? Help
- Sputtering Si help
- Comparing Engine Swaps...
- Anyone know the diffrence between gsr and LS front hubs/brakes?
- HKS EVC HELP
- obd0-obd1 jumper harness...B16 obd0 engine?? stupid question
- Clutch Help, does this look right?
- I Need some Serious Help
- OBD Code P0497, Evaporative Emission System Low Purge Flow
- Painting Problem
- Poor gas Milage, HELP!
- 2ndary butterflys arent kicking in
- 99 Civic B20Z swap
- quick: which VTEC cams are these????
- OLD OLD OLD OLD Transmission Topic Index/FAQ/GOOD LINKS/ETC.
- How am i still getting p0108 codes?
- Why am I getting these codes?!
- Throttle Body!!!
- tranny question?
- Anyone know where to find manual trans internals? 4th gear LS
- alternator belt whine @ start up.
- What transmission do i have? RPM to miles per hour ratio
- CR-V what mounts to use to put b18 in a CR-V?
- chipped socketed ecu questions
- tightening crankshaft bolt??????
- Motor mount bolts cracked in block….NEED HELPP
- vtec not kickin in?
- Code 17, VSS, but speedometer still works?
- car won't stay running any suggestions
- Couldnt find it in a search...Reusing coolant?
- Part numbers for LS 5th gear swap??
- SRS Light
- Exhaust...
- help.. check code 10
- seafoam on high mileage d16y8...good/bad idea?
- what kind and where to get transmission fluid for my clutch type kazz lsd...
- wiring V-AFC II type r?
- closed deck...
- Climate control unit & air conditioning... (5th gen Civic EX coupe)
- 99-00 Civic Si Injector HP limit.
- VR6 question
- Leaded gas in built all motor car, no emissions crap, SAFE??? Need answers ASAP, PLEASE!
- would this scratch on my cylinder walls cause my car to smoke?
- Please Help!!!!
- fuel pump question????
- B16a Misfireing problems
- cam cap
- Im thinking of Purchasing a new car.
- Manual Trans Rebuild...
- B Tranny Code
- backpressure?
- [Improving sound w/out sacraficing flow]
- check engine light code 11!!
- car won't stay running PLEASE HELP
- i have a exhaust manifold problem?
- Uberdtata and programing a chip, Need a good MAP!
- *HELP* Grinding noise coming from timing belt area!
- JDM power mirrors for 88-91 civic part #
- how much nitrous?
- injector swaping.
- Tranny Code...
- OEM LSD or aftermarket LSD
- too much oil, drained oil, car wont start.
- Will a LS auto tranny fit a jdm b16a block[yeah,yeah i know]?HELP HELP
- no injector pulse
- What parts to buy for my B18C5?????
- NEWBIE
- B18 camshafts into a B16?
- dam i think i fu*$ up
- Is there any hope left for my motor Picture inside
- Where to get mandrel bent exhaust pipe.
- d16y8
- broken injector (plastic piece)
- Can't believe I'm doing this... I have a question about AFC Hack. SEARCHED
- head swap question!
- Choosing a Clutch.
- Changing timing belt on a b16a
- Radio code.
- I am STUMPED. Tachometer still trippin out. Any ideas??
- auto to manual
- tuning up
- I Have a Problem On My 92 Integra
- P26 vs P06 ecu
- Romulator problem.. Anyone?
- vafc II help..tried to change the fuel settings
- something wierd here?!
- Funny sound coming from clutch/gearbox....
- transmission switch parts
- EF8 Parts???
- kpro or stock
- H2A5 Ratio
- 98 Civic Ecu trouble
- ECU Chipping ?
- 3rd gear not kicking in HELPP!
- Project: My First Motor Build
- quick ?
- DIY Brakes for the Newbee
- Rods modified for type r pistons?
- OBD0 - OBD1 harness help needed
- CEL came on, PLEASE HELP
- Scratch in rotor. Will this be a problem?
- ?'s on aftermarket valvetrain
- Please tell me it isnt a headgasket.
- Running without resistor box??
- oil seperator / catch can / swirl pot, are these all the same thing?
- LSD Tranny.....
- block brass drain plugs
- Electrial Problems
- installing fog lights
- DOES CROME HAVE NITROUS CONTROLS
- What kind of signal does the fuel gauge receive?
- 3rd gear poping out of gear
- Transmission Shops
- hondata Romulator help..
- Reusing engine bearings?
- I cant figure it out, Shifting.
- ITR final drive in a LS trans
- ECU Experts! Decipher this P13 ECU! Need to know the specifics
- Crazy speedo needle
- f22b2 block w/vtech head
- Vtec lag on B18c1
- idle aircontrol valve
- YS1 rebuild
- Car won't go into gear- 1999 prelude type sh
- Need a D15B Vtec MAP, I am burning a chip
- Brake Problems with B16A2 Swap in '90 DA
- Any way to control what the fuel gauge shows?
- Oil Analysis Results with some questions. Pics inside
- need to know where to get a 1" hd belt for a peterson oil system !!!!
- Rebuilding my transmission with a quaife and infinitude close-ratio gears!
- b16a2 thermostat..... which one to buy. (and a obd1 coil question)
- b18a and b18c block: physical differences
- Gsr transmission whinning
- loose timing belt, milled head, lsvtec
- How do you fix a stripped head bolt hole?
- LSD clunking at low speeds.......
- ARP main studs impressions- some questions too
- Soch Aem fuel rail for my doch LS vtec build?
- MISFIRE fixed after rebuild caused by crazy problem...
- mad vtec!
- Quick question
- Rpm gage stop working
- Anyone Know How to Wire Up Hondata 2 Step? S200
- LS/VTEC VS TYPE -R??
- b18a block,b18b1 head.. need help
- Non obd distributor
- Headgasket question??
- hondata p28 vs. p30
- Idles when cold, dies when warm
- ***Official*** B16 Thread, Everything B16!!1!
- Wich ignition system to use ?
- GSR Rod Nut pitch and size??
- H22a bog occasional bog Stock everything with walbro 255lph
- Caulking a VAFC
- oxygen sensor causing me to go into limp mode? doesnt make sence to me
- GSR getting so smoke
- Questions about Fuel Efficiency
- TPS Data Sheet For 03-05 Accord V6 6MT
- Put in jdm ecu. Vtec pressure cell, Electrical load detector cell
- inner tie rod/boot grease question
- Drive to Neutral on stop light or during anytime
- Replacing subframe bolts
- Transmission problem need Help...!!!
- Transmission Problems????
- B18B Throttle Body, is it can fit to B16A IM?
- messed up, need timing help badly
- Neeed help with ZC motor and Hf Tranny
- check out my transmission
- Oil pressure question for my GSR.
- oem?
- MSD question
- what sensor green plug by vtec solenoid b16
- eg blowing ecu fuse
- ls vtech. need to know what head gasket. bad advice
- Over heating on the highway
- Quaife LSD.... what fluid???
- b18a1 max rpm
- I need a swap
- hey guys any one kno how to tune vtec controller
- D15B Swap, Engine wont start :-(
- ignition problems....???
- After Cam install Oil and Coolant leak
- hybrid fuel pressure gauge?
