View Full Version : Tech / Misc
- anyone use AMSOIL?
- Anybody know the temp range of the OEM coolant temp sender?
- What pistons will work best
- Is a factory ITR clutch stronger then a factory B16A2 clutch?
- Generic intakes??????
- brake feel
- Rotational Mass and ET time (CSA vs Mugen?)
- B16A, the limits of NA tuning?
- vafc hack...
- Which CATBACK EXHAUST SYSTEM is better for a Accord 4cy?
- help: jdm b16a engine guru..identify this sensor please
- coilovers
- Timing Belt auto-tensioner (H22a)
- transmission wont shift
- safe redline
- Repair Manual
- Accuracy of the tachs?
- V-AFC wiring problem
- Main bearing/Rod bearing codes
- Azenis 195/60-14???Anyone have these?
- Dual point distributor for CRX 89'
- Q for the welding gurus
- How could you tell?
- KOS header dyno result..check it out
- Pulley question for 99-00si
- B16a Head Stud Kit which Part Number? B18b or B18c?
- Stupid front tower bar question
- smoking CX....
- 82mm Over bor worth it??
- Internals
- Using connectors or solder for S-AFC?
- Engine swap directions?
- Comptech Ice Box vs. AEM CAI
- Type R Pistons
- A/F Gauge Wiring
- J&S safeguard ultra and dual monitor instructions?
- Replaced secondary o2 still getting code 65
- I'll send you $$$ if you fix my problem - vtec
- h22 vs h23?
- abs & srs lights on!! Help plz!!
- just got new brakes and they sqeal??
- ECU check
- Michelin Pilot sports...is there anyone who can comment from experience?
- 1.8L to 2.0L ??
- What must be done to add a 75 shot to a B18C1?
- Let's hear all your Pass Smog tips!
- Shift linkage problem
- crank woodruff key slot
- Need help with battery/charging system
- can A/C hurt your car in anyway... besides losing HP
- Weird whistle-like sound coming from one of my pulleys.
- Scale of 1-10 how hard is it to replace hub bearings......105K figure why not.
- tool recommendations
- Turbo question- ITR cams
- simple vafc question??
- installing a LSD on a b18c1
- uneven lowering = neuspeed race springs + tociko blues?
- what size rim for m/t
- where to get a b18c1?
- Stripped Bolts... any suggestions?
- installing mechanical oil pressure gauge
- b18a1 to b18c1 swap
- AEM Tuning
- changing valve seals in a b18c
- Tokico and S2 opinons please
- Tokico and S2 opinions please
- Help... fuel pump issue...
- Speedometer works off and on... ('95 Civic EX)
- Nuespeed Strut Tower Brace:
- jdm ecu's
- Clutch Chatter
- i got the dc sports jdm header for my 99gs-r what all do i need?
- anyone know the integra gsr manual transmission fluid part number?
- 99-00 Exhaust Fitment Compatability HELP!!! EXPERT ADVICE NEEDED!!!
- where to buy cheap calipers?
- "Left Outer Tie Rod"?
- To much oil...
- Pillow mounts & alignment????
- Advantages Of Brake Cylinder Honeing?
- jdm h23a4 turbo?
- How do I recalibrate my needles
- LS/CRX.. which CAI?
- Install my own clutch....or have a mechanic do it.......
- cable vs. hydro trannys
- RC Injectors for b20 setup
- Baseline of motor, graph inside.
- which cam gear goes where?
- Dyno Q's
- estimate
- B16 w/ JUN III cams... what's the HP?
- Coilovers
- anyone with a B&M fuel press. reg?
- Building a "B" series block and have some questions....
- What to buy next? I need help deciding.
- Does a CEL code 65 affect performance
- will jdm 4-1 header fit a gsr?
- Help with codes
- Tanabe, Tein, Spoon, Zeal, Showa.. which is best?
- B-Series TPS, are they all the same?
- Car died on me...check it out!!
- D series motors
- Transmission fluid...
- endlinks replaced as a set?
- CEl coeds what could be causing them
- SOHC vtec head
- compression test results
- A/F fuel gauge...need help looking for a good one.
- car jumps between 2000 and 5000 rpm?? wtf?? need help?? please read everyone!!!
- Car mods to install a b18c5
- Removal of Flywheel
- question about balance shafts???
- SKUNK2 or Ground Control
- Wheel spins in neutral?
- MASTER CYLINDER UPGRADE for a 90 teg RS ?? type R
- Guy that makes type r chip programs????
- 5zigen
- boosting on new motor
- Is a throttle body or cams next???
- Cant see timing marks...
- using b16a2 cam caps on a gsr head???
- tach jumps after 6000 rpm
- Need Tuning ASAP for ECU
- Where did Mike K from Naples Acura go?
- JDM B16a1 question
- High Idling problem !
- rockers?? what sequence do they go in??
- What type of coilovers....
- Tranny people>>>
- exhaust question...help
- OK To reuse a 2 month old headgasket?
- Cars leaning
- lower balljoint WON"T come out
- Valve lash!
- Seasons
- Platnium or no platnium
- Need help today please!!!!!
- cam gear teeth and ignition timing (h22a)
- camshaft question numer 2
- ITR piston quality vs. aftermarket
- Engine Lugging
- Civic ignitor work in an integra distributor?
- Moroso plug wires
- Zeal Coilovers? Help
- Just bought an Autometer electro AFR and Oil Pressure Gauge.
- engine will not crank or anything
- Torn brake caliper seal: Should I worry?
- Problems starting. Click, Click, Click ---- then it starts up? Bad starter?
- what would cause hesitation when on the gas?
- is it possible
- Going from coventional engine oil to synt, what do I need to do??
- crower cams
- CTR piston
- 1st Generation AFC owners.
- Where to get 3 inch diameter rubber connector hose (need less than a foot)?
- Compression Ratio for Type R Head on LS block with ITR Pistons?
- IACV interchangability
- need help on exhaust
- camshafts
- next mod need advice
- cracked radiator= slower qtr mile times????
- excessive fuel consumption
- stock D15B VTEC ????
- LS Throttle body work with a B16 Intake manifold?
- Ok to drive with a VTEC head with a nonvtec ECU?
- ** Sfc-vtec problems in DC2 Si-Vtec Teg, PLEASE HELP **
- Good tires for street/Auto-X
- weird problem....look here
- broke a bolt in the head...what to do??!!!
- OT: Silicone hoses........can this be dangerous?
- skunk2 intake
- QUICK A/F guage wiring
- bypass valve for cai
- Need some info on a DOHC D16A1 ...anyone ever seen or know anythign about this motor?
- running extra Rich......performance loss ?
- Please help...this damn distributor problem is killing me
- 3 quick questions regarding B16A2
- oil pressure...vtec disabling???
- Oil thickness in plain english...
- Energy suspension inserts
- What next?
- why only CTR intake cam?
- Silencer on my Apex Dunk is STUCK
- Ok simple one for all u tech-heads
- Is there a difference between USDM D16Y8 and the JDM?
- Alignment Issues (Camber & Caster)
- b16a usdm and b16a jdm
- Is This Bad?
- Timing belt symptoms?
- Which Anti Sway Bar(s) to use?
- IACV question
- suspension, koni, tein?
- Weird CEL problem, please help!
- How much would pay for....
- REALLY NEED HELP with wiring ( CR-VTEC )!!!!!!!
- Idle Problem & Code 43
- Need to do research: Please post informative sites on the LSVTEC conversion.
- difference between long block and short blocks
- Ok, one more thing...What KIND of spark plugs?
- hesitation with quick throttle from idle
- trouble starting up now...
- Lucas Transmission fixer...any opinions?
- Dry Sump B series?
- VTEC solenoid filter/gasket
- oil for type-r
- Why does my engine light come on when dynoing???
- Video
- GSR problem....PLEASE HELP!!
- Lowering a EK Hatch
- trickle charge - electrical damage?
- Will a mustang fuel pump fit in my 94 civic vx?
- apex v-afc reading tach wrong
- Custom Exhaust
- VAFC numbers for fuel on a b20vtec??
- Engine swap today!! Come see the work in progress!!
- jackin up a lowered car
- RSX S "Limp home Mode"
- has anyone ever use a front lower arm bar or a front lower u bar???
- Need help! Don't know what to do?
- ctr cams install on 00 si
- Problems with civic
- idle loping
- Race Ready cams? (stage 2)
- Problems w/ the accord
- Flywheel Questions
- Clearing system errors
- Leak Down Test?
- oil catch can question...
- alright got a simple one for ya'll
- Replacing Spark Plugs
- b20 mount questions
- Help asap.....
- Need help with argument in kills forum. (Possible Stunna)
- To install or not to install the Air Bypass Valve
- squeek in clutch
- 95 teg blinkers wont work
- front transmission bearing problem
- FUEL INjector/COmputer problems!!
- knock sensor install question?
- dear god, why me?
- dx hatch tranny q
- modification for block girdle
- Shock Through Hood.
- anyone running copper head gaskets/o-ringed?
- Interesting A/C situation
- Changing Brake Fluid on 97 Civic
- swapping tires to different wheels
- aem cai
- integra manual transmission fluid?
- Brief Valvetrain questions...
- need some math help - intake calculations
