HELP! Something is wrong with my driver's side power window!
Old Nov 25, 2003 | 03:51 PM
EX-T's Avatar
Default HELP! Something is wrong with my driver's side power window!
Well today my driver's side window is acting wierd.
It works fine until it gets to very top, when it gets to the very top it starts to hop and won't close all the way?!!?!
I took my door panel off and pushed the close button and pushed the window up at the same time and it closed.
Anyone know what's going on with my window?
What do I do to fix it?
What do I need to fix it?
TIA!!!
Old Nov 29, 2003 | 07:01 PM
krzyaccord's Avatar
Default Re: HELP! Something is wrong with my driver's side power window! (DSeriesBKilla)
Either you need a window regulator or a window track. You might need a motor, but I suggest you look into those two items first. If you don't want to guess try spraying silicone spray on the window track, it could just be binding. Hopefully this helps you out.
Old Nov 29, 2003 | 07:56 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DSeriesBKilla &raquo;</TD></TR><TR><TD CLASS="quote">
Does it make a grinding noise?
Old Nov 29, 2003 | 09:19 PM
EX-T's Avatar
Default Re: HELP! Something is wrong with my driver's side power window! (Chiovnidca)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">
Does it make a grinding noise?</TD></TR></TABLE>
Naw, it just makes a popping noise when it drops back down rapidly.
Old Nov 30, 2003 | 12:58 AM
hondamama's Avatar
Yup, prolly the track. One of my cars had the same problem.
Old Dec 1, 2003 | 07:15 PM
EX-T's Avatar
Default Re: HELP! Something is wrong with my driver's side power window! (teggie-teg)
Today I rolled the window down and happened to look down in there and a few of the teeth from the big gear are missing.
Does anyone know what all comes with a new window regulator from Honda?
Old Dec 2, 2003 | 02:41 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DSeriesBKilla &raquo;</TD></TR><TR><TD CLASS="quote">Today I rolled the window down and happened to look down in there and a few of the teeth from the big gear are missing.
Does anyone know what all comes with a new window regulator from Honda?</TD></TR></TABLE>
That's part of the regulator. You never heard it grinding, huh?
Old Dec 2, 2003 | 03:43 PM
EX-T's Avatar
That's part of the regulator. You never heard it grinding, huh?</TD></TR></TABLE>
Nope, it didn't make any sounds at all and then it started to hop when a buddy drove it down the road.
Old Dec 2, 2003 | 03:53 PM
Kendall's Avatar
Sounds to me like a perfect opportunity to upgrade to fixed lexan windows.
deerman2701
Nov 27, 2007 05:59 AM
djfob
May 8, 2006 02:09 PM
MtbikingKing
Jan 19, 2006 08:21 AM
Sean @ ESG
14
Sep 9, 2005 09:21 PM
EX-T
Nov 27, 2003 07:26 AM
