View Full Version : Tech / Misc
- type r head on my gsr block?
- One Honda Specialist......?
- injector compatibility for gsr
- Sport light flashing when pulling engine codes? I really need help!
- New exhaust install??
- How to install a body kit???
- gsr distributor on LS?
- Wiring schematic....can anyone help me find some information.
- web page for 94 GSR
- ls vtec gaskets
- B heads
- oil in coolant
- After swap, trying to hook up the power steering.
- installing new intake manifold studs
- Steering Wheel Install Problems
- anyone know about this vtec add on lcd controler
- Newbie questions about "final drive"
- lsd, but no speed sensor,
- stupid LS question
- knocking noise from the driver side;in engine bay
- How does an actual O2 sensor work?
- gsr crank threads for flywheel bolts kinda stripped
- Car has been in storage all winter and it just started leaking oil w/o being driven?
- What good coilovers are recommended for the Tokico whites?
- Lost motion device
- Distributor wiring on a swap
- want to pull a fuse for extra security...which one???
- fuel leaking from the tank
- Jumpy Idle
- Oil on the Spark Plugs
- Engine noises
- Went to the track today and had one good time and the rest were crappy, can you tell me what happene
- Dunlop SP Sport FM901 in the snow!!!!!!!!!
- mixing leaded and unleaded fuel?
- HELP: Car wont start sometimes
- quick VAFC question...
- help a brotha out ?!?!?!?!?!?!?!
- civic with greddy kit 1/4
- tial wastegate?
- Master Cylinder Question
- FAL windows?
- Still no luck with tracking down suspected vacuum leak. Anyone have any suggestions????
- 94'-01' teg brakes VS. 92'-95' si brakes
- Type R tranny installed, now there's a distinct harmonic hum...
- help needed with axel replacement
- I need some crazy all motor dyno plots if you don't mind.
- Thin headgasket + Milled head = timing belt slack?
- HELP! Gear that go GRUNCH
- CRX Suspension. Is there any other chassis's that will fit properly?
- Help intake manifold 94 ex
- D16A6 cranks, won't start, dead ECU?
- need suspension help bigtime!!!!!!
- fcuking o2 sensor is pissing me off
- Vehicle Speed Sensor?
- GSR Tranny Problems???
- itr,ctr or b16 pistons .50mm overbore????
- Thoughts on piston install
- Anyone live in kentucky?
- Could anything other than a bad dizzy throw a crank angle sensor code?
- F20B ECU ok to run on a H22? what you think specs inside
- Tick tick tick tick tick.... my car is ticking.
- yet another Skunk2 IM install
- flywheel ?'s, lighter=better?
- Engine Stand bolt size??
- Help me out??
- what other carb legal parts could i use to increase low end torque?
- serious probs w/ b16 swap
- No hood + rain = no start.
- Q on spark plug heat range
- ECU wiring help!
- any problems running b16 head b18c block w/jdm b16a2 pistons?
- Where can i get a custom carbon fiber piece made?
- clear tailights
- A good a/f ratio gauge
- on freeway, 5th gear, going to neutral without pressing on clutch?!?
- Projector light bulbs
- Will a 91 LS Tranny fit ANY LSD??? I cant find any straight answers.... Which one works..
- converting B18B to manual transmission
- last year that was OBD1?
- wiring people read.
- How about this clutch/flywheel setup?
- how many times can a KN filter be recleaned and use?
- Electrical problem, maybe you've seen it...
- Can I use my stock A/C lines if I did a motor swap? Please Help.
- Why do Hondas grind in third gear?
- This may be a silly question but.....
- 99gsr in 94 dc wiring?
- too all people with 01 and up civics
- why did it stall??
- Black lugnuts for stock wheels?
- d16z6 to b18c5 swap info?
- suggestions on distributor woes B18C
- ** what type of compression would I get with B16A2 pistons into a B18C1
- B18C5 bottom end with B16A head
- ctr compared to typer
- New thermostat
- problems with grease
- which pin on ecu controls o2 heater control ground
- quaife lsd
- throttle position sensor code with my new engine
- I need your opinion here, What exhaust do you prefer on a EK hatch?
- Someone calculate compression for me?
- STR intake manifold question?
- Fuel Pump?
- took off my valve cover and discovered this
- Engine noise
- tune-up what sparkplugs for a GSR ?
- problem with shift linkage
- Help-a-noob! another O2 sensor problem
- Do i need Tubes for MT 22x8x15
- OEM vtec pistons on LS rods
- crower vtec cams feedback
- custom intake pipe, built 1.8L all motor,
- Oil starvation - D16a6
- what are the symtoms of......
- camber kits?.?.?
- Header.
- Steering Wheel Problems
- possible TPS problem
- turning to you tech pros for realllllll tech question.... Timing belt experts enter
- InlinPRO
- b16 cheap bank for the buck concept
- Car will not stay on
- cheapest b16 swap websites
- Quick Integra front bumper removel
- what size is the crank pulley tool? thining of making my own tool?
- Weird problem...
- question about turbo
- blowbye and what i can do?????
- what energy suspension bushings?
- Questions about engines?
- differences in welders
- True or not?
- need answers on d-series head swaps
- HeLp Please
- magazine recommendations
- Bore LS>87mm??
- hondata s200 ?
- question for the experts...
- itr muffler on crx
- performed compression test (help needed)
- VAFC and P28 chipped Combo
- Cap and rotor swap - 99 ex onto a 97 hx...
- b16 or type R Head
- 95 cx wire harness???
- ECU Problems! PLS HELP!
- Ignition fuse keeps blowing!!!!!
- ls swap ?'s
- greddy catch can question
- Neuspeed Sports on KYB GR-2s
- Help
- Why is my b16 Timing so far off?
- basic engine rebuild parts
- HELP transmission problem
- integra ls turbo question
- can a b16 stock rods survive 9.5k rpm?
- Code 10 IAT - intake air temperature sensor -- How do I clear it?
- ls crank in a b16?
- experts only : mind boggler
- Gas Mileage and Ignition timing relationship... Simple question...
- iat sensor
- Idle Problem
- will civic type r carpet fit in a 2000 civic si
- 3rd gear bog
- Horn problem... Need help
- Funny smell coming out from my exhaust
- Temp Guage
- Symptoms of low fuel pressure on mildly built GSR...?
- AT to MT swap $$??
- D.I.Y. Fiberglass Repair . .
- '99 Si stock exhaust fit '97 HX?
- how to tell if i have gsr cams or itr cams
- welding an oil return bung for a turbo to the oil pan????????
- Best way to fix oil leak on oil filter relocation fitting?
- irratic idle
- tokico blues or kyb gr-2's?
- What is the most power potential powerplant?
- is Y8 knock sensor same as B-series?
- VAFC Problem...HELP! Searched!
- B16a w/ CTR cams anything else needed?
- Radar
- Best Impact Air Rench?
- How much to the various 15" factory wheels weigh?
- Urethane Bumper Repair?
- Swapping out ZC for B16A
- Do I need new sleeves
- Octane booster............??
- Car won't start.. need help.. think its a fuse
- b and d series injectors, same?
- I am freakin out on my EG hatch someone help me out here
- really could use some help here
- Replacing Synchro
- picked up a gsr block lookin to build it up looking 4 sum input (all motor)
- I need advise on installing an ecu chip upgrade kit: Thanx!
- Dash board question
- tanabe sustec and koni yellows
- import engine tutorials?
- engine swap question
- A bunch of questions about further h22a civic 95 coupe hybrid modifications
- OS Gikken clutch
- more exhaust tickets in NYC.DAMN!
- Short block vs Long block
- 92 hatchback vs my accord 98 (6 gen)
- Throttle body selection for LS turbo
- ecu swap
- Help with Trans.
- can you really bypass the knock sensor by just grounding the respective pin?
- Valve Adjustment?
- kinda a ricer question but i cant chirp 2nd (b18c5)
- Where is the VIN # on a D16y8?
- B20 Vtec is struggling to START!?!
- Engine Problem
- tranny or motor
- 22 VTEC pressure valve...How do I clear this code?
- rough idle
- mating rod to wristpin
- how to identify b-series oil pumps
- Read this if you've ever considered the "electric supercharger."
- Apexi World Sport Install w/pics and comments.
- Wiring Harness diagram
- valve seat
- How do you measure collector size on a header?
- Anyone know what compression this would yield????
- Where are the MAXIMAS??!!
- main harness or engine harness problem?
- AEM Cold Air Intake Installion on a 99-00 Honda Civic Si
- H22 or B20..i need advice???
- built gsr motor with ls tranny...
- what kind of oil should i use..?
- ZC probs....
- d16z6
- 5 lug hub Q
- B16 swap then a CAS code I cant chase down
- Adler, Nissin, and NTP = OEM Parts Manufacturers?
- NE1 used VDO gauges?????
- exhaust question
- Vtec manual????
- code 1 after running a stock and chipped p28?
- Question for Newman, Poison, and other h22a owners regarding the swap.
- help whats wrong wit the civic
- Crank pulley bolt spins counterclockwise to loosen, right???
- Vacuum brake bleeders
- Wheel Bearings
- port and plishing
- orange wire on safc?
- TDC marks on cam gears aren't lined up....how do get them straight?!
- whats wrong wit my ride?!
- what welder yall use for clips spot welding,wire welder?
- building a gs-r vs crvtec
- N1 Crank Pulley ?s
