View Full Version : Tech / Misc
- Best way to kill my car
- another 16??
- Check out this RSX Type-S motor
- OBD0 to OBD1
- Vtec Head On JDM B20B
- Question on windshield wiper motor for Integra
- Misfire at high revs???
- Need tire opinions: Yokohama Avid V4
- MAP sensor
- ls internals/gsr block help!!!!
- stuck bolt
- new rear brake pad problems.
- Need help from Smart People plz...Look@
- Nitrous
- coilovers
- claying the motor for clearance.
- Place Racing Motor Mount Question
- mini-me questions
- Air Conditioning question for the pros. who can read a/c guages?
- big throttle bodies...
- cleaning throttle body and intake manifold.
- NOS or ZEX? Whys Zex safer?
- Did anyone recieve this with their Exedy clutch?
- Clutch screaming like a $5 ho
- car doesn't start grrrrr
- Installing Honda Factory Driving Lights
- transmission problem
- Lose my Power Steering???
- How would you rate Apexi world sport coilovers??
- cold cranking amps
- 90-93 integra cluster in a 96 accord
- 96 DX tranny ?
- nitrous with high compression?
- Clutch master cylinder question
- Wiring issues?
- vtec head or just the whole block????
- Clutch making noise when engaging?
- Causes of backfiring
- HP rating for non vtec LS motor?
- spark plugs
- Falken Azena Install (Pain In The Arse)
- Clicking in transmission
- Help!! Clutch or Tranny problem
- im having a car problem, please check out this thread...
- Ground wire kits
- help car idle low then turn off
- does sears sell this?
- Intake manifold?
- What size injectors do i run with 12:1 comp. ??
- ECU prob!
- VSS pulse voltage
- how do I check my fuel lines?
- b16a ecu problem help me
- What type of sealant should I use on AN/Pipe fittings?
- D16 Woth it?
- question on stuck fuel injector and broken rod
- Help!, my car died suddenly while in park, now it wont turn on....
- VAFC nessecary with Y8 Mini-me swap?
- V-AFC with Boost?
- Slipping out of 5th gear!--Help??
- How much will jun 3 cams help my current setup(experts help)
- Off Topic but need quick help for friend (Shifting Problem)
- Check vtec lobes for piston contact.
- Need suggestions for total ignition cut out..
- No Compression in Cylinder 2???
- block/head compatibilty-mini me
- Mild Rebuild: thoughts,ideas?
- new clutch, breaking axles, why?
- Clutch disc and pressure plate same on Bseries??
- chipped p72 vs. VAFC??
- GSR fully built with a JRSC { advice needed }
- ECU codes???
- timing problem after cam install?
- B20 Building
- Help Me!!! MY gsr is jerking at low throttle.
- aaaaahhhh damn!!
- baro sensor where is it
- DX swaybar hardware?
- AEM or K&N?
- Help with CEL CODES
- electrical system
- put this on a honda
- nitrous get old?
- Question about valve clearance and fuel?
- Got my valve train!!
- Need help !!!!!!!!!!
- melting spark plug
- YES or NO question help!!
- Will B16 TB fit GSR engine?
- starter for a B series?
- nitrous on 1998 type r
- type-r block for 500$ ?????
- can i borrow your valve spring compressor.. ill pay $$
- Whats a good plug for A LS/VTEC....
- 90 integ can i put v-tec head on my ls
- Upgrade the valvetrain on GSR wit high miles good or bad???
- d16 a6 motor specs
- fuel press question
- crvtec bad r/s?
- black/gun metal Lug Nuts
- Dream Setup?
- integra brakes or upgrade stock? 96 cx
- Let's talk about Volumetric efficiency
- Trouble codes not showing up,what am I doing wrong?
- Is this wise?
- aftermarket bumper... need help with turn signals
- What's the difference?? H/A Gurus Please Advise
- Water behind IP(dash panel)
- Voltage trigger switch ?
- Beep Beep, I can't sleep
- NA Engine
- Which Speed Sensor (VSS) should I use?
- Question of morals (tech related)
- Clutch Install = MTF Change? ASAP RESPOND>
- failed emissions - have the diagnostic report - what do i need to fix?
- difference between 62mm and 64mm throttle body?
- tie bar fitment question
- help needed: G2 with ITR pistons and internal engine mods
- Automatic axles & Manual axles...
- Oil? Black liquid? inside intake manifold...
- Need some pointers?
- haltech vs aem ems vs all others (yes i already did a search)
- H22A Throttle Body bolts to GSR Intake manifold?
- EF B16 tach
- People with ZEX 59300 cam, read HELP!!!
- Mugen chiped ecu w/ ctr cams help
- Do all s1 trannys come with LSDs...
- What is wrong with my car?
- Skunk2 intake manifold question for GSR need help!
- I need some help here.
- what tool besides puller to get off lower control arm to remove CVs
- gsr o2 sensor
- tranny swap?
- Is block guard necessary or detrimental?
- b16a hatch, axle/clutch install???
- built b16 block/gsr head build up
- What piston rings with your built turbo engine?
- Any other way besides Magnaflux?
- gsr tranny problems
- OBD 2-OBD 1?
- What valvetrain are you using?
- witch radiator should i get
- Any good way to put door panels back on?
- is this a starter problem?
- Trying to learn more....
- r/s ratio.
- oil in spark holes..car won't start!
- Coilover collars rusted...what to do?
- Block heater bad for head??
- starting problems
- How does toe affect handling?
- Import builders block
- Help on Timing Belt Covers, Will b16 ones Work for for a B18c?
- Mugen or Stock headgasket
- Permacool Sandwhich adaptor
- choosing a welder, advice needed
- What exactly is a AFC hack? I searched the forums cant find out how to do it
- Do you use more gas when the heat is on?
- can someone please help me
- What is a resignator?
- Car keeps stalling
- Vtec point via V-AFC
- tire size..
- slave cylinder
- Toyota Truck ignition system ?
- b18c1 blowing smoke after instaling "10 pound" fly-wheel!
- i need help please read
- How much effect do suspension mods have?
- Thermo Switch connector??
- where is the starter module
- Suggestions on 1988 Honda CRX DX engine drops
- z6 intake manifold on y7 head?
- GSR with B16 head???
- would a bad tranny ground keep the starter from cranking enough?
- Whats the compression ratio for this setup!!
- Question about CTR camshafts in GSR??????
- HELP, Car won't start!??
- Switching heater controls
- Air Fuel Gauge not working properly *HELP*
- 92-93 teg MAP same as 94-96 MAP?
- LS/VTEC longblock $1000 a good deal?
- Got my ITR cams and valvesprings installed
- Clutch Bleeding
- why do i keep blowing head gasket's?
- Help!!!! Engine making odd noise after headgasket incident
- 96 Integra Suspension Creaking...
- The new CR-Vtec???????
- I got my alaniztechnologies cyl head 56k beware
- Could i go nitrous in the future or not?
- how to check compression
- scraping questions
- b18b/c crank in a b16
- Coilovers or Not ... That is the question ???
- 1.5L carb 86 crx, wont accelerate passed 3k rpm's
- check engine light at WOT, tps problem?
- I need a Hondata.
- Car dies at stop lights
- hey guys what could cause excessive drag on a motor to keep it from starting?
- inline fuel pump before or after the fuel filter
- 95 LS Torque Specs
- rings question...can this happen
- soap and water?
- Tire removal from rim
- Car won't go over 4200 RPM
- Which header for my application?
- hi guys,can i put a p-28 mugen chipped ecu on b16a first gen
- 2001gsr in 92 hatch CEL problems help.
- fuel pump question>?>?>?>?>?>?
- Mugen ValveSprings
- Comptech Icebox vs AEM CAI, JDM Header vs 4-2-1 DC Header
- Possible Ignition problem... I really need some help!
- tranny won't come out of reverse!?!?
- 6th Gen Power Gains From Tuned SAFC?
- all honda techs please help me!!!
- replacing crank oil seals - easier way?
- setting timing
- Insight valve adjustment specs needed.
- high compression heads N/A
- TODA cams
- Forged vs. cast
- Best plug gap when using MSD 6a Ig & Coil?
- cc's for a stock 95 GSR?
- rear hub problem
- 5 Zigen Header
- Just lowered my car - hearing a 'thud.'
- B&M Trick shift Synthetic ATF
- pls visit our site..www.above5500rpm.cjb.net
- 1997 Honda Civic Si
- rear hub assembly installation
- clutch/tranny compatability question
- Integra Intake Manifold question
- Please look here! Anyone have valve adjustment specs on crower???
- EF rack and pinion help
- Help! Need any info on how or where to smog a car w/ jdm b16 swap in CA.
- ITR intake manifold swap on a b16
- Blew another axle, wheres the best place for a stronger axle?
- Cam gear question/ need help
- Supercharger
- electric help how to check for continuity?
- Running Rich, car dies
- 3 stage vtec???
- Desktop Dyno
- heyyyyy yoooooou guys?
- Honda OEM Oil Filter Part Number
- B18a1 Rod Bolt Specs
- reading tranny ratios
- anyone have specs from their EF alignment?
- HELP please!! car won't start! read more-------->
- Why does my ehaust sound "airy" when I accelerate??
- Engine builders I need camshaft help !
