Tie rod or steering rack?
Old Nov 28, 2003 | 12:52 AM
suckawillis's Avatar
Default Tie rod or steering rack?
ok- when i grab my tie rod and shake it, it shakes where it connects to the rack. do i need to replace the rod or the rack? any help would be great. thanks
Old Nov 28, 2003 | 03:42 PM
pherbag's Avatar
Default Re: Tie rod or steering rack? (suckawillis)
Sounds like the inner tie-rod is worn. Lisle makes a tool to remove inner tie-rods, NAPA or Pepboys should have the tool. Autozone may even have it as a loaner tool.
Remove the outer t-r from the inner t-r, then remove the boot to access the location to unscrew the inner t-r. Be sure to count how many turns it takes to get the outer t-r off, this way the toe setting should be close to spec when you put everything back together. Get 4 wheel alignment.
Old Nov 28, 2003 | 06:11 PM
doublejz's Avatar
Default Re: Tie rod or steering rack? (pherbag)
bah, i change them with pipe wrenches no need for a special tool. I probably changed about 5 with a pipe wrench.
relentlesstech
10
Feb 12, 2025 09:24 PM
Hcivic88
48
Jun 5, 2017 03:07 PM
keith1993may
Mar 7, 2013 02:34 PM
tacosandbeans
Sep 23, 2010 08:23 PM
qazaq
Apr 20, 2008 03:26 PM
