View Full Version : Tech / Misc
- HELP...having tranny problems in my ITR.....
- Comptech header ?
- 2.5" Collector Flange?
- Axle question??
- reverse affects engine idle??WTF!
- B20Z......what car did this come in???
- "Poor man's stroker kit" for a D16...
- Cam Gear Timing
- Crower cams
- P28 ECU Codes/ 96 LS Helms Are the Codes the Same?
- Swap and suspension
- Help me with the All-motor Mini-Me
- zc water pump
- h22 power estimate
- 93 delsol, rear lca bolts broken, sway bar install.
- ZC Header choices What have you bought and are you happy?
- aftermarket piston ring. Which ones to get?
- LS/Vtec Check Engine Light/1500 Idle
- teg camber kit on a 92 cx
- AN-R, Hytech, SMSP Which is better?
- Exhaust problems
- How do i polish my header?????????????????
- Is there a difference between an automatic distributor and a 5 speed?
- trial member
- CEL code 67?? what does this mean??
- oil pressure gauge? the sender
- leaning out what FP psi b16a
- Traction question help!!!!! please read
- .afer the swap???
- what is up with this
- GE vtec conv. kit ..help
- Whos The Best Tuner In The Tristate Area With Experience With The AEM EMS
- whatsup with apex n1 catback or just univ. muffler??? HELP!
- OBDII and straight pipes
- Idle problem with b16a
- Will a LS valve cover fit a gsr head????
- I need some help with my b16a swap
- I need some info/or help in the seattle area itr tb/mani install
- How bad is this body damage?
- o2 sensor question.
- help please
- what the hell is this? (ls block)
- throttle rotor???
- Determining intake...
- Coolant Sensor
- way to tell cc of RC injectors?
- does anyone have the toda header?
- Leak from shift linkage boot ?
- ITR lost motion assablies
- D16y7 SOHC vtec head swap
- ** -- Can we use OIL PRESSURE gauge to monitor FUEL PRESSURE -- **
- Help with import/sport compact car chassis code...
- will this fit???
- need transmission help asap
- Apexi S-AFC
- b16 in crx hf need help
- Ground Controls new suspension part
- What Else Do I Need to Complete My Block????
- Made Fast Idle Valve Gasket, idle still a little high = 1100-1400RPMs
- Best way to hook up IAB in 92-95 civics??
- civic hatch tailight install
- is it worth putting ctr pistons in my b18b
- Replaced intake temperature sensor, and still throwing a code?!
- Not sure where this belongs??
- need some torque specs.. help!
- What rpm do stock Y8 valves float???(searched)
- Monarch Trading Company
- valve adjustment, need answer ASAP thanks
- How to adjust torsion bar
- AEM v2 CAI or Iceman cai?
- hondata s200 vs. v-afc
- 99 civic LX ecu code
- Best spring combo with Tokico 5 ways
- Weird ECU code??
- Code 43 (Fuel Supply System defective or malfunctioning fuel supply system)
- Apex`i N1 Exhaust
- clicking sound from rear of the car
- exhaust/cat question
- eclipse compression?
- what size fuel pump for this setup
- Car stalling when on 1/4 tank???
- tell me what you think about this b16 setup
- No power to ECU on swap
- 92-93 Integra LS Distributor work with P75 ECU for B20 Swap?
- Anyone live in SE Pennsylvania, NJ, DE, MD area who can swap out retainers for me?
- Valve Adjustment
- Coolant temp gauge went down to bottom when crusing
- Team UG Transmission Repair...
- Will a D16Z6 Map Sensor Run my B20B4?
- head gasket? HELP !!
- 2.25 drop.....to low for H22/EG?
- engine being at idle does it do damage?
- stock spring rates Honda Civic
- How to tell TODA cams from other cams?
- ls crank in a b18c block?
- post all motor b18a/b dyno plots
- Damn it, I forgot which side the thermo. gasket goes on!!!
- obd0 > obd1 distibutor
- 92 civic steering wheel on 96 civic
- OIL & Tranny cooler help
- Suspension question
- Lazy o2 sensor
- Helms Manual Question
- Valve seals for sohc vtec? (difficulty)
- help me .... shock install and having issues
- JDM F22B DOHC what head gasket?
- white smoke ?
- need help.. front wheel bearing
- car wont rev up
- need some injector help
- Need help with an N/A setup!!! IDEAS
- JRSC question for 99-00 SI please read!!
- itb's question
- what size slicks
- PR3 and PR4 Q's
- Caliper rebuild question
- crv and 2000 si mounts the same??????
- Clutch problem
- honda factory 4.785 final drive kit
- engine will not start?
- Ls/Vtec swap???
- Adj. cam gears and detonation
- how to:bypass Vtec oil pressure switch
- Skunk2 Powerbands?
- H22A Crank Timing Problem....help asap
- auto h22a ecu convert to manual
- wiring parts
- skunk 2 stage 2 cams
- all motor d series poll...
- egt probe?
- brake kit question
- valve adjustment = cause of misfiring cylinders?
- ARP Rod Bolts Q
- B20 crank.....
- Compression Check questions. Check out my numbers? JDM GSR b18c
- Cleaning K&N filters...
- Stock B17 specs????
- where to buy DIY exhaust piping...
- Code 0 PR3 OBD0 ECU
- Who can chip my auto p28 to manual?
- crank pulley bolt WON'T BUDGE
- Is it worth converting to carbs?
- fuel mixture leaning out at part throttle: b16a1 JRSC AEM EMS
- B16A rod bearings where?
- 1st gen Odyssey CEL
- what is c32a?
- transmission kit
- zc vtec
- Apexi Rev/Speed Meter
- bmw handling - relocated
- D16Y5 help
- wiring IAB
- injectors
- Bigger inlet/outlet muffler to remove/decrease raspiness
- Okay, Final Post about headgasket to confirm. With Pics!!
- HELP! have a leaking head gasket. What price am i looking at to fix it!
- Worth the money?
- how to remove immobilizer
- Grounding Knock Sensor on B18C
- transmission help
- I need Tail Light gaskets...
- A/F.....Signal Wire on ECU Help
- wondering about new part?!?
- d16y7 valve train.....
- engine swap...
- Help! CAR won't start
- where can i find codes??
- HELP got a major problem with my car
- problem with installation of type r replica strut on my ls...
- Cam timing.
- HELP w/ oil leaking from headgasket!!
- portflow valve springs
- problem with installation of strut on my LS.
- About Azenis??????
- how do u change the power distrib. of an awd/4wd car?
- Is this a sign my headgasket it totally gone?
- recommend me some lightweight rotors
- ECU Problems!
- help with my gsr swap
- Skunk2 exhaust
- S1 tranny axles in a 91 SI Civic?
- OIL LEak!!!
- ls vtec piston
- Vacum Line
- seatbelt doesn't reel back in?
- ? toda spec b and a
- Need Help Fixing a Dent On My Civic =(
- LS/Vtec..Good or not worth it?
- Toda Interview
- apex garage sale in orange county
- Front Bumper
- !!!!!!!!!!!! HELP !!!!!!!!!!!!!!
- cel code 3 showed up today
- new Konis leaking shock oil on DC5
- Need switched power...
- Header?
- Need Options....Bent Valve
- fast idle thermo valve necessary? please help asap
- seat rails
- b series rod bearing size's
- Help on 90 Civic DX B16 swap
- Good Web Sites for b20 swap info...???
- Smog Ref.......
- How to identify a JDM GSR block
- Somthing I learned today about GSR cams vs Type R
- Doing a b20 swap into my EG. Need a few double checks...
- ECU Upgrade? PR3
- Integra wheel sensor help!!!
- Stainless Steel Mesh Air Filters (Blitz SUS Style)
- Help, just installed motor...
- where can i buy 14mm-17mm bolts besides dealer
- Weird ECU chip problem
- OT: songs..
- Vtec Oil pressure sensor Location....need help quick!
- check engine light
- gsr block
- how much does a stock b18c1 block weigh???
- Motor gunk and oil deposits...from a JDM motor
- what pitch alloys
- 92 EX help
- idle adjustment screw
- hondata
- car bogging under heavy throttle
- my exhaust hits my bumper...
- ZC Guru`s I need you advice
- need help with some equations?
- b20 w/ B16 crank
- throwing code 43
- HX-EX help (again)
- Testpipe info on a JDM DC 4-1 header
- type R intake manifold vs aftermarket
- where does a newb start?
- b16 with 75-100 shot
- Do 5zigen fireball exhaust have a long tip like the N1 or a shorter tip??
- help i really need it
- need help with auto to 5 speed/stick conversion!!!!
- What are Your thoughts on Nitrous????
- Apex'i World Sport vs. Greddy Sp vs. RS*R Invidia vs. Tanabe Super Hyper Med
- Oil Pressure/Knock on startup question
- 2nd exhaust ticket.................
- car making terrible sound..what could be the problem
- O-ringed and 84.5mm pistons i need help???
- Gsr tranny for 600bux,is this a deal?
- which head???
- anyone with a helms for 99-00 civic ex
- whats the highest compression I can run on pump gas????
- what cr ratio is this....i cant figure it out on c-speed
- where does the CKF sensor plug into???
- How to change valve springs without compressor?
- Got a Question should I buy this?
