View Full Version : Tech / Misc
- vtec problem
- What tools needed to change front pads
- B18A1 INTO 92 CX HATCH
- Proportioning Valve Differences
- Suspension
- ITR cams indentification... did search
- Need quick help Integra people
- SOHC Vtec will not start after swap
- rev set high but its not my idol setting????
- removing manifold vacuum fittings
- Need to know where to get parts for JDM tranny
- Does this increase horsepower and reduce engine bay heat?
- Reading my bearing codes... First time and im worried. Check em for me
- automatic transmission question
- What gauge wire for inline pump?
- loctite on flywheel bolts?
- can someone with apexi gt exhaust post the pic up for me
- no vtec... oil light is on
- prelude 5th gen problem
- CEL code
- Adj. FPR Question....Length of Spring?
- wiring canister type ignition coil, and distribritor independent of the harness
- ARP head stud question...?
- Flywheel bearing
- how to do a compression test?
- Tokico Illums blown?
- Bubbling coolant w/ cap off and loss of performance? (long)
- GC coilovers and Illum clanking
- A/C Condenser setup on Gen4 Accord
- brake master cylinder hose question
- Mathematically, horsepower and torque should intersect at what RPM?
- Cam Install
- Very low compression/spark plugs smell like fuel, please help.
- B-Series Headwork
- exhaust causing some trouble
- Anyone been to HASport Headquarters?
- wut can i rev to????????
- Any one know how to wire an VAFC2 to a D16y8 motor. I need some help
- Fuel pressure for B20VTEC and stock injectors
- Need a resonator
- blew the diff?
- cel code 41, 65, 73...??!!! car is sputtering....
- car acting wierd and not starting
- Quick question GSR brakes swap
- Installing O2 sensor - will this work?
- Is it safe to cut out my wheel well?
- Installing an o2 Sensor
- Ignition Problems, can doesnt start/has problems starting
- Fluttering/Hesitation
- JDM b16a trani = LSD???
- wierd brake problem? need some tech info!!
- S-Afc
- d16y8 problem
- b17 intake manifold?
- help
- Quick Axel Question
- h22 rc 550 injector problem
- timing retard on an advanced timing chip?
- The How to on Gsr cluster into a civic (95)
- Wiring 99 Ex/Si Doors into 97 DX (SEARCHED)
- Y1 with LSD or stick with the S1 tranny
- question about fuel injector
- Need help with d16z
- suspension?
- No spark on ZC swap in a CRX
- "slippery" front wheel and LSD
- Bushings for control arm
- clutch masters twin disc
- is it my pressure plate or clutch master cylinder
- Type-R Intake manifold Installation Question??
- Type-R i/m swap Question??
- Is bad to run in open loop all the time?
- Removing ABS, How to? on a GSR
- New pads and rotors. Brakes smoking!!!!!!!!!
- Correct located for O2 sensor in a custom exhaust?
- Radiator advice?
- PLease help my gauge dont work...
- 1st gear vtec bogs all other gears fine
- Clutch Fluid: Did Search
- best transmission fluid for B16A1??
- Valve cover nut stripped
- Compression test ?
- CAR DONT START!!!!
- Check engine light and OTHER CRAP HELP
- Question about hydralock
- Chicago Area Honda Acura Performance Shops????
- any possible way a clogged cat can cause blow by?
- are tubo coolant lines necesary?
- Tie Rod problem (Need Help Please)
- B16A: advancing timing, octane rating
- Integra Axle nut size on a 90-93 RS PLEASE HELP ME!
- Tire question
- gauge light wiring
- what sohc has a shorter timing belt
- NEED HELP ASAP
- whats the best way to break in my rebuilt motor??
- Crankshaft fluctuation sensor problem
- old skool AWD ZC lightweight project!! need help
- Need Help with Bleeding Brakes
- Ecu red lining at 7,700 rpm???
- Will a bad O2 sensor make the car idle rough??
- ghettodyne on a pr3?
- Which transmission fluid?
- faster ET's w/ Aerodynamics? My lil writeup...
- exhuast smoke color
- sparco sprint vs sparco speed
- ACT flywheel or Fidanza??? need help quick, gotta buy tomorrow
- Stick Welding
- anyone compared a g-tech pro with a true dyno test
- type r cams questions
- wierd headlight question
- engine light comming on
- Need some B series Bore sizes
- Brake pad question, what do most prefer for the street...
- intake boot color change? spray paint?
- assemblying engine, what lube to use?
- auxiliary vacuum...
- 5 lug conversion on EK 96-99 civic
- Help, can't get EX to start
- Falken Azenis tires
- blue smoke every now and then.
- Darton Sleeves/ H22/ Any installers in Louisiana Area?
- civic kyb agx owners
- B series tranny cases the same?
- please some I need help
- possible leaky headgasket
- Any experience with Jimfab motor mounts?
- Toe question
- Endyn girdle, anyone heard anything about it?
- Radiator as oil cooler
- Are B-series Underdrive Pulleys Interchangeable?
- Poor spark after swap.
- Attention all hondata users or people looking into it
- The best strut/sway bar setup?
- Stock tach needle jumps/bouces at idle and at high RPM?
- exhaust manifold burned through my ac line!!!
- jerky vtec chang over???
- Need ur help and suggestions
- bLOCK SAVER?
- how to turn off service reminder for 2003 honda civic 1.6l 16v engine
- JUN camshafts- help!
- fuel problems PLEASE HELP!
- Taking about Axels to swap 32mm hub ends with 36mm hub ends, What tools/tips/tricks will I need to d
- LS/VTEC or GSR or Type R
- Need Help, can't start the motor!
- Need pics of a GSR throtle body
- how can i make this engine fit my car....¿
- Need Help On VAFC
- Bought Used Civic Hatchback, failed smog, who should pay? Me or Previous owner?
- 97 Civic engine swap 2 H22A4 2000Prelude engines....But.....Look what i got from OSAKAJDMMOTORS
- OBD HELP!
- motor build up for turbo/n20?
- vx ecu w/ si head
- ground control questions
- Are Crankshaft replacements common for high HP engines?
- frustration.... no vtec when warm
- Oil Change
- Sleeving, help me understand
- need help urgent ...tranny problems PLZ READ
- FITV? How do i run the coolant lines!?!? HELP!
- Help!! How do you install an apex avc-r boost controller
- lug stud
- crx with b16
- How to calibrate?
- ???'s on an 88 Civic HB HF
- NO Power w/ctr cams
- tranny fluid
- what does code 92 mean?
- help with adjusting skunk2 cam sproket
- spark plugs
- Need help with Hondata misfire.
- identify cams?
- car feels like it's pushing towards me when i drive
- Snap ring
- Saving Gas
- Engine mounts
- Removing heat?
- Need to know if I can just buy an AEM short ram for my mini me
- check engine light
- Car stumbles (like a rev limiter) at high RPM's?
- wich crank has the best rod stroke ?
- how do i install a air/fuel meter from autometer?
- Helix Power Tower
- Type R Clutch vs. Aftermarket Clutches
- 96+ drum to disk ?? did search!!
- shield for dc jdm 4-1 header?
- pleez help!?!
- Accel DFI idle quality / start-up?
- Company names... is this all they are?
- copper vs platinum vs irridium
- suspension...
- jdm S1 tranny
- MSD start retard module
- engine swap
- Is it my alignment or is it worse?
- What are some signs of worn out wheel bearings
- Im so frustrated
- Starting problem
- does cam gears has to be set at 0 to do valve adjustment?
- small popping noise
- black soot, coming from exhaust
- Identifying year of B18c
- Is Type-R Manifold worth it???
- adjusting ebrake from the caliper
- resistor box HELP
- (HELP) SH to base tranny swap ...who's done it??? what parts r required
- NOS solenoid#16020 junk????
- Question for electronics wizards on the Bosch relay
- running RICH
- RPS Products
- Pipe Thread Size of MSD Inline Fuel Pump
- Install help: exhaust on s2000
- Can a chip made for P75 OBDI go into a PR4 OBDI ECU?
- greddy e-01 turbo controler?
- Please help! civic does not run like civic should on low rpm
- Gear popping out of 5th while cruising on highway??
- shfiting 4th and 5th gears grind
- HELP!! What is a fuel pressure damper?
- Need pin outs for a p75 obd1 ecu ASAP
- power steering.
- Need Help! Anyone Know any places that does performance upgrades?
- How to differentiate JDM vs USDM cable tranny....
- CVT tranny? it this correct? Help!!
- ecu reccomendations
- Relocation of EVAP sensor in a hatch?
- Help: Fuel issues with mild setup, confused.
- TRD's Engine Break-In!
- glasspack?
- knock sensor questions
- cam help
- wat is vtec...sorry for asking such a dumb question in advance!!!
- hey.. for those who knows bout teins
- car wont go in reverse?
- Motor liquids (octane boost, oil cleaning stuff blah blha blah)
- Cant start the car after swap!?
- resistor box wiring
- Lower profile tires for 2003 Accord Coupe automatic
- installed vafc..... sh*t bucks like mad y0!
- ignition coil problems
- Car reluctant to start! Then idles rough until warm.
- D15B1 vs. D15B2
- (skunks2 Camber kit) How Low Was Your Car??
- GSR makes funny noise after road racing
- h22 lsd... where to get it... repost. anyone?
- New Drag Car Project underway
- need vacuum line diagram
- Eg Kyb's on a EK
- my d16z6 sputters...what should i do?
- Quick question
- Cam/Distributor Timing
