View Full Version : Tech / Misc
- removing yellow part of lights?
- Anyone knows where I can shop online "Pistons for H22A Eng."
- my check engine light goes on & off
- Where to get wheel spacers?
- B16a idling probs(honda experts)
- how do i stop the my brakes from squeaking?
- how to remove my sterring wheel on my 99 hb
- Quick ECU Compatiblity Question
- cold air intake
- fuel filter for 98 accord 4 cyl.
- p13 ecu ???
- AEM CAI vs stock air box as sound deadeners?
- Help. Scewed up and need color codes for wires to EACV & Intake air temp sensors
- axles
- prelude\accord tranny?
- Oil leak redux - there's oil in the distributor.
- 95 Civic EX rear disc conversion; what parts do I need???
- Is My Car Repairable????????????
- Passive Rear Wheel Steering
- cx swap help
- need help with install of cusco catch can
- LSD Lifespan
- ARP head bolts...
- Cooling Fan
- installing OEM Fogs
- Fixing gears...
- weird - engine cutting out at 5300rpm?!?!
- Clutch trouble - not honda specific but need some advice
- has anyone ever built a remote pager for their car alarm?
- Cheap speed?
- TDC.. crankshaft
- First and Reverse, Sticky???
- I need a hardcore tech guy with this one...
- b20b with turbo. How good are you guys??
- B16a Engine problems-Help plz
- Cross drilled & slotted rotors, which one is which?
- z10 block gridle on b18b w/LS head?
- 9006 D2S 6000K Philips HID arrived....dont know how to install...HELP!
- B16 buildup problems (long)
- honda spark plug wire construction
- Polyeurathane Bushings...
- Necessities for a full race car
- Question about pistons, sleeving, etc.
- need help
- headgasket rivets.
- GSR/SI/ITR tranny on LS
- Dyno tuners in Central Florida?
- number of bearings needed.
- supercharger for B20 set-up
- Safe Turbo for stock internal engine civic?
- Quiet Exhaust
- Fuel pressure regulartor steeings:
- Coilover Poll ( battle of the stiffest )
- Changing o2 sensor on b18b1, help!
- Small allowable rim on ITR
- Where can I BUY a new TPS- any suppliers?
- From F22B1 to an H22A:
- itr cw rims
- tools for a camber kit
- Is my R too low???
- why my car hesitates??
- del Sol in the 12's?
- 4 point harness
- Gauges recommended for Nitrous usage?
- slick suggestions
- Feel's Flywheel?
- Firing order?
- motor build up what do you think it will hit and what do you think of the parts iam using?
- Oh yeah, one more for the goodguys!!!
- Ferrea B16A2 & B18C5 Valves
- Short Clutch?
- How difficult is this?
- Clutch type for YS1 tranny.
- Auto --> Manual...
- Ok..how is this for weird...I changed my oil type and...
- OT:Wiring the F***** horn with a sparco wheels
- Code 23 (Knock code)
- fuel regulator & CAI
- would bad fuel pressure reg. cause irregular idle?
- Questions on custom catbacks
- camber kit for 5 lug conv
- is it possible to put a b18c1 crank in a b16 block?
- are Del Sol Vtec axles and 99-00 Si axles 32mm like the GSR?
- Which wire to tap for Air/Fuel gauge?
- Difference between ECU's?
- Questions about an ALL MOTOR/JUN Setup...
- whats the diff from Ls block to a b18c1 block
- harness help!!!
- clutch.......
- bad idea to race one night with grind on 2-3 syncronizer?
- Test Pipe......
- weird stuff with my motor
- APEX i' EL gauges
- 2 QUESTIONS....PLEASE HELP....NEEDS ADVICE
- compression test on motor out of car
- Installed MSD Ignition and Coil. Hearing a clicking noise.
- AHH!!! Wrong oil!?!
- Possible header leak
- B16a stroke and rod length?
- Parts list for rebuilding b18b?
- Need a corssmember for my EG
- remanufactured distributors...
- dsm injector question for sgt?
- 1/4 trap speeds
- 90 civic hatchback 93 Integra suspension
- CTR Piston question. 13 Compression ratio?
- timing question
- Modifications required to fit block griddle on b18b?
- B16A1 Fuel and timing maps?
- skunk and skunk2 springs??
- Goin turbo on TYPE-R engine..
- 02 sensor problem......
- Heat Resistant???
- SiR Front Sway Bar mms?
- sign of bad steering rack?
- What happens when your timing belt skips
- help me, idle
- ctr cam question
- 90k mile tuneup
- Stainless Steal Lines, do they improve stopping with brake systems with ABS?
- Motor brake in question ***
- MSD Ignition box and coil mounting location?
- Whats the diff. between cx and z6 flywheel
- Irratic idle?
- synthetic blend worth it?
- My '94 Civic Ex is sittin crooked
- Built Motor, Timing belt problem?
- knocking noise after strut/coilover install??
- 1 question...
- GE 86mm Sleeves thoughts? 2.1L B18C1 All motor setup
- How hard to change the oil pan gasket..
- battery tie-dowm
- 93 auto EG conversion to 2000 d16y7 5spd
- umm, is a teg wheel smaller than a sol wheel???
- Auto Trans Fluid Change?
- Ls Vtec
- valve adjustment
- Possible exhaust leak? What does it sound like?
- Nightmare belts?
- Help with broken shift linkage stablizer mount on tranny
- D16Y8 ?
- Another swap woe... *cry*
- Cold NGK Plugs
- Spark plugs in a newly bought B16a 1 gen ???? what is up ???
- How hard hitting are the JG VTEC cam ( compared to JUN3 & Toda C ) ?
- CABLE TRANNY PROBLEMS
- type r suspension on eg
- i think i firured it out
- suspension HELP!! koni/h&r combo
- ITR Front Sway Bar In A Civic
- Need help on how to install a transmission
- need help asap dame check engine light
- Injector flow rates (Old Peak & Hold)
- jdm type r steering wheel smaller than del sol wheel???
- What entails rebuilding a tranny?
- Differences in B-Series turbo manifolds?
- OT: other car forums
- Final Drive
- Koni REds and EIbach SPortlines (for a 96 Teg)
- running my car n/a need advise on parts
- A/C problem!!!!help!!!
- Auto To Manual
- radiator Busted
- what should i expect to pay for this....
- ITR LSD fit in a 99-00 Si B16 tranny?
- anyone running individual trottle bodies on the street????
- new steering wheel install...please help
- new rims... how much will I notice the lighter weight
- What to get now........
- can anything bad happen if....
- 99-00 Si final drive
- Anyone ever hear of a "Freeze Code" on an OBD2 GS-R?
- NOS in 5th for a ITR
- Which wheels
- Won't shift into 5th or Reverse
- Will My Engine Run Better Or Worse If I Clean Carbon Deposits?
- just got motor rebuilt and it is smoking terribly above 4500k?
- Lower Timing Belt Cover...
- P28 ecu questions
- Full coilovers??
- Breaking in an axle?
- 180,000 miles compression check??
- how to repin ecu plugs
- crower 63402 cams maX cam gear ajustment
- Flywheel bolt size?
- R1 Spectrum Series Gauges, Cusco, and SARD question
- How do I....
- B18C1 oil leak - any suggestions before I tear the car apart?
- WTF! Did my motor seized?
- Fix-A-Flat VS. Spare Tire
- OBD 0 pinouts
- Ported head, do I need to cut gaskets to fit
- IGNITION COIL MODULE
- So I blew up my D16A6 last night..
- Should i get MSD?
- ummm, my jdm b16 crosses over at 5800 rpms!!! Help please!
- DFW Ennis Test and Tune....
- AEM CAI during Canadian winter
- grinding going into 3rd gear only at 5k rpm and higher?!
- Ripped boot...need help/advice.
- Car is sluggish at high RPM's...WTF?!! help!
- these are my plans, feedback please :/
- PLEASE HELP!!, 00 Civic Si problem
- tranny whine/noise???please god someone figure this out lol
- NEED HELP QUICK
- I need a shop that can replace my rack and pinion ASAP (so cal)
- Adjusting Valves
- CAN I JUST SAY???? EVERYONE READ!!!!
- 2,2.25,2.5 inch exaust what would work best?
- code ?..?
- LS/VTEC: Wiring 94 Integra LS distributor to '00 Civic EX wiring harness *help?*
- it never seems to end!!! need more help!!! tach gone crazy, fuel starvation
- how do i know if it's time to replace any of the injectors?
- what motor is this from
- stock cat
- what is a d16a6
- 125,600 miles Compression Test Surprise!?
- Car broke down....WTF
- b16a 1/2 question fot the Motor experts
- ITR valvesprings and ZEX/Comp cams
- Anyone heard of this?
- which cam for D16Z6??
- When do YOU check your oil level?.........
- cam theory... a discussion
- WHAT ECU PINS........
- Does a 4-puck hold more power than a 6-puck?
- honda civic exaust what size??
- Websites for resleevers?
- SEVERE tranny problems, grinding noise when clutch released
- help tranny/clutch asap
- How do coil overs work?
- 10w30 instead of 5w30 in Integra, any problems?
- 12.5:1 too much for daily driver??
- crx afterburner valve
- Which brand/type of timing gun to purchase???
- IT RUNS< but i need more help still!!!
- b16a cams and b18c cams?
- SARD and R1 homepages?
- ? For those that have used Eagle rods
- computer techs
- prelude motor in accord
- ITR springs into 2k Civic Si/SiR safe?
- D series Tech
- removing LS head question
- how to install coilovers on honda civic ex coupe.....
- Any difference?
- How much hp from a stock ls/vtec
- might be my new set up....
