View Full Version : Tech / Misc
- Cylinder burn mark and scratches
- Does my oil pressure sound low
- Theory True or False.. NGK = Best for Hondas
- obd1 sohc ZC into a 99 ex auto can i use the obd2 ecu
- OBD2B to OBD1 PROBLEMS HELP!!!!!!!!!
- Is This Possible ?
- b18C (GSR) Into a 1997 Civic (EK)
- 2 questions can someone answer its about a throttle body hose. pics inside
- what actually breaks when an axle breaks
- hub bearing? or axle?
- took head off looking for any piston damage or valves, everything looks okay....
- shift linkage help
- kteller 3 inch exhaust has a slip joint just use u bolts?
- need so help with transmission disassembly
- CAR WORKING LEAN NEEd of help
- PROBLEMS WITH MSD (HELP)
- 19 posts [100%]
Orange County
11-24-2004
Brown/Black Wire? Where does it connect to?
- electrical problem needed solved
- b16 b18
- NOOBIE ENGINE BUILD IN PROGRESS WRITE UP
- early rev limit...........
- Aeromotive FPR pics?
- Starting problems
- Fuel system parts re-assemble
- 7th gen Civic Gear Ratios
- CROWER stock idle cams worth the extra cash ?
- how to drop power from 14.4v to .2-2.2v
- i need to replace a wire in the wire clip!!!!!!!!!!!!!
- Why is VTEC boggin down????
- Wondering about the est. hp this setup makes?
- Speed Sensor Question (1986 Accord with LS/vtec)
- B18A1 swap into 1990 civic
- ELD(electric load detector)
- feed my b20 more fuel!!!
- Brake Caliper Rebuild Question - Help Needed!
- What Final drives for d series?? Which u use?
- questions about d15b po8 in 97 hatch (ecu, intake manifold ect)
- Where can i get a 1.1 radiator cap for a KOYO????
- OBD2a and OBD2b ecu pinouts the same?
- hasport mount
- 02 axle compatible with 05?
- b20 gains...........???
- For all you Honda Savvy...will this work?...
- How do you RESET your ECU????
- Need help with LC-1 wideband hookup
- stupid question
- Vtec engagement no longer working....I'm goin nutz
- Spec II
- ls head compared to b20 head?
- Do I keep it or not?
- AFC Hack Question
- does h22a1 head fit on h22a4 block
- What is the stock psi for integra rad cap???
- vafc 2 qustion
- VTEC HEAD SPECS ?????
- installing flywheel
- IAC Question?
- Picture of 99 Si driverside mount w/ Prothane Insert???
- Rotary Vale System
- Buddy Club Vcon Vtec Controller
- Computer program to predict horsepower
- Bumper Removal
- V-tech no go?!?!?!
- chassie codes
- arp rod bolt install??
- Will This Battery Have Enough Juice to Start Up My Car?
- the BEST Ecu can i use in sohc vtec engines?
- installing wiring harness
- Is Ls/vtec really what it is...
- P7H ecu, any idea which Honda model it came from?
- idle problem
- Anyone with an Auterra scanner please help.
- does obd I ecu support atts?
- CAR IS NOT WARMING UP?! THERMOSTAT PROBLEM? CHICAGO AREA HELP!!!!
- NEED TRANS HELP PLEASE!!!
- OBD2 to OBD0 conversion
- Upgrade fuel pump...which one
- will a b16sir2 ignitor work on a obd2 gsr?
- Anyone ever had a Rotary Type (99-00 D16y7, 3 wire) IACV go bad on them?
- TraVEL THE WORLD TOO SEE EXTREME VEHICLES POTENTIAL $$
- power locks not working!!!!!!!!!!!!!!!!!!!!!!!!!!
- clutch
- Chirping noise from timing belt area.
- Clutch engagement issue...
- Important: which program to tune OBD0 with ITBs setup?? HELP PLS
- Making Funny Noises by the frame
- exhaust smoke.....???
- O2 or not O2?
- Bigger Radiator Question???????????????????
- What's a good shop in so cal to do automatic to manual swap.?
- Would running 91 octane on a k20a3 (87 octane) for three years cause CAT to go bad?
- Power fc zero ign timing !?!
- sport compact racing simulation
- vtec malfunction on gsr???
- Converting a p06 ecu to vtec?
- SOHC HELP! d16z6 intake manifold on y7, surging idle, no cel
- Bearing sizing after Align bore ? engine builders chime in.
- wack engine idle
- brake booster linkage adjustment
- What is the right size of Front/Rear EG6 Emblem?
- Head Gasket Poll
- Long stroke vs short stroke
- Are crank shafts balanced with or without the pulley??
- Wider profile on standard Honda 91 civic DX
- OBD 1 vs. OBD 2
- code 22 -vtec pressure switch
- H22A HEAD H22A4 BLOCK
- Help with ECU Adapter please....
- Question about overboring a motor and determing displacement?
- HELP! Nedd help isolating the problem (fuel I think).
- Help.
- Need new passenger mount in Eg. How do I install?
- Expected life of Automatic Transmission in Civic's
- Noise sounds like TRANNY!
- Couple Catch Can Questions...
- what kind of rings do i use
- Whats this?
- What Universal Fitting Muffler for a K20A EG Hatch???
- Parts for the moroso catch can set up (yeah I searched)
- Random miss
- i need a header soon
- DIY CATCH CAN *PICS* Now How Do I *LEGALLY* Run Everything
- JDM ECU help
- starting problems PLEASE HELP
- vafc - sensor check voltages off after swap??? What could be my problem???
- No Spark help DIZZY???
- Main Relay Problem: How do I check for continuity between terminals?
- Ignition Timing and Rpm?
- mini-me arp headbolts?
- Gunk Engine Flush
- I Need An ECU upgrade
- Tranny / Transmission Gurus!!! (and self-proclaimed gurus)
- vafc cant initialize?
- SOHC VTec head oiling
- Good ECU not putting out correct Map Sensor Voltage (Please Help)
- transmission help!!!
- idle surge!!! need help
- Trial User
- At what point
- My SiR II B16A idles at 2500 rpm how do i adjust it???
- Air coming out of my master cylinder/ brake booster
- strange random bogging low end and weak vtec
- Noise in Rebuilt tranny B18C1
- Any one have this set up?
- SOHC / D-Series tranny transmission w/ LSD...
- burning oil, help!
- gas milage
- Need Websites for great quality parts plz
- Helical (planetary) v. Spur Gears
- exhaust
- de-immobiliser p9k
- vafc
- what LSD to put into my GSR tranny?
- F20B into EK civic
- CRANKSHAFT SENSOR!!!
- Turbo A/R and sizes wtf
- Auto Trans problem.!!customerscar!!
- Ignition management
- need some knowledge from tranny experts
- What causes an engine to run rich?
- no power...
- B18 swap to 94 Civic Vacuum Setup
- Ek Cluster help!!
- building all motor,where can i get some high cr pistons and which ones should i get
- Which setup to go with?
- _-_-_-_Tranny making a funny chatter sound, but only in 1st??? Any clues?_-_-_-_
- spoon oil pump or type-r oil pump?
- help me identify this rear engine mount bracket
- valve clearance?
- Are D-series and B-series FPRs the Same?
- failed smog, look!!!
- HELP! is this tranny case useable?
- Honda/Acura proformance shop on LI NY
- need help w/2000 civic
- melted 2 iacv's help please
- CTR piston's and 404 cams
- 4 wire O2 sensor??
- Valve Adjustment help
- how does LSD work
- need help on some codes...
- help please problem with rear disc conversion on my 90 crx
- 93 civic si power problem
- ? about engine bearings.
- necesito ayuda ecu p28
- STR Throttle body, Anyone have probs?
- TDC sensor
- need help with parasitic load test
- .... altenator seized..... how to fix ???
- HELP: SETTING VAFC
- VAFC problem
- Craftsmen brake bleed vacuum pump?
- BREAST! Squealing from timing belt area
- P28 AT ECU with JP17/18 mods throwing CODE 19
- What Pistons?
- burnin rich
- temp. problem...temp gauge needle bouncing up and down..
- bent valves? car sounds like a subaru
- twin disc
- Brake pad question
- wiring? 89 dx crx
- Clutch Change
- 92-95 Civic engine question
- ** LS/Vtec Questions ** Dowels, studs, etc
- Hondata S300 major bugs
- Would a chipped CRANK PULLEY cause vibration at high rpm?
- Identify clutch?
- tranny play?? is this normal what are some tranny inspection methods???
- Advantage Of Individual ........can't think of what it's called
- Is it possible to use a b18 block when the complete motor was under water?
- vafc code 3 cel, obd0 to obd1, map sensor
- serious problem with car (bad idle... low vacuum, car dies)
- low comp all motor...
- Going from Turbo To All Motor
- code 9 help
- How to pull a Motor.
- Removing Heater Unit.....Need Advice!
- OBD2 oil pump iwth CKF?
- Need Help wiring a PLX-500 Wideband O2
- help with wiring!98 motor into 2000 car swap!
- HELP: how many teeth?!
- is it possible? h23 block with h22 head
- just put my crx si on the bottle (questions on setup)
- Horrible CRX problems
- Knocking from Cylinder Head
- H22a w/Eagle Rods, Machining?
- PLEASE CHECK THIS OUT!!!
- need sugestions , fixed back buckets
- hard time puttin in reverse n reverse does not want to come out..
- ABS removal question
- need help b16 problems!
- clutch bleed mystery
- Alternator / wiring problem?
- Need help taking off passenger side airbag...for a DC2
- weird transmission noise
- Car is drivable w/ messed up tranny bearings.will it leave me stranded eventual..
- myth of fact?
- Why can't anyone help me?
- LMA Installation Q
- Built Engine Starting Problems
- b18a1 with a hydro tranny possible
- Fuel Filter and Fuel Rail Thread Pitch
- Problems
- Need help identifying parts for Ls 5th gear swap
- Where do you buy your forged parts?
- Idle problems - B16A - 2000+ rpm - WTF?
- B18C1 alternator belt too wide??!!
- enigne swap from hell...
- oil over fill now smoke
- P06 with Hondata S200??Help someone...
- mutant head?
