View Full Version : Tech / Misc
- VTEC will not engage on my B16B ... Help!
- motor will not rev past 3500 rpms?
- L3 transmission problem
- Helms Manual Owners: Wiring diagram?'s
- 92 EX hesitation
- good place to buy ECU's?
- True compression of a mini-me
- Osaka Motors
- what axle do i need in a 91 crx hf with a 90 jdm b16 swap in it. need help asap
- cant separate front upper control arm from knuckle
- Radiator Fan
- Failed emissions - high NoX
- Changing my clutch/flywheel this weekend, what else to change?
- Comptech Sport Springs vs. Eibach Pro Kit
- brake swap & lines
- Recommendations for a full catback exhaust system for a 98 lx sedan?
- Trying to learn about cars.......
- Blown CV joint on a 93 Si
- DC SI VS ITR 4-1 Header
- 97 Civic EX vibrating/knocking...
- Oil around spark plug threads....is this a problem?
- Troubleshooting: Engine Problems
- Throttle cable
- Sensor Issues?? :0
- B16A2 upgrade valvetrain question
- how do i wire crx dx to b16 non obd?
- Someone explain OFFSET to me?
- EF sohc vtec swap advice needed ASAP!
- main relay question??
- Did my clutch break??
- 1989 Civic-Steering left, CAR DIES.
- How do I convert O2 Sensor to 4 wire
- Im building a fully built streetable NA b16...how much power u think?
- causes of leaning out?
- I have a '92 Accord EX. Every now and then, it will not start. Please help.
- Question on compression. Type R pistons in gsr.
- clutch clattering... what is it???
- Are stock integra ls plug wires solid core?
- fumes...?
- i have a hybrid...but dont know what kind of parts i need now...
- B16a2 pistons and rods into a b18a block
- Question about Timing and tuning tips
- Need help choosing the right "stock" magnaflow muffler for my civic...
- ls/vtec questions???????
- Weird sounds coming from engine when its in neutral and idling
- Can somebody please take 10 seconds to asnwer this and save me 10 hours of aggrivation!!!!!! PLEASE
- ... ecu chipping service... who can help me out... p06 to p28 conversion...
- P28 ecu auto to a manual.......
- h23 intake manifold to a f22
- Last stop before the B20 goes in some questions
- quick question about compatability
- D16Y8 or B18B
- Koni AGX for 2nd gen Teg?
- camber specs
- APEXi Catback exhaust!!!
- Let me get this right..
- Welding Tips?
- Sizing bearings without measuring? (B20)
- Seal on tranny where int. shaft goes??!
- Odd click noise comming from rear of the car..
- ok . SI hatch bogs at full throttle.. really making me mad.. help
- "Just Look!!!!Please!!!!"
- HELP w/checkengine light
- Will i be ok with just a chipped ECU or do i need Hondata? (set-up inclosed)
- b16a with no vtec, need help
- ctr pistons in b16a?
- SKUNK 2 intake manifold
- Installing a CAI
- HELP!!! Code 14 on a 91 CRX Si
- OEM civic and integra springs the same????
- Idle and driveability problem
- Broken axle? (searched 7 pages no help)
- car sounds like its running on 1 cylinder.
- How long do new tires need to be broken in?
- MAP sensor info
- What is wrong with the motor? poping sound when I let off the gas... (video inside)
- Crankshaft Fluctuation Sensor (CKF)
- B16A1 - Code 21 questions
- BEST ignition coil for GSR?
- idle problem
- Can the pressure switch on vtec solenoid go bad?
- Where is the PCV in a D16y7?
- What kind of LSD works in an LS cable tranny?
- PP bolts....HELP!!
- Air/fuel tuning question
- ECU question
- autometer egt probe
- Hub question 56k watch out
- Anyone with a cam gear on a D Series?
- CTR cams with JUN valve springs??
- Help diagnose overheating problem
- air bag suspension pros/cons
- toda b cams queston
- hondata question
- Plug Gap B16a??? I forget
- ecu wiring diagrams
- Question
- Removing AC Condenser Fan Bad?!
- Cleaning a disassembled head?
- P 75....? IS that LS?
- ecu problems....
- will stock b20b TB work on a 5 speed car??
- differences between b16/b18c1/b18c5 head???
- Bulbs
- ABS Brake Light Code 4-8
- dam i broke the head of the bolt??? and help
- upgrading cams without valvetrain
- engine code 8 from jdm b20b?
- 12 volt source
- do you need to get a flywheel resurfaced?
- How many lbs. of boost can it hold...
- what do i need for b20 vtec with turbo
- skunk2 intake manifold?? No related topics in search
- tdc sensor? help???!!
- Underdrive pulley sets, what are your thoughts?
- Valve Seals & Retainers
- cfk sensor help
- a20 crank
- Quaif B18C LCS alble to be converted into H22A gearbox ?? or impossible?
- cable to hydraulic conversion
- VAFC Help...
- B16 TB..
- how hard to install a/c in a non-a/c car???
- VAFC Help!!! WTF is going on? Automatic Tranny....
- hood scoops, the true CAI?
- what suspension kit should i go with
- Energy suspension instruction sheet
- short throw shifter question
- whats the worst that can happen
- Is the b16a2 (99-2000 si) ecu obd2 or obd2b?
- Are there any final drive upgrades for b-series cable trannys?
- 92 GSR tranmission
- Loss of power when motor warms up???
- are strut boots supposed to be secured?
- B17 & B16 rod bolts the same?
- SUPER2NER TV??? no show up
- Problems w/ ITR hub swap
- Cam Info on JDM Civic Cams
- Changing Radiator?
- compression test results 94 jdm gsr motor
- ingalls camber kit install question
- LS blocks- Whats the difference in horsepower
- ls/vtec idle problems
- stock plug wires with msd ignition, yea or nay?
- Idle adjustment
- Why isn't my right headlight lighting up?
- Tranny case question
- flywheel and other stuff..take a lil peep
- ripped a boot
- Car stalls as I'm braking to stop?
- can someone explain wat a purge valve does
- Visible Difference Between Intake and Exhaust Valve Springs??
- What is DTC on the ECU?
- Anyone know the size of this throttle body?
- Hi Comp/Lo Boost vs Lo Comp/Hi Boost???
- help!!gsr swap into Ek
- blow by?
- Turbo LS
- not starting when hot....
- Hard shifting in your slightly used/jdm transmission try this.
- Distributors
- s1 compared to ys1????
- Ported LS head with no cam caps????????
- Clutch problem/question
- Any one here using a b series dart block?
- Apexi Vtec AFC probs
- diy cold air box
- all motor b16a, cam and spark plug Q's
- starting problem?
- is it ok to use stock civic radiator w/gsr engine swaped in?
- curious about sensor placement
- Sucking sound from intake when I turn the car off... PPSSHHHHHHHH-VAWHM!
- Autometer (mechanical) oil pressure gauge install?????????
- HELP!!! install went bad...workin on car right now..!!
- What are your best 1/4 mile times
- Question about custom intakes...
- Fuel Pump Questions???
- vtec activation w/ fields vtec controller
- can someone explain how i should install my sidemarkers
- jdm type r transplant in an ls, what do i need?
- how to check if a tranny is still good??
- Ok, WTF is wrong?
- Im sooo lost. Help
- sny. for rebuilt motors????
- Help with code 23!
- Gunk Engine Flush??? anyone use it or know anything about flushing engine?
- Resonator in Intake?
- using a brake parts cleaner
- H22A CNC Ported 188 WHP Dyno Graph
- 89 civic LX will not crank
- oil pick up trayoil pump gasket
- SRS light with non-airbag steering wheel
- LS/VTEC 9.0:1 compression, guesses on HP for turbo calculations?
- does any one no how to replace a window motor
- 89 accord charging problem
- 02 sensor won't fit, should i just hard wire it?
- Ls / Vtec timing - pistons -
- what happen to importreview.com
- valve spring install
- will this intake fit my civic?
- firing order for a h22?
- full catback or muffler???
- Larger Rims and Camber kits??
- Apexi RSM
- 1993 JDM Integra Si - car running sluggish
- will springs from a 94 (or thereabouts) civic fit in a 94 accord ex?
- Hydrolocked B16a, bent rods, ordered R block
- Fuel pressure Reg instruction
- phantom grip lsd
- What are the symptoms of bad main relay?
- Emissions comparison - which is cleaner?
- Why does third gear grind when I shift slow, but...
- B17, no spark, no fuel
- Checking Engine Compression
- fuel management questions
- ???help me............. ecu question
- DOHC timing belt change problems...
- how to install quaife
- i need 2 ac vents
- IS it possible...........
- ITR exhaust?
- b16a pistons or jdm itr pistons for b18c1
- alignment question
- rpms drop at 3000
- Intake manifold to what throttle body?
- Stupid question about 2.5 carsound cat and 2.25 greddy header
- need help engine won't fire
- Valves?!?!?!?
- clocking rings.
- need suspention help!!!!!
- Question for you tech gurus.....
- What head gasket to use on 84mm GE b16 block?
- Good car to learn on.
- Need help with Evap purge valve
- what will my cr be with ctr pistions
- Need help flushing coolent for 94 civic lx.
- building a b18a
- Rocker arm assembly wont come loose.
- anyone who has ever put an h22a4 into an ek civic-->>>
- Yet another LS/Vtec question
- hypothetical question, cut springs on high performance shocks?
- spark plug crossthread????
- Steady led on pr3 ecu
- h22 vs. h23 specs
- Forged or Honda pistons for all motor setup?
- white smoke / inline fuel pump problem
- Final drive ratio for a z6 tranny
- Swapping the block in my stock 00 si for a GSR?
- need trans help!!!
- Best all motor setup?
