View Full Version : Tech / Misc
- mugen twin loop style exhaust from jdmcarboy a legal replacement for a fix-it ticket?
- B18A build
- Low rpm problem-94 honda accord ex
- 4 prong os sensor p61 obd1 wire order
- crankshaft position sensor problem
- fuel pump not kicking in
- Has anyone used a stock ecu to start a lower compression motor?
- short intake question
- eg dash into ef?
- Sleeving in So. California?
- CRANKSHAFT - Quick Easy Cleanup/Polish? Scocthbrite?
- somebody school me on obd1?
- help: quick injector question
- GSR and ITR rods, differances? ordered eagle rods for c5, got them for c1??? Still work??
- Port and Polish Vs Cams & Cam gears
- 1994 acura interga helms service manual
- Bense's B-series transmission write-up page (i don't know where else to put this)
- Help Identifying JG Cylinder Head
- fuel system problem b16A/B18c1
- grinding noise when car is moving........bearings?
- Help OBD1 Coversion
- clutch problems, PLEASE HELP!
- 2006 Si Engine Bay
- B18 cranshaft question?
- How does Honda do Crankshaft Position Sensing
- Will the fuel pump and/or ECU turn on when there is no engine installed?
- Sandwich plate and oil cooler?
- TPS quetsion
- Cylinders 1,2, and 3 not getting any fuel.
- How important is this part of the distributor?
- Hondata Problem Help! please
- need help!!!!!!!!
- turboing a b18
- swaping from a d15 to a b18 in a 1994' honda civic lx 4 door
- WHat does a 3rd grind swap usually entail?
- timing issue.
- B16 intake manifold welded to dseries flange...done!
- stock compression on d16y7(psi)
- Quick Electric Oil Pressure Gauge Install Question
- Why does an increase in compression yeild more power w/cams?
- Another VAFC Question
- Rough going into first gear and sometimes the rest
- Help wiring a Vafc 1
- need some help with timing belt
- Where to find 1 7/8 inch exhaust donut for usdm zigen header
- Head Gasket ?
- New AutoXray Ez-Link OBDII Scan Tool! Need the location of the plug to scan!!!
- hondata s200 needs boost
- LS ECU + GSR motor. code 1 and code 22.
- firewall MAP sensor
- knock sensor question??????????please help?
- help!
- OBD2 Crank angle sensor help
- quick question: hondata s200 with gm 3 bar
- Gearbox "taps" in neutral and accel...and "wobble" noise at 2000rpms
- obd2 with obd0 injectors?
- Are all B-series starters the same, Vtec and Non Vtec?
- click noise in distributor
- GUYS HELP... LONG STORY....
- How do I properly use the 'idle adjustment?'
- OBD1 LS ECU into 93 Del Sol with OBD2 GSR swap plus VAFC2, help?
- ECU cel code 15?
- LS/VTEC HELP!!!!!!!
- Electronic cutouts
- Port N Polish Or Just Valve Job(searched)
- blox manifold
- NEED help...how to turn back the odomete for cluster
- Need help!!
- anyone have a d16 cam gear they care to compare with me?
- head assembly - rocker and timing out of whack!! Need help!!!
- two tech ? 91 civic electronics
- Quick question about ecu programming... WRT crome, hondata, etc...
- Will a Y8 VSS work for a GSR Trans?
- cam question
- Machine shop price, does this sound right?
- carbon fiber intake
- P72 Head
- what RPM is safe on stock ITR bottom end?
- stupid question about a P06
- for anyone looking TO help with engine trouble: pleeaassseee help me out guys!
- question about LMA???
- Compression question...
- not a honda question
- Questions no ones ever answered for me...
- minime goes clicking..
- How to determine axle ratio?
- p28 or p72 question/issue
- 10A intrument panel/taillight/license plate fuse keeps blowing...help
- arp bolts
- Need some help asap. Pulled my clutch and look what I found...
- Itr climated control installed now abs light is on
- head bolts on gsr/si
- Way to tell if head and trans are stolen?
- Do I need a new clutch?
- Learning to tune ECU's
- new engine lacks power
- problem while replacing fuel filter
- 5th gear pop out
- GSR Front brake question?
- need help w/ price on B16A2 motor
- Intake Manifold and Larger T.B
- ferrea 6000 vs ITR valves
- What should I lock my timing at?
- Gsr belt dont Fit at all
- Fuel Pressure Issue
- rotor screw in distributor
- P28
- final drive in 95 jdm civic sir b16?
- H22 LSD Questions.
- lookin 4 rims
- TPS voltage at WOT is 3.2 minimum, 3.7 maximum. Bad TPS?
- 4g63 in civic
- bent valve??????
- shift light????
- Why does fuel pressure drop to 0?
- Installing Head
- just got back from smog i have a quick question..
- eg owners...
- Regarding the SRS and Seatbelt lights
- Is it worth it.....
- d16z6 mods and tuner options
- 87 octane vs. 91 octane
- Oil pressure light
- Single vs dual bend Shifters
- 99 d16y8 into 99 hx need help!
- Does Hasport even make hydro to cable conversions anymore?!
- 2006 Civic Si K20 Motor
- oil
- automatic ls tranny
- Advantages of closed cooling system
- HELP Water????? Sputtering during accel
- z10 3 main girdle for ls/vtec
- Weird misfire problem!!!!!
- How to install extended wheel studs w/o a press.
- Lift/Duration of GSR cams while NOT in VTEC
- manual oil guages
- search is down, compression?
- Please help with 2001 civic EX auto transmission
- knock sensor on rsx?
- motor locked up?
- Bad Fast Idle Valve? i fixed MINE
- ARP oilpan stud/bolts?
- Cracked tranny still useable?
- ceramic clutch noise??!!
- AUTO TO MANUAL CONVERSION
- Run Vacum to TB? Stock TB to vacum lines, BDL ?
- integra dashboard w/center console, gauge cluster, etc. on crx...need wiring instructions
- Want to add a burnout limiter to a Digital 6
- Mini Me
- skunk 2 manifold and throttle body b16a2 how do i do it?
- P28 ecu ???
- wat chip to use?
- neat valve spring compressor
- how to tell if i have CTR cams? please help asap!!
- Stalling/Starting Problems
- What size AN fittings/line to use for coolant system
- axles
- cel code 16
- timing settings via pin punch through camshaft
- Failed emissions...couple o2 questions
- quaife torque??
- 2000 DX Hatch --> SiR Harness
- Question about reverse gear in Gsr tranny
- Speedometer going nuts at times
- need help with firewall oil line feed..
- New here need some info
- vtec oil pressure switch
- VSS gremlin. searched
- What Holds Oil pressure when engine is shut off?
- JDM integra Cluster problems.....
- No oil pressure after sitting for a week in the cold
- Help! Running SO RICH
- Knocking sound at higher rpm and during startup
- Converting a P28 to run a 1-wire o2 sensor
- rod and main bearings
- help, no spark.
- H23 troubles
- gsr tranny part ?
- lsvtec parts list (help me out please)
- vafc help
- Electrical issues, no crank, no start, no power, battery fine, help
- DP-MPFI conversion help!!!
- b16 cam cap torque specs 6mm, 8mm bolts (Im kinda in a hurry)
- GSR IACV & Skunk 2 Intake Manifold
- D15 Head On D16y8 block???
- b18c1 oil cooler
- What Rings for CTR pistons?
- blox manifold install
- B18 LSD in D series Si case
- k20 conversion
- Impact Wrench
- How to tell if LBJ is bad?
- Need help please read?
- quick injector question
- Cel 13, replaced Map sensor now what???
- Mid Mount CRX???
- h22a4 vtec not engaging or weak
- Just installed new clutch. Got Qs.
- is this Engine OK???
- oil pump with 100 miles - reuse?
- distributor bearing replacement. dizzy
- MEET TODAY AT FLOYYD BENNITT FIELD
- jdm ITR Oil Change????
- tdc sensor ok but still no start.
- FITV IACV Throttle bodies and S200B
- IS IT EASY!!! A6 Head / Z6 Block - Stay OBDO and BOOOST!
- Gear shifter lock
- VAFC2 harness question
- spark plug wire keeps poppin up...need help!!!!
- Misfire when cold?
- circuit board PROS which one is q101???
- auto trans question
- integra tdc sensor??
- d15b2 head / d16y7 block?
- what cause low vac on boost gauge?....
- JDM H22A Nitrous buildup
- no start
- EGR Help
- 96 gsr firing order
- timing belt question
- gsr swap
- engine stand bolts?
- Battery keeps dying.. Alternator is GOOD.. WTF??
- which cams should i get?
- Is my engine going to blow?
- 95 Civic EX--Tech Help--Won't keep running
- I think I just learned something new...
- Engine labor needed in So. Cal ASAP (Valve Adj.)
- can not bleed clutch
- best price on sleeving?
- Does anyone know what RCI's home site is?
- Valve Adjustment with non-stock cam timing
- Camshafts from "ZEX" good or not ?
- CV boot bands
- which cams should i use
- Yep a new tps problem... maybe not tps.. funny problem...
- Best ways to install BLOCK GUARD
- idle problem rolling my eyes
- Intermediate shaft and axle fitment (EF)
- low idle probelm B16a2
- ITR vs. CTR JDM piston question
- Car starting issues
- sodium fillved vs titanium valves
- Need help with automatic transmission......slams into gear, hear clunk noise.
- Idle problem.
- Y1 Tranny Rebuild
- TB sizing???
- Anything else I should do to the block machine wise?
- Alternator Removal on 99 SI
