View Full Version : Tech / Misc
- venom chip wiring help
- B-series transmission versus D-series transmission
- stronger shift fork
- GSR Tranny gives out in Palmdale IDRC
- building/rebuilding my first engine....any tips or tools I need?
- Cam timing problem
- S300 Problem
- GSR or TypeR tranny for the track?
- Wanted to find out what intake manifold I have
- B16 blocks?
- How does oil weight/viscosity afftect oil pressure?
- Are all B-series valve seals the same?
- is .0002" too much? rod/main bearings
- 92 teg wont start
- open loop w/cel?
- Car died/won't start/gauges fluctuating prior to car dying
- any one know about the mishimoto for turbo cars
- B18C5 problems!
- code 22, Vtec pressure sensor, Does it work??
- how do you tell what b series head u have???
- Installing lsd in my s4c tranny. I need some specs!!
- Main Cap has a scratch in it :(. help!!
- B18B1 Cams in B18A1 Head?
- need someone to tune uberdata in the New England area (Massachusetts)
- I have a b16 head should i go b18b or b18c block
- DTC p1362 tdc sensor no pulse
- Where to find potentiometer?
- Just blew up a new rad, need help with lingering cooling problem
- Ring Gear help please!!!!!!!!!!
- no primary O2?
- SEARCHED: ****Where to get a Machinists Scale****
- Diagnose my problem(tranny/clutch question)
- How do u take the clutch assembly off? Help plzz
- Im so screwed......
- Adjustable Fuel pressure regulator
- b18b head
- 1995 Turbo GSR....
- p30 ecu, want to make my car obd1
- Motor help
- Can't rotate crank after installing transmission
- crane stg 2 cams
- GSR oil cooler on LS
- Solid Check Engine Light
- auto & man crank balancing?!?!?
- Crank Pulley
- TE Datalogging issue
- Brakes Problem: Pedal goes to floor when wheels are completely turned L or R
- Mini-Me planning, help me out for a sec
- Axle popped out
- tuning a p06 into a vtec?
- GSR sensor torque specs?
- TPS problem......
- ^&*$^#&$ How bad is this?
- gsr swap, iab wiring
- ECU Chips
- Help with climate control
- Cable tranny into hydro shell?
- Which ECU is that ?
- Gasket Kits compatbility
- Air tool Recommendations
- are all bseries clutches the same?
- HELP!!!! lost 1st, 3rd, 5th - shifter pops outta gear... k20a swap
- ecu question
- Water Injection on NA H22
- what do i need to set up my laptop
- 96 jdm itr crank, rods, W/ new RS 84mm 11;5 pistons in a b20b block???/!!!
- B16 Valve adjustment with 00 ITR cams
- 96 d16y7 overheating
- Help should pilot bearing spin
- ERR!! MISFIRING ALL CYLIDERS.
- Would like to know if the y7 block is the same as y8
- Does a P28 ecu use a knock sensor?????
- car sputters in high rpm!
- pls help! a/c and radio lights do not work.....
- Transmission Question
- Im having major zc problems.
- Does GSR head have smaller cobustion than B16 head?
- HELP>>>>>>>>>auto not switching gears.........
- H22 in my civic hatch axle question
- Timing off need some input (allready searched)
- Difference in B18a and b main caps?
- Can someone please tell me what ECU and Chip this is?
- WHERE CAN I FIND DARTON OR AEBS SLEEVES lsvtec
- Has anyone dealt with RS MACHINES within the past year?
- oil filters?
- were can i find koyo radiators
- Turboedit and launch control
- LS Vetech
- LS Milage for turbo???????????
- problem with Gsr block
- Where to buy color code wiring like OEM?
- what car did this head come off of?
- Lost at this point, with pictures
- What ecu is this? No stickers on it.
- A little advide on removing surface rust please
- chipped p28, now car won't start?!?!
- obd1 vs obd2 b18b IM
- cam gear cracked.....help!!
- rebuilding rear disk brake cylinders?
- intake manifold swap...
- engine rebuild - where do these go?
- ctr pistion question
- hondata maps
- engines and running obd
- gsr clutch/ls flywheel
- Synthetic vs Conventional Oil
- ls header on b20z?
- obd0 vs obd1
- lol oh crap! Wiring harness I bought is from Canada!! HELP ID!
- at what point will a rich condition create a CEL
- ef civic cam holder bolts and head bolts torque
- h22a4 head, interference or not?
- Code 22
- Clutch, Tranny ???????
- dohc zc timing.. need assistance
- Code 6 please help!!!!!
- Fuel boss fuel saver
- ecu question
- RCREW HARNESS HELP!!!!
- b16 clutch
- transmission replacement myself
- ecu plug.. loose wire
- Is a P72 head a type r head????
- b18 in a 99 ex swap. HELP.....
- Strange brake issue
- Taillights won't shut off ~ HELP!@
- oil pressure gauge install question??
- synchromesh fluid
- ls/vtec
- Stock axle breaking point?
- Exhaust manifold gasket
- Topline bearings
- Oil Sending Unit question
- hondata s300 question...
- YS1, Y1 Tranny with LSd.. what oil to use?
- Autonics Stand Alone
- Wet Nitrous fuel line guestion
- D16A6 Lower crank housing bolts (8) tightening sequence?.. Anyone?
- GSR or B16 tranny?
- Dumb Question FPR related
- B16B collector size
- h22a throwin code 43
- car keyed/rust repair.. best way to address this situation..
- Turbo Tune in greensboro...
- Engine Smoke... Perfect leakdown... What could it be ?
- What would happen if you wire vtec wrong?
- D16Z6 clutch into a D16A1?
- effect of tire size
- whats the cross reference for JDM d15b??? searched
- Whats the best way to separate lower balljoint from knuckle ?????
- car dies
- Intake manifold swap- problems- looking for suggestions
- will LS flywheel fit b16
- Winding Noise from the tranny
- Problem with the car pulling left when accelerating then right when decelerating
- b16a throwing knock. code 23
- is it possible to chip a p09 ecu?? SEARCHED
- Tranny Gurus, Whats This? LINK INSIDE
- hondata s200 or s300?
- p28 ecu problems h22a
- Wide Band Sensor + Laptop = Wide Band?
- help..car not going into gear
- Electrical problem help please
- b16a and b18a starter motors
- clutch help....
- **HYDRO clutch problems**
- Distributer? Or is it something else?
- White oil?
- 5 lug on 98 civic 4dr.. which e brake cables will work?
- Do I have a failing ECU? Solid CEL but goes away when ECU is reset.
- b18c1 build.... uhoh what to do?
- 1988 Integra ?
- Bizzare stalling problem, no cel code, searched like a mofo'
- HELP CEL 54 CRANK FLUCTUATION SENSOR!!??
- 98' with OBD1 good in England?
- signifcants of cams..
- PLEASE HELP H22A WON'T START IN COLD!!!
- GEAR SPEED TRANNY how much did you pay for yours?
- Tach signal wire
- RESTORE: Engine Restorer & Lubricant
- Timing Belt - Will it fit?
- JDM B18C SERVICE MANUAL????
- y do turbo car over heat anyone
- metallic VS. ceramic catalytic converters
- Gsr trans question ?
- some help from honda tech?
- help the eg out
- Irratic idling problem, not the typical one
- Honing the cylinder walls
- D16A6 Crank housing bolt tightening order and torque settings?
- gauge question
- Dizzy Questions on Mini Me Swap...
- Civic Inner Tie Rod Size??
- apexi power fc 99-00 ctr
- Driveway Ramps? WHere to buy
- Fuel Injector Angle
- 94 Accord Transmission in a 91 Accord
- Engine Stand claw to Tranny BOLTS.....No one seems to have em
- GSR tranny ...
- vtec hook up
- Ignition and Honata??????
- Symptoms of a bad halfshaft?????
- h22a vtec problem !HELP!
- HELP: 94 GSR crank but will not start, problem is intermittent
- converting to obd1
- STROKER KIT
- Calico vs King vs ACL vs OEM
- !!!!!!need help!!!!!!
- can u put gsr intake manifold on to the ls?
- 2 questions
- Transmission problem someone please help!
- LS transmission Leaking...
- can hondalog cable cause problems with chipped ecu?
- b16 swap, need some info
- RC Air/Fuel Hauge Wiring
- clutch too strong?
- Cel 21...Help please
- engine/tranny will be going into storage soon HELP
- Theroetically speaking..
- tranny problems....
- brakes?
- SiR integra(auto) b18c cam profile different to manual??
- feed line
- GSR loosing coolant! Cracked block??
- WHAT REALLY HAPPENS..
- Aem tru power pulley belt size?
- Shifter assembly problems
- No spark and injectors getting a constant 12v signal!?
- built low compression turbo motor running with no boost for daily driving?
- Inconsistent Surging Idle
- GSR Pistons In A LS????
- can anyone identify this spoiler?
- Car overheats
- block concrete? searched
- gsr tranny on LS?!?!
- CRX B16 trouble
- JDM ITR vs USDM ITR pistons
- Ctr pistons in a gsr
- GSR bogging right after vtec (6k)
- cold spark plug, cold 10
- catback help
- synchromesch del sol vti
- speed sensor
- header question
- NGK Iridium VS Denso
- NJ MPFI SWAP HELP
- worn clutch, seems like it sometimes shakes?
- p72 tuning
- Failed Smog...Need help from Fellow H22 swappers and Emissions GURUS!
- Failed Smog. Give opinions on what i should do.
