View Full Version : Tech / Misc
- OEM LSD in GSR tranny???
- p13 ecu
- car hesitates or lags
- How do you make a DA w/ a B16A legal???
- Installing Zex, which TPS wire do I tap in to?
- crx swap B18A1
- Is misfiring caused by bad spark plugs?
- state ref inspection
- Obd1 Heated 02 Sensor Diagram needed...
- new pistons with just honing the block.
- What is the difference between the B-Series block?
- YS1 or S4C tranny??
- Integra OEM Fog Light Switch Wiring Diagram
- need HELP installing blaster ss coil and msd cap!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- Detonation, symptoms, help...NGK Spark Plugs w/Zex, safe?
- ECU chipping Q-only for the experienced.
- Spring Rates for Eibach Sportline and Neuspeed Race listed here...
- Lojack...
- ITB's, whose is the best?
- I got some 310 RC injector for my H22A will they help out a lot or little
- JET V-Force Ignition Module
- Tools
- Air Condition Squeeling?
- thimk its air con
- Help! My engine overheated today!
- does anyone here work for honda......or know anything about Master Keys
- Installing used cam - please help
- obd1 to obd2
- OBD1 internals in OBD2 distirbuter case?
- Idle adjustment screw?
- Gasket Sets
- B20/Vtec question
- knocking sound?
- Need help, car not running smooth..
- P28 ecu
- Advanced timing on B16
- need tech help...whats the matter with my car?????
- FIT? Neuspeed front upper strut bar and B&M FPR???
- Axxis ultimates....??
- exhaust question
- installing ingalls camber kit
- Wanted Info: D16Y6 Motor
- Final Question with B16 ARP head studs need to ORDER ASAP
- p72 GSR ecu on B16??
- Are Koni yellows externally adjustable?
- Cam Gears
- Need Help On B16A!!!
- Where's that b-series compression ratio calc?
- my car died and i have no spark?
- Best place for port&polish in toronto
- ACL Bearings Tech Info and Pix
- car wont start anymore
- Zex junkies, need installation instructions, recommendations
- my swap sucks......
- engine swap
- I need a big trottlebody!
- JDM engine
- coilovers -- questions from a suspension newbie!
- H22/23 questions.
- more idle issues
- when does vtec kick in?
- Can someone help me? Distributor problem possibly
- MAP sensor
- b-series water pump install
- Good fuel information. VERY long!!!
- tranny problems?
- Adjusting Cam Gears - how?
- Offset/tire clarification...help, ordering this week!
- $550 for install of Clutch and Quaife..... Help me, is that too much???
- Reliable NA setup?
- HELP !!! GSR ECU in my ls/vtec ?
- HELP me put this back together.
- integra coil
- what is a leak down test??
- what does long block include?
- Hub removal.....HELP!
- HKS C.A.M.P. anyone seen or used one of these?
- Aem FPR a pos?
- Tune up things...
- CEL 68 -- No clue
- what kind of ecu for boost???
- Header wrap on a CAI ?
- Neuspeed/Koni vs. Regular Koni Shocks...
- How much MTF is needed?
- Apex power intake filter
- Integ Type R Tranny conversion? Rocket ???
- mandrel vs. crush
- CODE 17 with other things
- comptech icebox compatability
- how high can I go
- 17's how bad are they for me
- A Warning on "www.massivemotorsports.com"
- tuning my car
- cam gear settings for ITR cams
- Wiring secondary butterflies on GSR hybrid
- transmission problems on 98 auto EX
- help me out...........
- A/C Squealing, Please HELP!
- Fastbrake replacement
- msd dist. cap
- Sport shocks - drop range??
- 91 civic options
- i got a b16 head that i am putting together and have some questions about the dowel pins...
- Performance DSM Mechanic WANTED!!!
- Getting more hp from a type r
- idle acting funny.
- B16A pistons with B20 rods???
- !!! Tach will not work after engine swap!!!
- Suspension articles...
- Car stalling!!
- HELP... Solenoid- B18/rex
- B16a going into 6th gen civic, i need help!!!!!
- Tryin to lower CP for a GS-R motor, need help.
- Reccomended VTEC engagement point?
- overheat problem.
- vtec discussion on F22b1
- Need assistance PLS.
- Bigger Fuel Pump
- Smoke came out when I pulled the spark plug...
- m/t??
- ???86-89 teg = ????????
- Which Carbon Fiber Hood?
- How can I make my CIVIC DX quicker with out spending a lot of money?
- b18c smokes as you get on or off the gas and the exhaust really stinks.
- vtec
- turbo lag
- Strut Recomendations??
- AEM EMS & Boost controller?
- Help me get rid of my stutter please...
- Due to being the victim of a hit and run, i am currently swapping right rear trailing arms in my 93
- What's a good swap for a 94Civ Ex?
- How do you get the alternator out
- Question about combining 264 HKS cam with 272 cam on the exhaust side of Turbo engine
- 5g Upper Ball joint replacement...need part info
- Engine bearings (mains and rods)
- Tranny ? A.S.A.P.
- VTEC kicks in...but no power
- getting code 7 on rebuilt b16a1 (pw0/pr3 ecu)
- Would it be pointless to get camgears on stock GSR cams and engine.
- Odd electrical glitch when I turn key. What is this??
- JDM 4.7 final drive info
- this is what happens when you beat on a clutchmasters stage 3.
- All honda stock pistons made out of same material?
- differences in burning oil vs coolant
- Whats the law with swapping in CA nowadays?
- Disk brake conversion
- Installation experiences with bushing sets and valve springs.....
- Spring rate question
- Vtec head mods for B20?
- How to install a Quaife??? Please help.
- Fastbrakes 11.75" kit pix...
- B20 pistons in B16? and the CR afterwards
- i have reached the 100,000 km point for my 94 integra... lots of questions...
- b16 oil/water pump Q
- are ITR and GSR retainers the same?
- ???your thought on an engine rebuild????
- B series transmission ?
- correct order for bleeding brakes on JDM DA6
- a/c power loss...
- thumping noise - passenger side, when i depress brake slightly..
- uneven drops
- vtec alternative/replacement
- 02 crv block?
- A good or bad idea ?????
- High Strength Head Studs for D16Y8? ARP does not make them for it
- Replace Bearings with piston swap???
- Grinding in 5th
- Couple more maintenance questions...
- Field SFC
- valve clearences
- problem car making noise
- Web Camshaft Co.
- ??? Type r swap into 92 EG CX ???
- wheel / tire question
- sohc custom turbo
- Why do we need to cross hatch ??
- spark plug gaps for high compression
- A/C Troubles.
- intake manifold
- Valvetrain Question . . .
- cat back install
- crankshaft
- does the 93 integra rear suspension fit a 98 civic?
- 180 for a mirror my a$$. Note: Mirror was broken in accident. 1 hour a 12mm rachet and some super
- HID question
- Where does the metal wire for the vent hook up too?
- 6th Gen EX. Idle high until stopped. Cleaned the trottle body and IACV....???
- best o2 replacements !!!!!!
- suspension q's
- car starting problem
- How often to replace Cap w/ aftermarket ignition
- Removing bolt from cam gear
- Speedo reads 10-15mph high?
- where to buy tokico shocks?
- 161/123 on dyno, what can I expect from bolt ons and tuning
- car terms i don't understand
- Pinging noise at high speeds/steep hills
- Whats up with these times?
- NSX / Legend Calipers
- B16A1 and B16A2 or 3....is the main and rod bearings the same?
- The Difference between FPR and FMU?
- baffled
- Deck Height
- gsr or itr cams?
- turbo
- camshaft endplay
- Problem with tranny. HELP!!
- Oil Filter Flow Path question
- vtec- whats the same?
- o2????????
- what is this?????
- norfolk virginia area
- LS Integra Engine Upgrades.....
- Has anyone put an HID setup in a 96-00 civic?
- High Performance Coated Pistons?
- turbo Q?
- question on changing head gasket
- HELP! clank/click from tranny.
- anyone know did SW388 spoon wheel have 4X114 bolt pattern>?
- whats wrong??
- What can I do?
- Factory H.I.D. vs. Aftermarket
- Engine sputter ????
- which rims would be better for performance wise.
- Spoon SW388
- need more fuel??? techs please
- tech
- How did your hondata run with bigger injectors and no tuning?
- BIG TIME clutch problem !!!
- Inspection of CV boot...
- How do you know u've bad crank bearing??
- I fuking won!!!
- o2
- compression numbers
- Oil pan bolt, leaking.
- Need major answer for JDM b16a to an CX EK 96-98 civic hatch . EXpert please help
- eastside muffler
- how to wire vtec switch to "accessory" output on computer.....
- Greddy turbo timer install on my 2000 si.. help!!!
- can u change a sohc to a dohc without changing the bloc?
- Running rich and tps
- My clutch is bothering me.......
- Problem with steering, any ideas??
- Help Speedometer isnt workng???
- Is there a difference in a b16a block and a b16a2 block
- Master cylinder question
- my moms legend...
- diagnose my low idle
- oversized throttle bodies....
- CEL with test pipe
