View Full Version : Tech / Misc
- b18a1 with b16 head and ls rods ctr pistons
- obd1 LS tranny in obd0 CRX
- Aftermarket pistons/rods: Installing Pins?
- leakdown test results, help!!
- D series to B series transmission swap/ clutch problems
- Exhaust question
- valve job, a good one or not...
- fuel pressure, spark, correct timing, but won't start.
- PLX M-300 - Narrowband output doesn't satisfy ECU - Random CEL
- what obd1 ecu will properly run a d16y8 swap in an obd1 car p28 p07 p06
- need HELP with Chassis Electrical system diagrams
- Integra CEL 4,5 ABS code 12,31,32,81
- what is the difference between this treny?
- Time-Sert Thread Repair Kit for CRV - Need an experienced NYC mechanic!
- Need help changing distributors, distributor problems plz help
- Want to install d16y8 thats been sitting for 4 years
- ACL RACE SERIES BEARINGS
- Changed clutch and gearing is notchy now
- Twin disk or single disk help pick
- P30 ecu
- crome gold??
- will ls dist fit a b20?
- car won't start....ran fine but now nothing.....need help....
- Another solution to idle problems
- help with rebuild
- b16 tranny with a b18 clutch?
- 350hp na and 350hp turbo 1/4 mile
- b16 block, trade question
- 99 civic ls/vtec????????
- h22 piston rings? HELP!!!
- Clutchnet.com reviews? any good.
- Tested the Fuelmiser gas saving device - IT WORKS!!
- need some transmission advice.
- please help me with my charging system!
- transmission
- Do i have to use a Kaaz speedo gear on a Kaaz lsd ...you know how much they said?
- Bearing supplier
- ACL vs. OEM for my application... please help
- Fuel rail?
- GSR tranny with LS 2nd and 3rd gear?
- vx 3rd 1.066 into cable trans
- Best after market (OEM looking) exhaust
- loose timing belt
- Compression check question
- code 20 on and off ELD
- What is the Y59 transmission?
- Help me choose........please.
- itr pistons/ctr pistons?!?!?!
- best way to tap my valve cover
- Wiring Harness question?
- differential bearing (enclosed vs open)?
- Auto transmission problems
- has anyone had a Quick Time Electric Cutout system in there car
- Faulty iacv ?
- LS Pistons on GSR Rods?
- Transmission question. pops out gear now and than
- What is needed to tune with vista
- gsr dipstick same length as b16?
- What would you prefer for lsd...
- S1/J1 B16a cable tranny 90-91 spec jdm: which richmond spool?
- Alternative to Cleaning AEM dryflow filter ???
- valve adjustment lock nut missing
- what ecu to use? gsr motor
- signal light problem!!!
- b18 leaking oil
- exhaust ? eg hatch w/b18cR
- jerky throttle
- speed sensor problem
- air/fuel mixture adjustment on a d series
- ** Can this cage be certified for drag racing?** nhra/ihra * cage builder input needed
- Final drive JDM Type-R kit with first gear also?
- Clutch finally engages after release
- Valve clearance on 98 P8R head
- H22A Exhaust
- AEM fuel pressure regulator o-ring
- B18B1 Cam timing question
- what are the timing specs for a 93 civic 1.5 cx?
- d16z6 E426? camshaft
- Oil Orifice missing?! Opinions needed
- Transmission question, need help?
- CEL P1456 and P1457
- How to wire a b16a alternator up (custom)
- How to do a rear disc conv. need help !!!!
- HELP nEeDeD. motor build
- Checking for Bent Valves without going to a machine shop
- car wont crank...please help
- 02 civic ex nos
- d15 wont start.
- i need some help with this
- B-Series motor building
- Integra Type R- Fuel Pump - Pressure Needed for FI
- How can you tell if the LSD is still inside the transmission (H22A)?
- Timing belt and cam gears not sure.
- CRVTEC build question...
- help with b20 head p8r
- greddy ECU
- A/C Clutch Oil?
- Can speed sensors be dismantled?
- Crower rod installation?
- transmission question????
- What is my problem (strange compression numbers)?
- "All Hondas vibrate a little when at idle."
- Buddy Club spec 4 camshaft defect
- Block Vin Numbers
- B-series differential? Difference between hydro and cable
- No crank..
- trouble after replacing master cylinder
- HONDA CIVIC 1.8 VTI FUELLING
- Installing 5.9's New wheel bearings dont fit! too small ???
- How do i get my car to pass inspection?!?!?!?!?!?
- Anyone had luck just using inline resistor when bypassing iacv?
- valve seal spring color
- Arp Tech Sheet
- Caliper Rebuild Grease Packs
- LOW REVS - ACCELERATION PROBLEM... PLS...HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!
- engines rotates but does not crank
- Replacing CHIPS in ECU - doable?
- help s1 trans question!!!!
- APEXi V - TEC Airflow Converter II (V-AFC II)
- 1998 Civic with d16y8 intake manifold: GS-R throttle body fitment?!??!
- How do i covert my OBD-2 to OBD-1?? HELP??
- DIY oil filter relocation...
- exhaust/cat question
- SLIPPED timing belt? damage to internal?
- Stripped Oil Pan Solutions Needed!
- Sir I or Sir II
- Bogging/sputtering around 3k
- quick timing question
- Will a dented downpipe really affect performance?
- What would cause my tach to rise, then go backwards while still accellerating?
- what would cause this piston and head damage ? no valves look bent?
- B-series tranny casing question...
- looking for trans rebuild parts
- tuning p2t same as p28
- FACT OR FICTION "AFTER MARKET STERING WHEELS"
- I dont think its true, about JDM engines
- Are these brake rotors safe to use?
- Need help chipping ECU
- question about some sort of computer that monitor's shifting rpm points? dunno how to search topic
- how do i know if i have a manual or auto y8 intake manifold????? help
- HOW TO: Swap a B-Series Differential (Video)
- trans make 1 or 2 clicks when in reverse
- B16a2 rally engine build advise
- Oil to use?
- HELP h2sa swap into a eg civic coupe
- DO YOU THINK THIS IS TRUE?
- How do I strip the valve cover for powdercoating?
- Polyurethane Motor mount insert questions.
- what do you guys think about obx lsd?? good or bad
- ITR Tranny Swap
- ?????? Valve clearances ?????? --D16A6--
- lightweight crank torque curve
- Ask for Throttle Body, Intake Manifold, Down Pipe.
- really really need help here.
- My Honda Beat Project - A technical deconstruction of a little known Honda.
- vtec
- i think my water pump is on its way out
- help with nissan pickup
- lags
- Speed Sensor Problem
- clutch/transmission problem
- HELP! Need o2 wiring help
- Axle Seal: B16 Trans(Size, Install Questions)
- crv transmission
- K series crank pulley bolt
- 5v output in a obd1 ecu
- 94 civic ex no power to fuel rail?? HELP!!
- Clogged muffler?
- VAFC removed, wired back up to original now throwing 5 codes EM1 2000 civic Si b16
- type r outer valve springs
- 5th gear grind...
- **[b]tranny..how do u put the halves together??[/b]**
- Injector Differences
- can crome be used in this case?
- Doing a obd2 h22 swap into a 93 obd1 accord.. advise needed...
- CRV: Overheating and Engine Block bolts have pulled out the threads - Advice Please
- Target C/R for a blown JRSC B20Z?
- Possible to use K series ECU?
- Lightest/least complex/easiest to find/cheaper to buy Honda engine?
- Lots of Black Smoke
- Headers touching oil pan
- Where to buy wire???
- Direct port nitrous nozzle placement
- anyone know the best buddyclub exhaust for a gsr?
- HELP RECAROS
- Radio Issues
- what size are ....
- Honda MTF Viscosity Index/Flash point?
- motor mount inserts
- p75-a51 <-- OBD1?
- vtec controller pinout
- what are the symptoms of a bad fuel pressure regulator?
- Clutch Removal for '87 civic si
- jdm itr 4-1 replica engine temperature too cool
- Power coated rims
- stg .3 XTD clutch
- breaking in rings and rod bearings
- First time honda owner who need sto change waterpump and timing belt!!!!
- corner light!!!
- Anyone bought brake rotor's and/or pad's from Rotorworks on EBay?
- set basic settings 03 accord ex 4 cyl?????anybody know how???
- S1/J1 B16 non-LSD cable transmission: Will MFactory 4.92 gear set work?
- Differences in obd1 and obd2 distributors?
- Valve train/rocker arm questions...
- Race Fuel?
- B-series tranny speed sesnor please HELP !!!
- Separating the ECU board from the case?
- problem with integra tail light
- how 2 check a tach signal on my gsr hatch
- need some information
- 01 gsr b16 lsd installation help
- throttle body pulley
- Hondata? Kpro anybody have any good base tunes 06' rsx type s
- Tranny shipping help plz !!!!!! Everyone
- my car sounds like a wrx, help!
- I have a vtec head that i cant identify
- da ls cluster into crx
- Hard Shifting at High RPM's
- P0740 code on 2001 Acura TL 3.2 V6
- 96 obd2a gsr throttle body on 92 DA
- whats up with my tranny
- hondata s200 discontinued? does anyone know why?
- Crank pully movement....
- Exaust Drone: Completely eliminating!
- why golden eagle uses the vtec gasket in our kits
- gsr tranny
- Random question
- white smoke??help
- Need to no cam specs
- Spoon Radiator Cap Type D
- dyno shops?
- Civic headlights are acting wierd!!
- 95 integra ABS light
- How much boost on 87 to 91 octane?
- buddy club
- GM knock sensor?
- Hear knocking when cold starts on fresh build.
- Fuel press. reg. through purge valve. Cause leaning???
- H22 swap In integra
- Final Gear Bolt Part #
- Car issues
- K24/20 Tech Info
- How do you know if it is a GSR timing belt
- AFC Neo throwing a cel
- 96 Integra GSR b16 tranny.......
- Head Swap?
- anyone running the crane hi 6s ignition??? i need help
- buddy club computer
- gsr brake issues
- p28 inside- good or bad- opionions needed
