View Full Version : Tech / Misc
- Toda B valve adjustment specs....
- HELP Del Sol Valve adjustment
- JDM vtec solenoid VS USDM vtec solenoid??
- OEM pistons OEM rings... what ring end gap?
- can anyone tell me what the timing is for a b16a1 jspec engine
- compression check question...did search...
- ardperformance.com
- block gaurd yes or no?????
- 4th gen wiring question
- i've made my plans, here is what $$$1645 should get me...
- AEM cai vs. AEM V2
- wheel fitment question
- P28 SOHC chip good for DOHC swap?
- flywheels the same
- Pluging FITV on gsr
- Finding ecu jumper wires
- electrical problem...
- will 0rings from gsr injectors work on prelude injectors?
- auto zone alternator just as good as stock?
- d16y7 timing problem
- Integra R lsd on cable GSR?
- RPM Throttle Body
- 94 dx hb....have some questions?
- I crank the Engine i hear a click seems like every revolution??????????
- a/f guage on non obd o2??
- 99-up Civic Wiring/Pin book ?
- double clutching
- 02 sensor problems!!! Make it stop please!!!1
- 'homemade' radiator hose... will this be alright? pics
- timing belt issues?
- Why is my car idling @ 1100 RPMs????? Please help
- Keep old ecu or use new ?
- ls vtec or high compression b16a with cams
- 95 EX SOHC Vtec No Start
- whats the voltage of the yel/blk wires at ecu called -power input- 12v right?
- craziest thing i have ever seen at rockingham today
- clutch interchangeability?
- auto to manual p28
- Intake manifolds
- How important is a Valve job during my rebuild?
- Automatic ECU???
- tranny size
- intake mainfold whistle?
- blew up my b18c5 help me diagnose please
- Need Tech help any is appreciated
- Want To Drop My Civic . . . .
- eibach prokit....
- Falken Tires?'s
- possible to recondition O2 sensors?
- Brake bleeding procedure w/ABS
- sort of a review: skunk2 short shifter
- Where to find online timing belt "how to's"?
- ignition ?'s
- B20 Vtec Quick Q
- Timing belt snapped on stock B18C1. Ways to diagnose damage?
- Torque
- Using old exh mani gaskets?
- ZC bogging out at 4500RPM????????HELP
- B18C1 down to a SOHC D16
- Anyone running Skunk2 II cams ??
- i'm a "Gross Polluter"! failed my smog test!!!
- Bore sizing question...
- Expert transmission help pls
- Wiring configuration on ECU plug on a 90 honda Civic DX
- rear disc brake conversion.....
- Custom close ratio rebuild on VX tranny questions????
- idle jerking problem
- Whats best?
- what's the most power someone has made NA at 11.2:1
- nice civic 4 sale
- Making a composite Intake Manifold
- need help asap!!!!!!!!!!!!!!!!!!!!
- How hot (in degrees) does a D-series engine get?
- some tranny questions
- Worn Valvetrain parts? Adjustment question....
- question for the pros??
- new intank pump, ran fine for a while, now doesnt want to pump any fuel??
- block questions
- what head studs do i use?
- H22A into 92 VX. Starting issues -- Main relay please help!
- LS-Vtec on a 200 LS
- '92 Accord ABS troubleshooting help...
- skunk2 IM
- Engine question
- p-30
- How can i clean this (56K don't try)
- AN-R 4-1 Header vs. Greddy 4-2-1 Header for H22 Civic
- Painting Header ...
- vtec head
- electrical problems. relay cutting on and off
- eibach raceline or hr sport?
- what to set valve lash at with jun 3 cams?
- Suspension skips over bumps..
- help on 3rd gen zc swap... need some tech advice
- Vtec work without speedo working
- anyone in san diego that can wire?
- What Is It ??
- intake manifold?
- GSR throttle body install on ITR manifold
- b17 cams??
- Why do I need to do a valve adjustment if...
- New brake pad & rotor install issues/problems
- Help!! strange timing question...
- 00si swap axels?
- Check engine codes needed....
- Clutch / Flywheel opinions...
- vtec wiring...code 21, please help
- code 23 b16 pre obd ecu
- My dyno plots, if anyone cares
- Quick Answer!!! O2 sensor Pin for p75
- JUN springs bind ?
- help..car dies out at 3500 rpm!!
- Any ideas on how to remove the valve stem seals???
- gsr block and b16a2 head?
- Im screwed... SOmething broke when trying to remove front mount
- Help Please!!!
- injector sizing
- what is my redline??
- best place to purchase b16
- Wich ecu to use
- How many oz-in to turn the dial on KYB AGX's?
- New OPTIMA Battery for Civic/Integra/RSX/S2000
- What size drill bit would I use for a -10an bulkhead fitting?
- Need a honda part # for ITR rings...
- Setting timing on B16
- any1 from fresno wanna help me out???
- alternator belt too long with AEM Pulley on my Y7 motor
- Springs + Winter = ???
- EG Civic Suspension Q
- what to use to remove paint on valvecover from junkyard
- HELP PLEASE!! converted to obdI and now car runs funny
- buying new car NEED adivceeeee
- Strange Noise after clutch install
- Wich shift linkage
- Water Leak?
- B16 block + resleeving with bigger bore..
- grease for energy suspension
- Stupid throttle body quesetion.....
- 1992 hatch si quarter?
- My current motor build...need some opinions
- need step by step timing belt change for sohc
- b16 mod
- need help wiring my hks type one turbo timer
- where to get radiator..non honda for cheap
- Anyone actually win a "Modified Exhaust" ticket?
- VAFC 4th Gen Prelude - JDM h22a - jdm p13 - code 21
- need new rings?
- idle is all fcuked up
- Ignition Timing Q
- 90 Accord LX f22a1 engine swap for a h22
- Suspension setup for under $400 - ASAP!
- How hard is it to change a b16a2 pistons and rods?
- Does a lighter valvetrain=more hp?
- Has anybody heard of a shop called Speed Garage in cali???
- Need help reconnecting my vac lines GSR.
- wires and function on vx and hx o2 sensor?
- cluster questions
- Air suspention-how good is it??
- b16 wiring problems in 89 civic
- Projector Headlights or Angle halo lights?
- My H2O sensor is not working right , I get a faulty code n°1 , help wanted
- Volk Racing AV3 wheel question
- B17A1 YS1 tranny w/LSD
- taking longer to start car after header install
- I think I just F#CKED my motor.
- to knife-edge or not....
- Best way to plug a extra coolent line from the thermostat?
- Modify Apex'i piping!
- RIP David Ryan Jackson
- which tranny is better out of the 3 listed...
- My first motor build! So good so far.
- 88-91 crx springs fit on integras?
- Injector Question?
- REALLY stupid question -- Regarding Helms manual
- Understanding the fuel Output Lvl of aftermarket fuel injectors
- zex on my 1.6
- what do i need to put a CRVTEC into my 91 hatch
- problem
- Torque Convertor Question
- hardcore H22 yea woo!!
- DC Integra Cluster Wiring Q about the speedometer and VSS
- Does Anyone Know This Part???
- Walbro 255 fuel pump. Overfueling?
- Kent cams???
- Vtec hits then boggs out. Any Ideas?
- is this possible
- CTR Intake Cam Install
- Little help: 92 VX, JDM H22, Walbro 255 lph, no fuel pressure.
- would this work.... stock tank and fuel cell? Diagram inside....
- Good dyno tuners near Seattle.
- Hydrolocked B16A3, Pictures Inside...
- Rattling?
- Caliper slide grease?
- Help needed with gsr front brake swap on eg cx!!!!!!!
- Hondata Stage 4 or AEM EMS?????
- Timing belt woes- is this good or not?
- help with ls cluster in my ek
- need hi performance alignment specs..toe mainly.
- A/F gauge problem...possibly electrical...
- jdm b16a...what are you thoughts
- Extra parts engine build-up
- anyone heard of cp pistons?
- DIY Port & Polish
- Head pics, deshrouding the valves
- Need favor: J&S Safeguard
- whats the real deal with lightened crank pulleys????
- k20 vs k24
- Valve Clearance setting on ITR cams
- what order do the ignition wires plug into the distributor cap???????
- compression Ratio?? k20
- Endyne +.137 pistons / rods
- Need help troubleshooting this knocking noise on a 1st gen b16a..
- Hawker battery tidbit
- Question about rod bearing notch location
- HUGE engine problem Vid included!
- Which Filter is Better?
- is there a difference in where you buy a water pump and timing belt
- what should my CR be?
- 90 Crx DX shuts off on me when im driving what is it?
- which tranny?
- Squeeky brake pads...
- B16 smokes on hard left turns
- Which spark plugs to go with?
- idle and throttle problems
- header coating
- Will 1st gen b16 bolt straight into an civic eg?
- D15 re-build "better, stronger, more effiecient"
- idle @ 2G+ ???
- b16a2 whoa's
- Where can i get a C&R radiator?????
- Head gasket replacement... absolutely positively necessary????
- Radiator and VTEC ques??????????????
- stage two crower cams
- trying to fix my air compressor, please help
- SOHC jackson super charger dyno charts??? anyone??
- Tranny Leaking from Shift Rod Seal?
- HELP! Blowing whiteish blue smoke out the tailpipe!
- Auto Meter Oil temp gauge?
- BLEEDING BRAKES Don't Make The Same Mistake I Did!
- To coil over or not to coil over? That's my question.
- A/C low pressure valve leaking!!
- I think the force is taking over...
- Piston to valve clearance on a 99 B20Z?
- new car...1987 civic wagon 4wd..what motor should i use....
- Corner ballanceing (where to get it done)
- Compression Test on a B16
- tranny price
- LS/Vtec ?
- Code help!!!
- Is this how you bleed brake correctly?
