View Full Version : Tech / Misc
- -10 an drill bit size?
- just woundering...
- d15b vtec runs like crap on cold startups.? please help.
- Wiseco Pistons (skirt Coated one's )
- Code p1259 comes up on Integra
- CAMS
- *****HAHAH, EVERYONE.... READ THIS!!!!!
- how to check my codes?
- Nikasil only on FRM or no?
- Apexi vafc wirring question!!
- running rich
- bumper install
- wobbly shifter
- dpfi dizzy on a si?
- crome or uberdata
- SLIM FAN HELP ....TURBO??
- excessive oil burning....WHY!?
- How do you maintain rods?
- cams for a DA9
- 98 boosted teg stops reving at 4500 rpm sometimes
- Shifter bolt problem!
- compression test
- not just another D series oem tranny build
- This is what we call TECHNOLOGY
- front main seals
- Head Gasket
- Engine rattle
- New Medusa Fuel System?
- obd0-obd1 conversion
- anyway to check if piston rings are ok with head off block?
- can this work
- CEL 65 What to do?
- d16a6 pistons in z6 block? possible
- Greddy E-manage question! Help
- M2B4 Help!!!!!!!
- switching msd boxes
- NO POWER???
- VSS speedo dont work
- Oil On Top Of Pistons??
- h22 base map program
- integra ls long block, short block, what are the differences, pros, and cons? and how can u tell apa
- modify b16a ECU PR3 AT to MT
- help "cluster/rpm problem"
- What kind of transmission fluid?
- Help!!!!!!! How to adjust clutch pedal?
- axels
- wierd noise need some help
- jdm p72 cause diffrent timming?
- ecu question
- countershaft c-clip
- Would this intake work?
- ls/vtec, GSR intake mani, vacuum fitting help!
- How can i clean the build-up on my valves
- idle surge
- Relocate ac compressor?
- SAFC wiring in 99 coupe
- fidanza flywheel pilot bearing issues??
- Siezed motor...can't crank over motor
- Firing problems
- I searched....messed up vtec question?
- what computer do i have??
- help car sputtering at low rpm's
- Walbro In-tank vs. Inline question (surge tank application) ?
- skunk 2 short shifter
- Shops around Boston
- B21 Vtec?
- PLX M-300 vs. AEM UEGO
- GE 84mm Sleeved block... head gasket question
- new and have transmission fluid question
- KNOCKING NOISE PLEASE HELP!
- Installing a switch for the fan
- IACV question. Is there any phycial difference between a 2 wire and a 3 wire IACV?
- msd external coil pack hook up
- Switched to copper oil pressure line, now gauge buzzes with engine speed?!?!
- Low Vaccuum pressure....
- vibrant ??
- Taking apart transmission
- help am new
- How to clean valves?
- How to tell whether P30 ecu is jdm or usdm, obd0 or obd1???
- Help. Lights keep dimming. Short somewhere?
- Intermediate Shaft - Bearing / Seal replacement
- Need input on OEM 00 SI ECM
- Quick question about axelback
- New Jersey shop for swaps?
- Has anyone had any experience with 'Blue Sky Clean Air' Fuel Conditioner?
- how exactly do you tune??? (tried searching sorry if this is a noob question)
- muffler
- Little Valve Seals Question
- Will a vss from a EJ6 affect my Vtec?
- ►►► DTC P1381 :::NEED HELP::: ◄◄◄
- problem with electric oil pressure gauge
- Messed up a piston ring during installation...HELP
- gsr with itr cams make power to what?????
- spark advice
- Brake Issue
- new d16z6 starter grinds sometimes?
- Verify this Brake Master Cylinder
- EAGLE rod and ARP rod bolt need help!!!!!!!
- Best place to buy jdm motors
- SPUN BEARING??? video!
- Quick a/c bracket question help.
- No VTEC no codes OIL light??? h22a
- HELP:air/fuel guage on lean side
- 02 d17 vtec into 97 civic?
- DISTRIBUTOR QUESTION
- timing belt install question
- HELP: autometer gauge wiring?
- wiring diagram
- converting 1 wire 02 to a 4 wire?
- Reverse lights won't work on 91 teg. Missing wires?????
- how to check motor?
- what can make a car bog down
- Schematic diagram
- engine building thoery: bearings?
- k24a1 headgasket
- fuel injectors
- t3/t4 turbo Issue.... Help!!!
- Have anyone seen such water leak on H series engine?
- bench bleed MC if lines are dry?g
- Rust on my Main caps
- B20 Swap HELP PLEASE
- b18c1 head gasket
- need cam advice
- Installation???
- ls rod bushing
- Snapped Cam Cap Bolts!
- newb brake bleeding problems s2000
- Question for those who have taken apart Honda engine wiring harnesses
- axle seal
- No Spark
- Need a reliable tuner in chicago
- B16a2 header
- anyone reccomened a solid clutcharound 200$
- Cable or Hydraulic?
- 2.5 piping, 2 resonators, spoon muffler.............
- *****BAD GAS.........?????*****
- Camshafts ground down to nothing
- B16 Transmission Question.
- GSR CAI no longer fits with Skunk2 Intake Manifold?
- Spoon calipers>??
- car runs better without tps sensor; rpms stick when shifting
- Calling out multimeter experts just bought a fluke?
- Clutch pedal wont release until.....
- Shocks
- Starter signal(Yes i searched)
- D16 Mini Me Swap
- Condenser Fan not turning on
- clutchmaster fx 600
- car makes squicking noise
- Moates Ostrich - I just made a horrible realization :(
- New cam break in?
- gsr head gasket and ctr pistons
- Need help ITR wont start again
- Need Help !!
- d15b8 mini me
- B16 Cable tranny + Quaife LSD questions
- B-series Cable LSD Trans
- OBD2A DRIVE CYCLE, HOW LONG DOES IT TAKE?
- B16A7? What car came with this?
- Are the Civic EX front brakes the same as the 99-00 SI's?
- motor weight
- d15 to d16 conversion - is it possible?
- smoke from my exhaust ?
- Where can I get a Throttle position sensor for a jdm zc??
- Need info / opinion on sleeves
- Engine flooded with gasoline.... Why???
- Only One injector fires
- Timing belt gamble (do it or not?)
- cel 1 & 14
- Noise in transmission can anyone Identify this noise
- b series block external crack - leaking coolant ????? how did i do that?
- 95mm crank in ls/vtec stock sleeves good or bad
- huge temp problem !!!!!! please help!!!!!
- Tranny will not go into gear!!..Help...
- Clutch/Pressure Plate problems. Help please!
- interesting read on oil...
- Inexpensive Honda mechanic/shop needed for Civic in South Orange Country (Southern California)?
- tranny case
- wd40 sprayed on the cylinder walls?
- my car won't even move.....
- Oil Pressure *stumped*
- Del Sol power window relay? Where is it?!?!?!?
- mystery motor?
- CEL codes..
- LS/VTEC and turbo feed lines: oil filter?
- idle for LS
- Stuttering - Wants To Die When Cold B16a OBD0 - Need Help
- clutch install
- zc people look please
- urgent answer please lsd question
- Input shaft question
- piston question
- Piston/Rod mix up
- Bad gas mileage in my HX?
- B18B1 Auto Tranny into B18A1 possible??
- iac
- Vibration when idling
- OBD1 jdm p72 = usdu p72?
- y8 intake manifold help
- golden eagle ls/vtec headgasket?
- Lightened Flywheel Tech. Question...
- Possible to over tension timing belt?
- WANT MORE GREEN STUFF!
- Reading my cam?
- Can a Manual ECU start a Automatic car? need help...
- where to you go when you are trying to all gaskets for the bottom end
- ITR flywheel on b16 woes
- help!!! code 1 with swap
- big loss in high end power???
- '00 Civic EX, 1.6 L SOHC, with Manual Trans
- Going to Dyno
- 1990 Integra, dies after warming up
- STUCK VALVES? WTF 2nd head in a week!!!
- Sparking/Ticking noise from ECU??!! Boggy / Jerky ride at 3500+
- Throttle body problems
- Buddy club vtec controller help
- Just got wideband 02 bung welded but i dont think its right, need help asap!
- how do you make a Det can?
- Supertech Valves on Daily Driven Motor - Recommended or Not?
- No rod bearings in motor?! WTF?
- I NEED HELP, NEW TO THIS SITE
- 2006 ACCORD EXHAUST QUESTION?
- Looking for a mechanic
- Dead battery
- need a base map by friday
- 97 ek with gsr turbo. cylinder 3 and 4 not firing!!!!
- Need some info about my gas tank
- proportion valve ?
- help on y7 to y8 intake manifold
- anybody know where i can get a 5 wire o2 sensor for my wide band???
- problems with chipped p72
- New motor dead, any ideas?
- new si
- helpp
- High idle when the car is rolling. wtf?
- thrust washer clearance
- y1 or j1 jdm cable tranny?
- new honda emblem???
- How would I know if my diff is toast/not working?
- wheel hop?
- JDM ITR steering wheel horn hookup
- Oil consumption
- Re-torquing ARP head studs.
- bleeding clutch
- need to know where the vaccum lines goe on a sk2 manifold
- 90 degree anti-fouler fitting...
- ? Has there EVER been a final drive change in b16a transmissions obd0-1-2>?
- need help with wiring a h22 in a 95 dc
- First Build - '96 SI/EK
