View Full Version : Tech / Misc
- ignition problem
- Sensor on b17a
- flywheel cover black thing
- engine to tranny bolts!
- how to use obd2 injectors on obd1 engine?
- IC piping and exhaust size howto?
- OBX LSD on 99 civic si--install help please!
- Fuel and Spark...BUT does NOT start!!!
- ...read this question and let me know
- brake parts cleaner on bearings
- Gsr Tranny problems
- Interesting Tuning advice
- Does anyone use certain types of tranny fluid to stop grinds?
- how do you oil/grese impact gun?
- boring my b18c block
- spoon stroker kit
- Multi-Port Problems
- ::need help frpm the pro's!!! PROPER BREAK-IN??::
- Exhaust system
- B16a CFM's ?? anyone know
- axle stop ring
- compression test, howto
- Main relay? Fuel Pump? Fuel Filter? Car turns but won't start...
- Pulling out spark plugs?
- o2 sensor help
- Cam Installation
- do bi
- gsr diff and final in a ls trann help please
- icm (ignitor signal) voltage
- cel code 45
- shift light
- Car Dies or Bogs out when I go on the gas !! Help
- Which Hondata?
- Are B16 blocks interchangeable?
- extrude hone porting a stock IM
- Revlimiter only at 6500 rpms
- B series thermostat options
- Idle problem (yes, I searched)
- question about b20 cams and 93 ls cams....difference in them?
- Sputtering/Breaking up
- B16a1 stalling when clutch is dipped
- need help gearbox filler plug
- car has hard time starting
- wrinkle wall paint does NOT require primer.... dont ask me how!!!
- B16 Tranny on a LS.
- Can an IAC leak coolant into the IM?
- b16 Overheating HELP!!!!! :'(
- bypassing emanage
- Your opinions on unorthodox racing pulleys...
- Banjo Fitting B&M Guage where to buy?
- where to wire the electrical water pump?
- Spoon Stroker or High Compression B20Z LS/Vtec?
- NO VTEC
- how manys sprays do you get out of a bottle?
- apex power fc
- b20 gaskets?
- Is it really that hard to change out a synchro
- Coarse thread or Fine thread?
- vtec solenoid
- 97 Ls tranny Help!!!
- D series bolts fitting in b18c1
- 92 Civic LX won't start...
- Water Temp Gauge
- lsvtec oil leaking bad! from headgasket??
- CV joint/boot replacement question....Just finishing up. 1 last band clamp but it's the crimping kin
- chipping my ecu...
- Question on installing Hondata...help fast!
- open pins on ECU
- Squeaking Sound when i turn the Wheels
- Opinions on Zdyne Gold Super SECU?
- tranny problem
- cam caps, are these flipped backwards? *pics*
- anyone daily drive with a pro drive spool?
- Need Pinouts for OBD1 Auto TCM to ECU to Wiring Harness
- CAR WON'T START! AND NO CEL!!!
- Is there a diffrence from d16 head studs, and main studs for the same engine ?
- A6 block, Z6 head, ITB, and NOS. how to tune it?
- arias piston specs...
- Fuel pressure will flux between 35-16psi, Is it my fpr or my fuel pump?
- h22 head on h23 bottom end
- valve lash specs
- 89 CRX DX + 91 CRX SI tranny
- Building H22A bottom end, Domestic engine building shop?
- Head Porting question
- What Brake lines to use?
- Old post will not open????
- Just took my turbo kit and installed new hg..left in walboro & got cel 43
- Will a d16y8 ZEX cam fit into my d16y7 motor???
- help wit secondarys
- Battery...PROBLEM?....Starter
- 20w50 cause my car to idle lower?
- b20/vtec with almost stock gsr head?
- zc internals who makes them
- 11:1 shelf piston for ls/vtec?
- OIL FILTER PROBLEM
- Need help on a ITR manifold in a B16???
- HELP: need a quick radiator fix
- no high beams????
- 92 civic ignition wire help
- need wiring diagram for vafc
- Aftermarket revlimiter ?
- What wheel size?
- head missing cam caps, any options?
- Winter Startup Warmup
- HELP!!! Cable Reel Installation
- Chip maps
- f20c rod bolt torque spec?
- HELP..door problem?
- wideband?
- B16A2 head and B16B block Combo
- JDM B16 in a 95 Integra??
- I CAN'T START MY HATCH
- 1st gen B16 head what distributors fit
- Checking quality of New RC injectors
- JDM h22a Problem
- Which timing belt for D15b?
- Why does my temp gauge read cold?
- machine shop in new mexico
- under brace
- Bullsh!t Theory? Does Thicker oil Make V-tec Sound louder!!
- piston question
- Making the B-Series Hondata ECU FLASHABLE just like the K
- Battery in boot
- Kevlar lining on a OEM clutch disc ?
- "healthy" compression numbers for a b18c1?
- Purpost of TDC
- IAT sensor
- Rebuilding a hydrolocked engine?
- Rear Type R seat on a civic coupe 95???fit?
- help on an IACV!!!!! PICS INSIDE!
- Built B20 VS ITR which is better?
- New radiator....hoses too big
- built D16 no start problem
- D16Z6 racing cam - need help
- i'm fucking confused!!
- hondata or motec?
- horsepower
- EG/JDM SiR-G ( GSR AUTO ) swap..Need help
- auto to manual wiring help.....Reverse lights???
- Power Windows Problem
- help me learn how to change fuel sttings on vafc
- spark plug wire problem..need help!
- 97 prelude base SS - massive CEL codes!! need help please!!!
- Block Build Questions
- help! got hondata s100 back for 95 h22a.....detonation
- Where to Cryo Treat parts in Southern California?
- Clutch Pedal "popping"?
- Thread Pitch and Diameter for Oil Piston Cooler Bolt/ Oil Squirters for B16
- HONDA DISC BRAKE INFO
- Best/GOOD tool -- > valve spring compressor for B series?
- How to hook up cruise with a B16 swap
- sway bars type r rear lower control arms
- block without main caps - am I fuxored
- Help with air/fuel installation
- B16 block dosnt match B16 head!!! WTF!!
- I Think This Goes Here... Question About Putting Engine on Stand
- CEL code 21
- DOES EK coupe EXH FIT DC2?!?
- unknown lsd, what test to determine the lsd type?
- SOME FUN WITH A J30A1
- D16Y8 or D16Z6 camshaft with D16Y8 block and D16Z6 head !?
- Redoing Head internals - should i do it myself
- swapping 90 crx si dash into 90 std hatch. including front body harness...need help
- Timing so Far Off that you get ZERO CR During a CR Test?
- How do i change the VVS sensor plug??????????
- 91 obd-0 ls dizzy on a 93 ls obd-1 head.......cant get it to work, why?....help!!
- Bolt snapped what now?
- can oil pan be fixed ???
- vtec-nonvtec cam gears question
- ZC timing and starting problems
- Bogging b18c , I need help please!!!
- pinging on high compression motor
- pvc valve or pcv valve problem
- Sway bars ,will they swap?
- B16 starting issue
- OBD-I to OBD-II
- changed timing belt now no fuel pressure
- safe guard knock sensor module
- 2000 Civic Si Black Or Blue Whats Better
- h22 tb on f22
- How do you place a pic on here?????????????
- pic???
- valve train noise sound clip, comments
- Snapped end off of rear brake hard line..what to do now?
- Trouble with B16a Swap
- Is this a TPS problem?
- Skunk2 stage 1 cams? or Buddyclub spec 3 plus cams?
- Skunk intake manifold? or JDM type r intake manifold?
- saturated vs. peak hold injectors? how can i tell which ones they are? (RC)
- oil pump question
- help;classified ads
- Integra has a code 3 and won't rev past 3500rpm
- Rich At Idle/Lean Under Heavy Throttle???
- Timing Belt????
- i need help!! asap
- Need HELP HELP HELP building a strong reliable jdm b18c!!!!
- Question about fuel level gauge and sender, will this work?
- herd of these guys? WWW.EFFICIENTEXPERTS.COM
- Radiator Hose Upgrade with Fluidyne Radiator
- What type of shift linkage
- Alternative for looping heater hose?
- what is datalogging
- Clutch has been disengaging HARD after track night...
- Helicoil/timercerts for flywheel bolt
- Well i Think my G/F car is hydrolocked
- Are all 92-00 d-series clutches the same?
- b 16 oil pan???
- turbo questions
- how do you use a volt meter instrument?( already searched )
- GREATEST ENGINE IMPROVEMENT EVER?
- D series valve question
- check out this torque graph
- ground control help!!
- Who's the best TUNER in Northern California?
- anyone has pics on a Ls VSS location ?
- modify a greddy turbo d series manifold for b series
- Extented wheel studs
- VTEC on the 05 RSX feels weaker than Previous RSX's what did they change
- carbs on honda motors
- TUNING!!!!!!!
- HELP: knuckle stuck
- hondata: how will it perform on my setup?
- I think I have a voltage problem?
- Question regarding exhaust size... going small to larger...
- Questions for the B16a2 Experts
- Pyrometer in each header pipe...
- weird starting problem.. Pls help!
- ball joint inspection...how to tell?
- aftermarket ls and vtec valvesprings
- Rocker arm sequence for B18B
- speed sensor problem?
- Transmission has burnt oil!!!! eeeeek
- B16A2 ECU or any B16 ECU for that matter.......
- trouble replacing the struts...
- twin disk clutch users, check this out, help me finish my project. pics added.
- crank balancing
- Sensor help on first gen B16!!!
- Crazy sppedo needle
- Revs acting funny at idle - running way rich
- EPROM Burning Help
- DFI gen6 = need old school disc.....please help
- New Suspension Forum
- Mechanical Fuel Pressure Gauge
- Best Honda/Acura Block and Head for Boosting
- Using the 3-4-5 from a ZC JDM L3 into a D16Z6 tranny ( S20 ) question + broken fork pics...
- hondata rom editor user's come in!
- Could this work?
- Apex N1 Shocks
- obd2 gsr manifold
- Weird noise coming after car is turned off.
