65mm or 70mm T/B ????
Old Nov 29, 2003 | 12:32 PM
douglas_be's Avatar
Default 65mm or 70mm T/B ????
What T/B to run on an ITR Intake manifold on a 85MM B18C1 with B16A head . NA motor , used for track racing ?
Old Nov 29, 2003 | 03:52 PM
dfoxengr's Avatar
Default Re: 65mm or 70mm T/B ???? (douglas_be)
70
Old Nov 29, 2003 | 04:46 PM
chrisCNL's Avatar
Default Re: 65mm or 70mm T/B ???? (hybridvteceg)
depends on how much air can you flow...
Old Nov 29, 2003 | 05:00 PM
Kendall's Avatar
I'd run the 70, and have the intake manifold port matched to the head and the throttle body. Doing this could be good for as much as 8 to 10 horses at the wheels depending upon other factors.
Old Nov 29, 2003 | 05:53 PM
91integraLSVTEC's Avatar
Default Re: (dc231)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc231 &raquo;</TD></TR><TR><TD CLASS="quote">I'd run the 70, and have the intake manifold port matched to the head and the throttle body. Doing this could be good for as much as 8 to 10 horses at the wheels depending upon other factors.</TD></TR></TABLE>
ive done that.. currently sitting at 200whp with stock b16a revlimit.. cant say if it help but i expected a lil more..btw using an str 70 mm throttle body.. basic ls/vtec setup with usdm itr pistons with skunk stage 2 cams
Old Nov 30, 2003 | 10:25 AM
Ruby Civic's Avatar
Default Re: (91integraLSVTEC)
i want to know how you port the intake manifold to accept the 70 mm tb - it looks to be about 68 before you "chew" into the water line up in the corner....
500hpintegra
Oct 9, 2006 02:22 AM
Crono139
10
Jun 1, 2006 09:49 AM
dabomb
Jul 29, 2003 12:37 AM
Black R
Nov 20, 2001 06:26 PM
