squeaking brakes
Old Nov 29, 2003 | 09:07 PM
iwhichisme's Avatar
Default squeaking brakes
i have the rsr race springs on my eh2 hatch. Everytime i turn my wheel i notice a squealing type noise coming from the front. also when i go ever bumps or hilly areas i hear them as well. How do you stop this. or do you?
Old Nov 30, 2003 | 12:53 AM
hondamama's Avatar
Default Re: squeaking brakes (iwhichisme)
may or may not be your brakes. Could be your bushings, or tire rubbing in your wheel well.
Old Nov 30, 2003 | 07:12 AM
Kendall's Avatar
I've had terrible squeaking before that I thought was the brakes but turned out it was a piece of metal jammed under my car that was scaping against my sway bar (or anti-roll bar if you want to be technical).
Old Nov 30, 2003 | 02:24 PM
vtekstorm's Avatar
bro check your ball joints on the control arms they might be broken or starting to wear away
Old Nov 30, 2003 | 06:45 PM
ANPlumbing Sales's Avatar
The brakes are geometricaly fixed in the suspension, therefore occasional squeeks resulting from suspension movement could only happen if a caliper, upright or control arm component is defective (loose, broken). I wonder if you are hearing the coils, because the isolating rubber is missing!
Old Nov 30, 2003 | 08:07 PM
agrn93ls's Avatar
make sure the brake backing plate is not touching the rotor, and make sure you have a lot of material left on the pads because this can happen if they are worn and the wear indicators are scraping the rotors.
sakuraofthesea
Acura TL, RL & ZDX
Aug 4, 2012 08:04 AM
Cronousman
Dec 1, 2006 04:23 PM
ham
Aug 16, 2005 12:24 AM
E-Rok
Jan 18, 2004 03:51 PM
