View Full Version : Tech / Misc
- HELP!!! please!!! why wont cam gear fit????? i need help asap!!
- are the connecting rods good on a d16y6?
- is 255lph pump to much for a jdm itr motor?
- p28 re-chip question
- How do you tell the difference...
- injectors
- help w/ my angel eyes
- OBD 2 H22A help......
- Vtec and the speedo.. simple question..
- 5th gen prelude check engine light
- how can i test my idle control valve?
- How to install clutch?
- Cat. convertor question....
- d16a6 with p29 pistons
- d16z6 head on y8 block
- Alright All together, but wont start????? WHATS GOIN ON
- NX N-tercooler?
- torque specs on b16a header?
- will a cx pipe fit?
- to Shaving
- Gunk under valvecover? Possibly condensation?
- Need Wiseco piston help ASAP...
- my car is un even
- Does anybody know how to make carbon fiber car parts (lip)?
- AEM intake Vs. the rest
- Paying to much????
- ctr pistons in a ls... HELP
- Tein SS
- Another stupid question about TDC PLEASE HELP ASAP
- Temperature sender mounting on H22A
- Slack in shift-linkage/tranny?
- Car wont start when its hot out??
- Skunk 2 camshafts
- AEM fpr users please give me some advice.
- ECU Question
- Ordering a new clutch!!!!
- Quick question
- Piston ring placement question???
- Alternative to crank pulley wrench?
- does displacement change if thicker/thinner headgasket is changed
- Timing Belt Article
- What kinda of Torque Wrench??? (56k :crook: )
- Just finished b16a2 swap in 5th Gen Civic NO POWER HELP!!!
- Timing belt blew - need help ASAP
- squeeking slave cylinder
- 40lbs of boost or so, what will break first?
- question about my new motor
- 00 CX with 97 itr change over. I need help with wiring
- SKUNK2 valve springs
- Any good toyota shops in Philly/South Jersey area?
- help installing my koni yellows!
- cracked injectors. take a look.......
- HELP, rear drums, need help NOW...URGENT
- tranny for turbo setup?
- honda bond
- Replacing rotors
- shift linkage roll pin question...
- Distributor Problems
- b16 swap obd0-obd1 question
- Bore block to 84mm - What about the HEAD ? ? ?
- failed smog for the 3rd time
- Door intrusion bar removal??????
- jg engine dynamics
- is it true that kyb gr-2 shocks are pretty much stock replacements?
- Gasoline smell when A/C is on...?
- Turbo B20 or B18?
- Power band on Toda cams?
- ok smarty pants. figure this one out.
- Falken Azenis Sports can i get some comments about these
- LS/VTEC or Turbo?
- what kinna power out of a b16?
- What head do I have?
- could fuel pump or fuel filter be the cause of my car boggin?
- What else should I replace besides pistons???
- gauge pod out
- burning oil?
- pics of how to install short shifter in Civic
- Squeeking Noise
- steering rattle / shake
- still wont start
- Is this the cover to get access to the Flywheel teeth?
- Fuel Pressure Question....
- throwing codes....please help!!!!!
- carburated 1300
- 1st, 2nd gen b16 cam specs
- HELP, throttle body still sticking......
- ???How Lpw!!!???
- A/C into you intake?
- Car Stumped........Please help!
- Ideal RPM's to get the best MPG / gas mileage?
- JDM ITR front end installation, need help
- AEM Short Ram and Houston heat
- obd2 to obd1 conversion harnesses anyone???
- Problems with exhaust install *READ*
- CTR pistons in B17a......compression 11.4ish is that safe?!
- obd0 to obd1? where do i get it? how do i do it exactly?
- wideband 02 meter setup?
- 1/4 too small for fuel?
- what's the difference between/advantages of oil weights?
- ECU CHIPS !!!! <~~~
- failed smog again! wat to do!!!
- spoon or skunk stage 2 cams
- Compression Test on LS (B18B) ...
- Running ECU in Open Loop...
- AEM V2 Intake.....i know it's a repost and a 1/2, but i still have questions.
- PLEASE HELP! installed type-r tb and 3" intake tube. codes and idle problems!
- compression with different heads?
- Just installed distributor now engine misfires and bogs need help!!!!
- where do i get cam caps?
- Highest Compression with 91 octane
- poor mans itr dyno?
- O2 sensor wires
- where to get carbon fiber sheets
- overheating
- motor died, advice/opinions wanted...
- Does all B series(VTEC) share the same clutch system?
- vtech wiring
- A/C smell...
- What's my compression?
- will Apexi Super AFC work with a ZC or D16A1 powered 88 Integra?
- b16 swap problem
- What size bore = .10 over?
- Is this compression right?
- Alignment shops in MD/DC area?
- Exhaust For an Accord v6
- How many teeth on a B16A water pump?
- Timing Belt problem
- TIMING BELT PROBLEM...installed new belt and cam gears, now belt is getting chewed up
- Theory: Question about timing belt tensioner and timing...
- h22a cylinder and pistons.
- Fix Horn?
- g-tech performance meter
- How big of a compressor do I need for the crankbolt?
- Shocks
- Seeking Intake Knowledge
- How to get crank out? Not a crank bolt question.
- 1989 Civic DPFI Vacuum Diagram
- PCV valve
- obd1 distributor any better than an obd0?
- got water in my motor....
- vafc or safc
- need help with JDM B20B swap in a 93 civic coupe .. auto-to-manual conversion
- adj. cam gears worth bothering with on a b16?
- blinking oil light?
- I'm gonna get bitched out for this one... Another STUPID video!!!
- fuel pump ?????
- Eagle rods breaking at high RPM's???
- aem fuel pressure regulator leaking!
- temperature problems. . . need help
- HELP.....Clutch fluid leaking problem *messy mess on my carpet*
- Honda MTF - is it worth it?
- P72 and b16??
- how much horsepower
- fuel pump or not
- upgrading head on b18c1
- Is there any way to fix a creaky hatch???? did search
- b16a setup, alright?
- JDM D15B Non Vtec?
- help installing suspension
- website w/ HOW-TO on motor mount repair w/ 3m window weld...anyone remember the address?
- Intake manifolds
- Can a vacuum leaks do damage to a motor, or throw off the air/fuel ratio into a lean condition at id
- chattery clutch
- b20 swap into a Del Sol Si or S
- anyone have a junk h23block around need a knock sensor>badly..
- New dowel pins?
- b16 and b18c arp head stud the same?
- wooooooooohooooooo i got my skunk2 cams
- Timing
- Questions about swap. With Coolant lines
- JDM rod journal codes W and X?
- d16y7
- bad headgasket makes sorta clicking noise????
- plastigauging to check rod clearances...
- conversion plugs anyone???
- will a 1999 Civic EX Rear suspension work in a 1992 Civic DX 4 door?
- Help car overheats
- Fuel rail disassembly
- IAC needs coolant? why?
- How to mount tires! Hurry
- Anyone using Centerforce dual friction clutch?
- best rod for NA 9500rpm
- HID install...need help...
- GSR crank, itr rods, what rod bearings?
- Adj. Cam gears
- rounded off head bolt??? AHH
- how to check TDC
- Dyno
- b16 Sir 1 swap
- trying to find the pin out for PR3 ecu, anyone??????????
- skunk2 intake manifold
- badly stripped alternator bracket bolt..
- Can someone ID these cams?
- Why not to buy anything from GUDE.
- Read my spark plugs please?
- How much does camber increase with 0.5-0.75" drop?
- motegi rims any good?
- I know I blew my Headgasket...
- Factory bore finish on b16a cylinder walls
- Will JB Weld work on an oil pan?
- Motor swaps: A.C. braket which one?
- clicking sound from front of car when turning.
- h22a valve height (needed)
- Need help, Check light:code 21, wont idle
- HELP: b16 rev problem
- Type R head on B18B1
- how to install a greddy egt and probe?
- 2nd gear synchro problem
- How hard to convert to power everything in an 88 dx 4 door?
- i have a b16a1 engine and lsd transmission
- d16z6 build up need advice
- relocating oil filter, replacing with high flow unit
- remmoving the harmonic ballancer from a b16?
- p28 ecu
- This may be why most Hondas won't start!
- motor swap
- Fuel Pressure help, car barely idles...
- largest width rim u could put on a 00 dx hatch???
- Some weird questions
- Need pin location info. (Searched)
- Milling .040" off
- Toda valve springs/retainers + Ferrea valves work for skunk stage 2???
- Light Grind Occasionaly...where to go from here.
- FS: Integra/Civic parts
- alternator light glow
- sohc arp headstud issue
- Bisi's CRX
- broken tranny... need some info stat....
- gsr civic knock sensor problem
- Dyno Tuning in Dallas or Austin area?
- Wierd shifter question (probably easy)
- Reseating ECU pin..
- ANYONE near Md/Va/Dc wanna make some $$$???
- Please help with my oil leak! (Now with pics)
- Skunk2 sleeves + KYB AGX.
- THIS DAMN B18A!!!!!!!!!!!!
- safe to reuse mugen headgasket?
- Tranny Grinding
- check engine codes
- Car won't START...tries very hard though...
- idle problem - help
- b16, b18, and b20 bores and strokes?
- Timing
- torque specs for intake manifold?
- cai vg2
- Why am I blowing out the clutch master cylinder?
- Is this a fair price from a machine shop?
- eibach prokit installation
- tranny upgrade question
