View Full Version : Tech / Misc
- oil pan removal
- pr3 ecu obd0 trying to chip?
- Assembling a motor that will be boosted...
- Checking bearing clearances, bearing question
- b16a, 99-01 civic si 68mm holley t.b. can I use on the b16a stock mani
- Prelude not starting
- Gear selector won't work, 1998 Accord
- transmission needs to be rebuilt
- is this enough
- Bad Master Cylinder?
- Endyn Catchcan on B18A with one block fitting...
- ls power
- had an idea for a DIY shift light
- Fluidyne radiator 1.1 cap on Koyo aluminum radiator?
- Installed CAI, now motor misfires or chokes.. Need help!!!
- tranny noise
- Skunk2 Stage 2 valve adjustment
- need help Modding a obd2 dizzy to obd1 engine harness, and the same for a alternator
- Tranny Problem
- Need help?
- oil blowing in engine bay
- Eagle Rods differences
- Deck/Block Height B16a
- ARP Bolts
- I HAVE A B-20 /TYPE-R HEAD . CAR STARTS BUT WONT STAY ON UNLESS I GIVE IT GAS????HELP/
- p30 on lsvtec
- No Torque = Smart Thinking?
- arrrgh coolant boiling after koyo radiator/slim fan install...
- ecu swaping
- f22 vtec in my 92 prelude
- Auto tranny question What causes plantary gear failure?
- Is IAB and knock needed when doing a swap.
- Clutch disc for b-series that *doesn't* suck?
- No Clutch, Stays on Floor
- built gsr head.... what would my rpm max out at?
- apexi power fc - max rpm?
- finishing quarter mile in 3rd gear with b16 tranny
- *What Engine?*
- Apex'i N1 Sound
- Spun Rod Bearing / Rod Knock. what im plannin to do next.. am i on the right path?
- Timing hard to set with thicker head gasket, please help.
- ?????????????what kind of aftermarket mounts????????
- Removing the fitv?
- clutch problems
- Cooling system upgrades...please help!! searched too..
- tranny noise!?
- b16 swap dose not run rite!!!!!!!!!!
- Motor Wont Start!!!
- How to make a 99-00 Civic harness work with 96-98 cabin harness?
- rattling noise coming from the tranny
- can bad fuel filter cause loping idle??
- idle loping/surging... please help!!!!!!!!
- Where to buy GSR tranny shift fork bushings???
- D16a1 pistons in a d16a6
- Question about bearings, I might be dumb.
- low irratic idle
- installing shifter bushings...need help
- Differences in coolant brands
- Wiring Confusion
- Y7 block w/ Z6 head
- code trouble
- GSR swap into 97 EK civic LX, what distributor to use?
- engine swap help
- i think my car is going crazy i duno how to fix please help!!!!!
- which intake mani flows better
- Wiper Switch will not turn OFF!
- Knock Detection
- b16 cable syncros
- Jspecautosports? anyone bought from them.
- Are Lexus brakes similar to Honda brakes?
- head porting question, blending valve guide and port ceiling
- new clutch=problems...stage 3 supposed to do this?
- Warm Start - Car Bogs n Shuts Off (TE ng55, gm 3 bar) WHY?
- D16y8 HP Upgrades/Recomendations?
- Electronic Parts Catalog
- Tranny rebuilers in SoCal
- burning ecu chips?!?!?!?
- Seriously WTF?
- What in the bloody hell!!!! Please help!
- Chipped ECU issues.....chrome, moates burner etc....
- NSX Rear caliper equivalent?
- Sputtering when cold
- Big idle problem (searched MANY times)
- whats the purpose of coolant lines to IACV
- ls/vtec oil fitting
- blue print the block?!!!
- Axle loose in transmission
- Best Tranny oil and engine oil to use???
- Z6 cam in a6
- loping idle and CEL codes
- throttle position sensor question
- New tranny or re-build???
- stock head flow question
- ls knock sensor options
- turbo/gearing for a high horsepower sohc, time attack not drag
- Killing o2-sensors - read my theory and please chime in with solutions. (searched yes)
- mixing lacquer and urethane
- Tranny or clutch problem?
- No brake pressure
- Not getting spark and other weird electrical issues.
- auto zone gasket kit?
- mixing different piston rings??
- tps and iat codes
- speedometer?
- low voltage/temperature guage acting up
- Reliable Jax shops
- Etching on connecting rod?
- 90 CRX Si- replacing engine.. Can rear mount be put in last?
- siphoning gas...
- MAP sensors.... what's the dif from one on firewall and one on TB?
- Good body work near Annapolis Maryland?
- DA abs to non abs conversion gone bad please help!
- how can you clean bearings?
- Barb fitting shaped like a Y
- cooling question
- quick spring retainer install question. for all you mad mechanics
- Ys1 confusion
- b16 cable rebuild
- What is the ARP part number for a d16a6 headstud kit?
- engine wont start
- jdm vtec wire
- Car blows headgasket then makes higher compression???
- oil pan drain bolt stripped..?
- ATS Carbon LSD
- trouble after doing valve seals!! help!
- obd1 b18c into obd2 car using obd2 car harness and ecu jumper harness
- any chicago burbs car meet up?
- Ground wires?
- 1992 Accord Automatic Tranny: How does mine work?
- B16 Tranny Woes
- wiring an o2 sensor
- can you guys tell me what diff is this
- transmission problems ??? help me !!!
- Crome Tuning, AC related overheating
- car won't start 97 civic. cel 15
- 1986 CRX overheating???
- clutch problems
- fuel pump?
- having problem tuning my car with zeitronix 3.5 bar map w/ hondata s100b..
- 93 Si with d16y7 wiring problems
- Wiring....
- Apexi powerFC plug and play for B18B obd2???????
- seatbelt light keeps blinking and beeping!
- 91 civic won't start
- zc won't fire up...can't figure out why
- Crank Trigger System
- Anyone ever replace a radiator fan switch on a b16a?HELP,HELP!!!!!!
- jdm d15b
- JUST INSTALLED LS swap....
- civic guage cluster swap
- valves coming out of adjustment
- ENGINE/MOTOR TERMS...
- Harmonic Damper really needed?
- TECHNICAL smog/BAR related help plz
- Anyone got a write up for LS rods in D16's?
- b18c1 block / b16 head arp head studs
- Drat! Lost ARP Nut for Headstuds, can i use any other high quality nut??? Plz Answer
- tenzo seats good?
- cable clutch...hydro tranny
- ordering honda bearings online?
- DAMN it..I think my project car is toast. Crower Cams Problem
- axle seal will not stop leaking
- are all pr3 pinouts the same?
- JDM TYPE R, Injectors wont send fuel
- Cincinnati tuning shops.........Any experiences would be great good or bad...
- Every cam cap cracked.. how?
- exhaust size vs horsepower
- Torque Specs
- Poorman's ITR???
- Running only ONE slim fan on integra sized koyo...
- Swaping engines. OBD help.
- Oil Leaks in Ports/ Ex & Int.
- not sure
- h22 pitons pin question
- recently purchased 93 si
- need quick help
- need help with datalogging cable
- EG with ITR dash...need help with wiring guage cluster. ANYBODY HAVE WIRING DIAGRAMS?
- Dimensions
- pm7 pistons/rods on d16a6 crank in d15b7?
- jdm itr lsd in a b16
- Good Mechanic needed in the Bronx, NY
- bleed brakes after/before pads and rotor change?
- Obd-2a to 0bd-1 harness...Need to change my distributor?
- Tech Question
- Help: Toda cams set up questions!
- what would you suggest? rebuild/stock motor replacement
- CAm Gear Probs
- civic 4dr wiring help!!
- Need to rebuild a transmission
- 4 wire oxygen sensor ECU pins
- need help with itb's and afc
- p28 chipped with skunk2 running a b16a gen 2 in a 99 coupe UBERDATA suggestions. ECU GURUS HERE PLE
- please help me out(tranny)
- Car shuts down by itself when pushed too hard and shoots fireball
- ECU pricing
- 80 Miles on New Felbro B16 headgasket, can I Reuse? or should i just retorque headstuds.. read
- I.D. these enkies!!!!!! please
- bearing clearance part#5M1959-std acl? maybe not
- Need my P28 ECU Chipped
- short shifter
- Is this true? You tell me...B20 related
- oil pan gasket b16
- Clutch Pedal issue = /
- anyone know about ac systems?
- Fast Idle Thermo Valve Question
- What car was sold with a S1 cable tranny?
- tranny housing
- Loping Idle
- upside down head gasket????
- Torque specs on oil pan bolts..
- Gear Ratios, good setup FI
- Map sensor problem
- swaping a 38mm to 40/44mm wasetgate diaphram
- car is shooting fireballs, shutting down and its pretty much stock
- ****HELP! after rebuild no spark!! HELP ****
- Twin disk clutch
- SIZE OF FUEL RAILS TO FIT BIGGER INJECTORS
- 99-00 ex ecu
- HELP! Just built my b16, put timing belt on 3 times, tell me if this is normal..!
- Car running lean cruising speed
- CEL in EG?
- Can I use this distributor with this harrness on this motor?
- Longblock and shortblock?
- Splicing O2 wires together
- is integra type r oil pump better than reg. b16 oil pump??
- Helicoil removal extraction?
- quick question, are all b series(including b20) half/intermediate shafts the same?
- tranny swap in a crx
- Can I use this distributor on this motor?
- Having some problems, please help!
- *Tuners* Check out my Crome .bin please
- dim cel
- Boosted v-8 .vs. boosted V-4 with same compression
- D16Z6 what modifications?
- too much brake dust!!
- B18C5 lacks 100+ hp, bogs, sputters - stuck on solving this issue
- v tec wiring problem?!
- HELP transmission will not slide back on....
- Another DAMN PROBLEM! VTEC Oil Pressure Switch!
- Bad intermediate shaft keeps f***in up seal? any help?
- Apex'i VAFC2 or Greddy Intelligent Infometer
- Which motor mount bracket? help!!!
- Help with Missfiring at 4k..!!!
- Timing Belt Tensioner Problem
- Can anybody help me with this wiring the 2nd 02 in a 96 Dx obd2
- CYP CODE 9 - Have 130ohms at all 3 sensors in dist & no continuity
- Notches on b16 cam gears align however Intake arrow points up, exhaust arrow points up, slightly to
- place to get bottom end balanced
- Header
