- Why is it that when you start your car....
- Taking off front rotors.
- how to clean inside of engine?
- Timing belt question?
- CRX Gauge Cluster
- Quick question about my disc brake conversion
- Exhaust falling apart
- Whats the Highest Compression Ratio that can be put on a integra?
- Knock in Suspension
- new barke pads. OE or Bendix?
- Dark Smoke at WOT
- APEXi V-AFC Question about the vtec controll
- S2K Steering Wheel in ITR?
- Question on LS/VTEC?
- Why do my brakes squeel and make noise?
- F#*K....Rounded off every friggin suspension bolt...
- Need a question about the B18C1 Intake manifold answered
- Distributor dying...help
- is my clutch gone???
- GSR tranny parts on B16 tranny?
- Blitz PowerMeter....anyone have?
- Why does it do that?? Tech Q
- Anybody know what the ECU for an '01 GSR is?
- Anyone ever had a block fixed that spun a main bearing?
- vacuum on NA car
- conversion for spring rate...metric to us
- Shock compatability - '99+ Civic Si & '94-'01 Integra
- Block height on a Gsr Vs. Ls?
- how can i PROVE that i am burning oil
- rotten eggs
- What do u think?Yes/No???
- seat belt retractors
- ctr pistons with jun cams????
- What is the ideal suspension reaction??? for FWD car :p
- my dying lude :(
- Any good place to find a motor
- Which Cluch???
- Suspension bushings?
- Help is rough idle
- H&R SofSport vs Sport vs ITR vs prokit
- Me Again...Engine Geometry Reference?
- HELP problems with tach..........
- h22 in del sol
- A question on exhaust gaskets/oil filters/lemon laws....
- ALKYHOL!!! YEE-HAW!!!
- weird suspension sounds
- Need serious help with my gsr engine.
- Engine problems, please read!!
- Tokico Premium Performance Shocks???
- milled head?
- Correct Engine/Models?
- OT: The FI Hostboard
- Infamous header question?
- fuse 24, vehicle speed sensor circuit
- car stalls when turn on the headlights?
- What size slicks should I use???
- replacing cams in DOHC
- help me locate a muffler shop in Houston
- Thinner head gasket?
- Leak Down Test
- secondhand b16a2....have i been ripped?
- APEX'i ITC
- C Clip on Konis
- Quick, Dirty, Cheap Build for a 1.5 SOHC...and...I'm stupid
- B18CspecR conversion into an EG civic hatch question?
- MSD Sport Compact Ignition
- speedo doesnt work in the civic
- b18a Header fit on b18c1?
- Will b16 tranny fit on B18a block?
- Crower Cams
- My 1990 Accord is not well - Please help!
- possibly getting new tranny....new axles needed?
- wire for tach in ecu
- Anyone use a 22mm rear swaybar on a CRX Si?
- shaving a head does it do alot?
- Anybody wanna give me some advice on why my car is puffin blue smoke?
- cable clutch tranny on a 92-95 civic bracket
- factory tach on aftermarket ignition
- reading ecu trouble codes on 91 civic si
- Hey Gubo22, I could use some help
- CV Boot replacement
- code 22
- Best Guess for Cam Adjustment?
- Accord valve adjustment help...
- Help with new clutch install.
- clunk with new clutch. please help!
- knock sensor problem ?
- HX wheels.....Spray painted or powdercoated? Give me your Thoughts!!!!!
- Field's AFC VS Apex'i S-AFC
- Head swap ???
- Shift kit or Torque converter??
- Will this NA setup get a b16a2 into low 14's???
- Anyone interested in VERY cheap porting work?
- What is a Torque converter?
- engine drop
- Whats the proper form of downshifting?
- 91 Civic EX auto tranny and 88-89 teg ecu
- Short shifter problems
- Fuel limiter
- need help with my rear lower control arms
- How do I hook up the horn on a JDM wheel?
- Rims???
- Clicking noise.
- Milling the cylinder head!
- It's Summer Time! A/C help Needed!
- how long did everyone stock clutch last?
- Still White Smokes
- low compression, your thoughts?
- BIG PROBLEM... Field V-SFC
- Teins HA help????????????//
- Can you check for bent valves by doing a Compression test?
- 98 GSR distributor = same as 94 GSR distributor?
- new clutch need help....
- Do I need plugs and wires with a turbo?
- H&R springs better than others??
- You'd think this would be simple...but no
- I really need some help!!!
- dying battery
- Engine swaps, Do it your self, or let someone else do it ??
- My SOHC better scream after all this!
- wheel size VS wheel weight
- Re-locating batter to the trunk
