View Full Version : Tech / Misc
- Anybody ever use Motor Honey? Problems.
- distributor cap help
- Code ?
- convert an OBD2 Alternator to OBD1
- Connecting My Laptop to a TV, Not sure what connector I need
- Printing a PPT as a PDF
- CD burner is not burning
- Cannot renew IP address
- Manual for car states 10w-30 for 86F+ temps but 5W-30 for below 86F
- This sound like a fuel pump about to die?
- cam id??
- how much rod stretch ?? eagle rods in B18B
- weird idle
- honing and deglazing
- 92 honda civic wiring problem
- cold air intake
- overbore vs. stock bore
- Bride seats bracket help
- Fuel Woes
- Battery Light On New Swap.
- full obd2 engine and harness on obd0
- HELP: Proper way to install front sway endlink ( 94-01 Integra)
- Integra running rough under load???
- Brake light switch?
- hesitant start? spark plug wires maybe?? easy ? please help
- OBD2 car w/ jdm OBD1 engine swap problem
- interior work
- B18b1.. question...Bent Rod?
- What oils in you b16?
- Vtec Valve Spring Seats
- Weird rev limiter problem - D15B2
- Transmisson??
- Bolts Stripped Possibly?
- valve seals recommendation
- DISTRIBUTOR HELPPP!!!!!!!!!!!!
- DSM injectors junked?
- bunch of lil questions
- F20B Harness & ECU
- MSD installation
- Need serious help. Vibrating noise in front suspension past 45MPH
- please help me out, Honda-TECH, DD 99 Civic engine prob
- Radiator Fan Problem!
- Recommended brand for dizzy cap n rotor?
- timing marks
- removed ventilation system question...
- ARP Rod bolts, LS/VTEC
- California replacement motor
- UPDATE Civic project
- help...car ran fine now wont start
- help with wire harness
- help! engine scratching loud sound
- b16a2 head b20b block, do i use gsr head studs?
- found out what was wrong
- Is my clutch slave cylinder bad?
- VTEC Engagement Questions
- Tire upsizing?
- camshaft identification
- Ever have a bad crank sprocket?
- what is this?
- PDL/PW conversion to manual?
- horn don't work (help) 98spec itr jdm
- JDM 4.785 VS USDM ITR 4.785
- power steering help
- 2000 Civic Project! PICS INSIDE
- EF SEDAN SEAT PROBLEM.
- need help... codes 4,6,10 on crx
- ECU?
- NEED HELP ASAP!!!!
- Engine wiring help/suggestions needed ASAP, F23a1 downconvert to OBD1
- mesalinous
- Belt Question??
- p28 to to p30
- Eratic tachometer readings
- Modded B18C1.. Rough Idle, Smoke, Knocking
- RHD Conversion, the easy way.
- '97 4-2-1 header vs '98 4-1 header
- Intake Question
- wich seats to go with?
- Question about rack guide adjustment
- why am i burning oil
- What is this part????
- 00 civic ls vtec not starting!
- Removing wrinkles on a hood bra!!?
- Boost control
- b16b hitting rev limit at 7800???
- 1997 Accord front wheel bearing ID
- Thread Pitch Size
- turn signal issue
- O2 sensor
- map sensor ( quick question)
- injectors
- Civic Headlight Wiretuck UPDATE
- Finished painting my garage; lower drywall edge?
- A hiccup at partial throttle around 60-70mph
- Found more oil leaks? Oil dipstick?
- 90 accord coupe EX 2.2 Auto ? on removal of transmission computer
- Let's play name these cam gears!!!!
- ECL #9 OBD 1
- Blitz Cooling performance Hose
- Shifter Question
- B-SERIES TRANS Q?
- longitudinally mounted D/B Series transmission options?
- HP loss from Crank to the Wheels
- EK oem sideskirts fit eh9?
- swap b18c into 96 civic
- AEM wideband froze HELP
- 90 EF, CEL code 12, code 17
- help! valve bolt snapped...
- wiring vtec help
- Timing belt broke easiest way to check valves?
- UPDATE Civic Headlight Tuck
- A/T to manual
- Removing PS COOLER???
- Good Tune in California
- B18a1 idle issue
- How do i check if my ecu has gone bad on my 98 accord
- ARP Head studs B18C Torque procedures.
- ep3 seats in a eg coupe
- Shifter Thread Adapters
- EG fog lights installation help? Guide?
- Starter problems??
- Who uses turned cranks?
- B18c gsr block with b16a head
- Why do cold engines run rich?
- crank bolt
- Axle Nut Stuck on good
- electrical prob help plz
- need help locating intake air temp sensor
- honda wiz chime in 2 coolant lines need help tonite please
- B20 vtec turbo w/block guard?
- Feeling like a noob: vtec issues
- Car wont maintain temperature??
- ef b16 help
- How to lower emissions? H22A
- FG2 Civic w/ RSX TB ABS
- 2.3 stroker high comp h22 troubles??
- HELP: Clogged Fuel Filter? Unsure
- 00 SI b16a2 engine rebuild help PLEASE!
- Stolen motors (VIN NUMBERS on ENGINE)
- mini-me intake manifold HELP
- Gas tank restoration?
- type-r crank w/ ls rods
- another idle problem thread.. but not your average. (turbo 'B' on ectune)
- Need Opinions on Headgasket Issue
- 98 ek cat converters, 1 or 2?
- ticking,oil burning= bad distributor
- Why is my VTEC solenoid valve leaking?
- Hi-tack or rtv for waterpump
- key stuck in ignition
- random misfire please help
- Oil Pan ???
- WHERE can i get this piece????
- where can i get this piece? need it badly!!!
- are all b series alternators universal?
- shift linkage help please
- Does putting an automatic vehicle in neutral ruin the transmission?
- wheel bearing abs and non abs?
- Will obd1 PR4 work with electronic VSS?
- Possible to recalibrate Odo?
- Stock b16 TuRbO HelP!(DONE RESEARCH)
- SMOG EXEMPT??????
- Pushing exhaust further out?
- Reusable internals?
- need help with jdm d15b timing
- Hood Prop/Easy Fix?
- high idle need help please
- Cruise Control 93 Accord EX
- Coolant Line & Intake
- car shuts off while drivin. need help
- idle fluctuation after warmed up
- What else can cause an oil leak near cam plug/distributor?
- coilovers
- whats the best ecu
- Napa Valley Fun Run
- Civic door won't open from inside or outside FIX (no drilling)
- Fresh Rebuild. ( cant idle ) but run's
- wtf need help plz clouds out of my exhaust
- oil pan gasket keeps leaking!!
- Need help with del sol gas tank
- 98 Prelude intake manifold removal
- I don't get the wiper delete plug install...help?
- Car will not start, Please help.
- Water light comes on during hard braking?
- Need help with cel 21 and 10!!!!
- engine stall (video)
- Godspeed Rear Strut Bar. Not Satified.
- timing belt replacement for 05 civic
- civic 2001 coil on plug (anyone know the coil specs)
- b16a2 and gearbox
- help with ls/vtec
- Can Running a Motor With NO Thermostat be harmful to the motor?
- what does this plug run?
- Oil ring failure? Take a look at these pictures....
- b16 tranny flush?????
- Help! Crazy coolant problem
- Wireless Dongle ?
- Firewall Question
- Wireless Computer Networking Problem
- BSOD WIN 7 Shutdown when idle
- windows 7 audio driver problem
- does anybody know anything about honda sankei mufflers?
- blox coilovers
- b20 pcv Help! b20vtec
- Intake chocies
- D16A1 and TBI
- need swap help
- problems with b18C6 swap in EG6
- Y21 Trans - LSD?
- teflon tape on brake line...?
- b20vtec
- Crankshaft Question?
- B18A1 HELP!!!!!!!!!
- help on timing
- help! (b16 turbo spark)
- WHATS BETTER DYNO TUNE OR STREET TUNE FOR DAILY DC LSV
- WHATS THE BEST CAR FOR TURBO DC DA EG EK CRX EF
- 90 DA WIRING UNDER DASH WONT LET CAR STAY RUNNING OR START
- TSK sound canceling
- b18a1 rod bearings clearances issue...
- EF light wire harness
- Problem starting car
- high idle on my b20vtec turbo help please
- maybe someone here knows
- HIGH IDLE
- d16z6 with comp stage 2 cam and skunk 2 cam gear HELP!!!
- vtec solenoid (oil pressure switch) thread size/pitch?
- chipped p28, im confused.
- Using starter to remove harmonic ballencer bolt.
- 2000 Civic Headlight Tuck. Help!
- Weird Heat/Temp Gauge Problem..
- Vibration arrrgh
- em1 rpms wont pass 3500
- b17 revving to 9k?
- b16 misfire
- CAR Problem...HELPPPPPP..
- Honda cel code 9
- Car stalling and wont restart until it cools down....
- Wire Up 02 Sensor
- obd2 8pin plug on obd 1 distributor Help!!!!!
- vacuum
- 2000 civic wire tuck Help!
- car wont start
- asap help me
- pr3 question
- So this is what VTEC sounds like!
- E Brake.. clip??
- headlights on and no cluster & tail lights help!
- The dangers of running open header?
- crome pro datalogging readout through sony vaio to pioneer avic-x910bt dounle din
