View Full Version : Tech / Misc
- code 43? fuel system
- issues with cold start (now it doesnt start at all) SEARCHED PLEASE HELP
- need ebrake help asap please
- Help with Installing Aeromotive FPR (P/N 13105 )
- need help with ac
- Testing Electronics With Engine Out???
- cam gears arent sitting right
- Check these pistons out for me!!!
- Golden Eagle head studs
- obd2 to obd1 now getting code 21
- Replace tapered roller bearing with ball bearing for LSD install?
- Milky Milky Milky stuff????
- i looked all over (k series)
- Add knock support on P28 ?
- mini me question
- master and Slave cylinder
- s4c b16 trans issues
- Aligning motor to put timing belt back on?
- lights problem
- Ebrake Stopped Working Help!!
- What Throttle Cable to use on b20vtec?!?!?
- Front lip repair??
- Gauge hook up
- Tuning Shops
- 1/2 Sized Radiator
- Vibration when accelerating.
- C-west replica side skirts. how do i put them on?
- 240,260,280z v8 conversion
- New Built Motor...starts..but dies right away...HELP.
- Clutch Rattling
- what does bore'ing your block do?
- DRT's website? phone #?
- importbuilders what a joke
- does a odb1 dizzy bolt up to a odb0 b16
- forged crank?
- O2 sensor issue
- scretching noise while taking off in 1st
- How safe is Zex
- Charcol canistar and hondata/P28
- Fixed a surging idle/off idle stumble
- P06 Chipped ECU - VTEC Doesnt Work :: HUGE PICS!!!
- oil filter
- Hydraulic to Cable Gearbox Conversion
- Apexi Power FC 4 Turbo LS?
- help!!
- CV joint issue
- 92-95 Civic EG Brake Pad Rotor Booster Master cylinder Upgrade
- help - strange problems after swapping injectors (VTEC crossover changed, and fuel cut i think)
- Safe to drive with this check engine light?
- Hondata romulator question
- input shaft bearing dumb question b series
- Wacky TPS
- Is It Worth The Time & Effort? GSR Cams In B16
- can oil pressure sender mount on ge sandwich plate
- 01 Civic starter issues, PLEASE HELP
- how to adjust timing
- AEM 1040, Neptune, Or Hondata s300
- 00' civic SI exhaust piping and muffler on a CX Hatchback?
- Headgasket question...?
- ***HELP!! Open stud stuck in the back of my block/ d16z6
- new car modification??
- AUTO > MANUAL SWAP EJ7 SHOPS IN MD
- bad valves?
- ClutchMasters Stage 4 noise????
- cam placement
- What is the best wideband?
- ITB Pros and Cons
- Cusco LSD & Genuine MTF?
- the tool warehouse put me down
- Setting my timing... impossible
- Critical Thinking Part One
- aem ems
- k20a3 in a em2 what you think ?
- O2 Sensor heating up slowly
- tranny fluid
- wireing vtec to the switch, how to?!?!
- Ok to upshift from 1st to 4th
- Tuning after a complete rebuild.....
- Obd2b Ecu work on Obd2a?
- MUGEN/ Tanabe Ultra exhaust sound clips???
- autometer egt (bung and extension piece thread size) searched
- j1 transmission parts
- need help asap!!!!!!!!!!!!!
- D17 block mount up to D16y8 head?
- I put on a new distributor and its running worse now??
- GSR Transmission differences
- alternator removale on a b18c1 integra
- Jacked car in the air to spin ITR LSD trans. Only one wheel spins...
- need help with my ls/vtec timing belt
- Need to find cheap pressure sender/transducer w/ 0-5v output
- DPFI >> MPFI problems :(
- High Idle with milled head....
- 1989 Civic - Transmission problem
- Oil Catch Can breathers
- 1988 Honda Accord Automatic Transmission Problems
- NEED A 5 SPEED TRANNY
- PCV Valve Grommet removal : Torque Strut replacement
- how do i wire jdm itr head lights to usdm gsr harness?
- CAN, BC , Any know a shop able to do LS Vtec install?
- Help.....Please!!!!
- JDM GSR LSD TRANNY HELP!!!
- Block re-build...What crucial internal parts should I change since the block is out
- Did I do this throttle cable pulley correctly? Pics included!!!
- is this head ok
- will integra type r pistons fit into gsr engine?
- Massive header dent.. Have you seen worse?
- Weird electrical issue.
- Rear disc Conv. question HELLLLLLPP meeee
- 4 wire oxygen sensor wiring
- B16 eagle rods....bearing size number 2 or 3?
- Need Help With - MSD Pro Billet Honda Distributor
- Best engine tuning/ management systems
- h23 won't start?
- Is this true?
- piston question..aftermarket
- Is there a CKF Sensor on OBDII Motors?
- CEL 14 After Intake Main Install. Also car will not Idle. HELP!!!
- How do you replace a mirror on a 04 Accord??
- I NEED HELP head gasket replacment
- Car won't go into gear, need some assistance!!
- Need Hondatech Help!
- any small radiators w/ fan switch housing built in?
- b18a & b18b crank
- MY CAR IDEAL!!!
- Code 30
- Rev Limiter
- h22 question? is a h22 a good swap??
- can there be too light of a fly wheel?
- Clearing monitors on ECU.
- B20a Rods question
- Clutch isnt engaging... HELP!!!
- engine removal help
- ef hatch
- Measuring oil: hot vs. cold engine
- OK diagnose my car :( HELP
- obd2 to obd1 alternator plug......please help!!
- need help with a few things on my new swap PLEASE HELP HAVE PICS
- S1 tranny wont shift into 5th or reverse (searched)
- d16y8 intake manifold swap, injector Q?
- manifold cover bolt
- Dearest pupil whom works for Eibach...
- Stripped Tranny Mounting Holes?
- how do u chage the idel???
- ignition problem... please help
- Who sells chip burners?
- gsr swap 3000rpm bog ???????
- P72 Fried???
- How to Recalibrate gauges??
- Reverse Lights dont work, also reverse feels odd going in.
- Fuel Injector fuse/short out......*POP*.....
- how to know if head has laready been milled?
- Civic Engine Swap
- ctr pistons on ls rods
- what do u guys think?
- Remove head or use valve spring Compressor?
- B series starter just clicks loudly and rapidly
- ECU not working
- new clutch.. HELP!
- Shims,bearings, and QUAIFE LSD
- question on ef side markers
- ls/v???
- How do I remove IACV without throwing a CEL
- valve spring/retainer compressing question.
- boosted d16z6 ecu question
- Someone tell me what ECU this is!
- Quaife lsd Install - Caution to all --> Differential Bearings from Acura/Honda out of spec!
- tensioner pulley? STRIPPED!!!!
- what the best way to put a mark for timming on a aftermarket flywheel??????
- no start w/out fuel inj resistor box?
- question about INNOVATIVE MOUNTS and more!!
- Is this Radiator Single or Dual Core?
- Replaced Input Shaft bearing..no reverse
- 2006 Honda Pilot leaking tranny
- Cam reinstall, intake cam keyway wont stay facing up?
- where to send manifold for ceramic coating???
- Okay to start fresh rebuilt engine with no oxygen sensor?
- Clutch problem
- So cal tuning shop (Crome / Uberdata / Neptune )
- whats the website where i can check my carb numbers?
- tranny oil question
- Question about Type R pistons in a B16A2
- Engine Pictures. Critique needed.
- Bismoto adapter plate ????
- vtec cutting out!
- What are the best springs retainers for this setup?
- B-series Cable Tranny Axle Seal????
- best tranny for ls/vtec?
- Weight of B-Series Complete transmission?
- vtec head choice for crvtec
- How Can I protect my engine? Cams Polished! (Raise oil pressure, 10w 40)
- Losing Pressure in clutch pedal!!!
- 2nd gear problems
- help with striped headbolt???
- HEAD GASKET????
- dumbass ground wire question
- Pressure Plate??? Clutch Cable??? Please help!!!!
- R SPEC ELECTRONIC FUEL CONTROLLER?????????
- Motor mount alignment Q
- HELP! temperature gauge only moves from C to first notch (pic inside)
- running problem.....HELP!!!
- tapered ring compressor?? where to get one?
- crx B16a1 won't rev over 6000 rpm when engine is very warm
- any difference between a 92 GSR ECU (P67 i think) and a JDM PR3
- How to turn over engine?
- WHAT HEAD PARTS SHOULD I WORK WITH???
- crome, uberdata, hondata dataloggin problems?
- another valve adjustment question
- tranny question
- pistons
- IACV help
- Engine harness swap
- SPeed Sensor Question???
- NEED HELP WITH ELECTRICAL. help plz .
- ITR, or B16 pistons, What is the compression??????????????????
- EZ sensor ID & location help needed with pics
- Should I get Hondata?
- how much do you guys think this engine is worth!?!? help me out
- engine swap help
- shift improvement kits?
- need some help with the crix
- H22 cam timing
- check engine light.... 89 b16 hatch
- Stupid engine fix - MUST see
- NEED HELP ASAP WITH CAR I DONT KNOW WHATS WRONG!!!
- Tuning Greddy Emanage on 99 Civic EX
- Noisy LMA's Should i change or deal with?
- Secondary Butterflies Question/Theory
- whats this crap on my sleeves?
- d15b cam
- who has increased their displacement on their B18C
- crankshaft position sensor malfunction?
- Uberdata tuning in the nashville TN area???
- civic D16y8 how much boost would it take...
- Clutch Question
- will the revs begin
- quetsion for the REFs???
- wierd delayed starting problem.
- Need Help asap! Somone to mic the crank journals of a b18a/b
- a/c problem not turnin on
- What's missing from this distributor?? Pic Inside...
- rod bearings size (color) for aftermarket rods
- building gsr head
- B18A1 BLown Block
- wont idle when cold
- valve adjustmen/ TDC????
- need acura part # for a 95 Integra LS hydro tranny part
- D16Y8 in Si hatch NOT starting???
- car isn't starting.
- Crome...good for tryin to tune your own?
- what mounts do i need for my swap?
