View Full Version : Tech / Misc
- jdm gsr ecu
- JDM y-1 syncro gear change.
- Will My Apexi VAFC or other electronic controllers memory be reset??
- how easy to tune ls/vtec?
- konig subzero 17s and rota subzero 17s..........question
- How long is the life of a tranny?
- Chipping a VX ecu the same as P28?
- type r ecu in 98 gsr
- strange noise from tranny.....
- ecu question!!!!!please for the love of jebus help me!
- Need a GA mechanic to finsh my swap!
- OT: Does TE37 comes with both 4x114 and 4x100 bolt pattern on the same wheel?
- auto to manuel conversion
- I'm SCARED>>
- After Market Coils
- what camber kit do i need
- b20vtec crank girdle question??
- H22 distributor on H22 in an EK running a P28 ECU?
- help...engine wont turn over
- pools of oil and gas in with the spark plugs!!
- CEL #90
- fuel prerssure, please help!!
- b20 turbo does it like turbo as much has ls motors
- What good does swapping right rear upper control arms for left rear upper control arms do for caster
- Need rebuild torque numbers for B20 bottom end...
- Need wiring diagram for GSR cluster into 92-95 Civic
- DCJDM4-1vsGeddy4-2-1
- Rotating mass balanced
- quic question
- Boring Out B16A Throttle Body
- modification guide articles
- Compression ratio question...
- Calling on all mechanics
- How the hell do I reinstall the axle??? What's the trick?!?
- What do you guys think of these rims ... (not an appearance question!!!)
- WTF?!?!
- 96+ ex into a 95 hatch
- what to do about my spring rates for ground controls???
- Tuning your Hondata 4
- fuggin smoke screenin everyone. Could it be valve seals?
- Good shock/strut that is tighter that Tociko Premium(blue)
- vtec for JDM Engine
- internal components
- YIKES.. overfilled oil.. then raced
- Hondata+J&S? compatability ?'s
- help major backfire....(long)
- Balancing the engine
- TORQUE WRENCH?
- ABS install on a Civic
- Cooling system driving me crazy - HELP PLEASE!!!
- hollowing out the cat
- Is the Integra GSR rear sway bar good on a 92 civic hatchback?
- Which intake manifold ?
- Suspension kits
- B18A specs?
- Wondering timimg mark, bad distributor shaft?
- When to reset the ECU...
- !!!! Brakes !!!
- I need someone to chip my P28 ecu....
- need help with exhaust/pipe for DragGen3
- Can't get turbo manifold off!!!!
- hi-flow cat diameter for my 95 civic EX
- Brake questions!!!
- reuse clutch and flywheel bolts or get new one?
- Theoretical 1/4 mile times
- One F'n problem after the other......
- Vibrating Shifter
- NITROUS
- 1 ply or 2 ply headgasket?
- grinding third
- whats your take on koni coilovers ?
- rod bearing identification
- is it bad to out in 5 qts of oil??
- CEL is flashing while driving....not throwing a code, just flashing....help
- any body use the Field vtec harness??
- valve cover cutting
- Adding a knock sensor to a B18B
- painted block?
- Missing cylinder...Please help!
- Blown motor!! need help..
- Clutch - what a giant pain in the butt..
- Getting Code 21..But I swear its hooked up right!!!I WANT VTEC!
- Tranny help...
- just did my compression test//
- Brake problem help.
- need help with two things
- syncro in gearboxs
- air dam
- help please...........
- strut please
- resistors for dsm injectors?
- Fouled Spark Plug
- Where the heck does this hose go? And who left this loose?
- Struts to go wth GC coilovers?
- O2 sensor acting up?
- Flywheels
- short shifter can damage transmission?
- CEL w/ Fields SFC-VTEC
- people from virginia please respond! if i put a JDM b18c from 98 integra into my 96ek coupe.. would
- need help asap
- What displacement would I have if I
- New Tires?
- master cyclinder
- Setting coilovers....
- B21 crank
- Is something wrong with my clutch??
- DC header 4-1 or 4-2-1 ???
- CFM numbers for different B series heads?
- Why so Cheap???????????
- Cam Shafts
- How to tell difference between Trannies?
- CP Tachometers
- Installed headers... now car seems to be running cold
- lost motion assemblies
- Brospeed exhaust pipe diameter???
- Need help ASAP...My hydraulic jacked stopped working!! Tuneup???
- strut
- Thinking of getting ES Oval Exhaust??
- cold air
- intake chip
- B16a1 Oil pressure question
- Bad rod bearing?
- ecu chip intake
- ---Help--- No VTEC,Speedometer,and CEL. 92 Civic Si w/ B16 OBD1 ECU
- LOW IDLE
- p28
- Vote for these 3 different grinds for all out racing (hehehe)
- 94 gsr came with b17a cams??
- timing... advance or RETARDED (me).
- B16 cam id anyone
- Love my GSR radiator in my 92 civic Si
- how to remove a really ($*(#)$*)(#$)# $#*$(*# pulley?
- Did I get hosed on valvesprings? (part nums...)
- Escalated Idle? Why?
- Stroker Kits....
- CATCAMS has anyone heard of this company?
- EDELBROCK INTAKE FOR B16 Has anyone tried it and what they thought?
- question on where to get this kind of autometer
- Tein DC2R HA installation on a 5th gen coupe.
- Will 2000 Civic Si Tokico Illumina Struts fit a 1993 Civic Si?
- Copied from my post in Honda-acura.net
- IACV problems
- Rota Slipstreams
- HELP! abs light came on and i hear a wierd noise from the right side....read please!!
- please help!! my car isn't starting!!
- Just bought some OMP screw in pedals, what do I use to drill through OEM pedals?
- LS/VTEC. . . FUEL CUTS
- My ABS engages early
- 92-95 civic ECU fuse blows out every so often..
- SSR lower control arms Ok for daily driven street car??????
- why is one side of my front suspension sagging?
- 92-95 Civic , 96+ civic and 94+ Integra interchangeability
- vafc prob.
- CODE 22
- who makes these engine mounts?
- (b18c5) type r block ???????
- b16's pistons in b18c's
- cyp sensor questions
- 403's and 402 question
- Chikara power plus hedman header?
- need advice about better cams that work best for my engine
- Modifying combustion chamber surface ??
- Knifeedging D13B crank that only had 4 counterweight , ..overlight???
- flywheel weight ??
- want dc header that are for ex got to have them for an lx
- WHAT HEAD IS BETTER FOR LS/VTEC
- which cams to use?
- why is b18c1 redlining at 6500k w/ gsr ecu??
- P28 wiring
- Need Help guys!!!!!!!
- car won't start?
- any videos of motor swaps and things done to your car?
- B series stock clutch comparo
- TURBO TIMER WIRING W/VIPER 600ESP ALARM SYSTEM. CAN IT BE DONE?
- reving problem 92 lude
- how long for coolant in block/rad to exchange?
- vtec controller
- how to check if engine is legit?
- which arp head studs for a b17a?
- Help!
- Where to order crx Si 1991 body kit for a good price
- Which Wiring Harness for CRVTEC into 1987 CRX Si?
- JG Edelbrock Headers - Goood or Baaad? Experiences??
- Where to order Bilstein shocks for a good price?
- Carburated turbo install?
- b-series engine into '88 Accord sedan?
- Jun Recall?
- quaife LSD installation problem
- Time for a new clutch??
- anyone running Jun 3 cams....how much cam timing are you using?
- B18C engine wiring diagram
- Help: Keeping the car running with Turbo timer
- Honing a B16 for OEM rings.
- wierd electrical problem with 94 civic
- Doing a swap and ran into some trouble, need help!!! How do I make this distributor fit?
- Anyone know where to get a H22A P13 ECU Reprogramed?
- HELP, LSD problems
- thanks to everyone.!!!
- SSG flywheels ???
- how important is this?
- Gains from my built bottom end?
- my clutch is sticking
- Best ECU for my setup...
- d16a6 code #1 oxygen sensor
- Best shop with prebuilt blocks??
- Question about ignition key tumbler replacement... Please help.
- LS and GSR flywheels
- COLD IDLE PROBLEMS
- Synchro or shift fork?
- wings on FWD cars....what's the problem?
- acura ABS problem
- changing syncro
- B20 12.1 compresion pistions
- HID's In Projector's?????????
- 4th gen civic front shocks on 5th gen civic?
- torque vs gearing
- 140 whp on a D16y8 NA?
- AXLES
- rear sway / exhaust question
- Does the JDM D15 SOHC transmission come with LSD?
- frustrating problems
- Need help with throttle body swap in a GSR
- Squeaky Rear Brakes?
- Math Problem: Riding on 205/50/15's for 32,000 miles = Riding on 195/55/15's for ________ miles?
- Need help cleaning HID bulbs
- need new O2 sensor, wich one to chose.
- TEMP gauge and fanS not working NEED HELP FAST
- what canshafts you guys preffer from the honda factory line up?
- Need help. anyone got pics of parts!
- I need to buy a evap canister for a 99-00 Civic Si
- cams
- CV boot (what should i do)
- JUN flywheel clutch
- car hard to start......
- REALLY weird thing happened on 90 Accord....GLOWING SNAKE UNDER HOOD!
- I hate domestic parts companies....
- Timing
- Vtec Controller Harness question
- Fuel Rail Upgrade
- White smoke coming from exhaust?.....too much fuel?!!
- Suspension height
- Mille Miglia --> made of soft metal?
- 2000 Si head problem???
- WHat year Integra Radiator fits the 4G "EF" Civic? Mines the '89 Hatch DX W/ZC
- V-afc problem,, please help
- stalling out
- JUN flywheel intall semi-retarded friend needs to know
- any good pictoral websites of clutch installs on EG civics?
- New Front Swaybar Bushings any good?
