View Full Version : Tech / Misc
- When do my Skunk2 stg1's stop making power? GSR w/ctr springs?
- pulses per revolution
- Valve lash on b16 head
- rebuilt motor, now wont start
- Need Help With H23 JG Cams
- SR20DET VS B18C5
- Condensation in the engine ?
- how to repair rear sway bar tearout?
- Shop Presses
- back fire!!!!!!!!!!!!!!!Just a little POPPIN????
- Instruction Manual for a FC-Commander (B16 orr B18) ?
- VTEC distributor question, cap and rotor interchangeable
- B18C5 runs lean down low and super rich up high. Any ideas?
- torque settings, inch vs foot ???
- NEED HELP!!! I NEED to know an answer ASAP!
- i want hondata, I have a chipped p30 right now.
- Crankshaft identification
- gears stuck
- anyone know where to get stainles steel brake lines
- obd2 harness + obd1 dizzy wiring scheme anyone?( searched )
- The Ultimate Engine???
- Water in the Cylinder
- car misfires when it is wet out. Wtf?
- Prodrive Oil Pump Gear
- wiring in a bosch universal o2-question about 2 black wires
- gsr rods on a ls crank????? is it possible without machining????
- Performance muffler for V-Tec
- HCP or Hasport?
- Motor Swap into EG hatchback problems...
- tire rubbing in the front
- Oil leak!
- Weight & HP of Air Conditioning
- Lowered civic alignment
- Would i lose horsepower by putting a sohc zc vtec head on a d16a6?
- KMS Engine Development?
- Not really a Honda question, but general ingnition question, please read on!
- Koni vs. Tokico
- Looking for drawing of crank torsional vibration, I think by Toyota...
- CEL code 9
- walhbro keeps priming??
- Chipping JDM P30
- 4Wd Conversion!
- Programing honda ecu questions
- 2000 Civic EX won't start..
- No start condition, electrical problem
- o2 sensor wire at ECU?
- Perma-Dry???
- rings on forged pistons does it take longer for them to seat
- Help with reverse idle gear question??
- 1.5 sohc to a b18 in 92 hatch, where do i check codes from...?
- Automatic Transmission fluid capacity
- Need help on wiring gauges for DC2!!
- What is the correct Ls/Vtec oil line suppy size?
- what clutch for a Y1 or YS1 tranny
- Torque on the crank pulley bolt!
- My 90 Civic LX Sedan Sticking Caliper Saga Conitues.
- obd1 conversion
- smoke problem
- Please Help, Where would you guys go for a complete b16swap?
- b16b stock injectors..
- About cleaning injectors
- Which Walbro should I get?
- OBD2 distributer/injectors?
- D15b swap check engine light on???
- i think jdm motors should be legal engine swaps
- HELP PLEASE!!! MY MECHANIC'S BOGGLED!!!
- Any good write-ups for a valve spring install with the head off?
- linkage
- Bearing sizes
- Hondata help: solid Cel & bad idle...then no start?
- LOWERING SPRINGS bumping
- HELP!! ABS light on.
- accord power vs. civic power
- Cam Timing, Plus or Minus?
- help with bearings on b18c5
- Is this a sign of a bad Clutch Master Cylinder???
- k series valvetrain in b-series?
- P05 Modded for DOHC vtec?
- type R cams
- Help with Brakes!
- h22 swap engine bog
- f22 IACV fit Type R Manifold?
- tranny oil, synthetic OK?
- SHAKEY STEERING WHEEL?
- question about cam gear
- t25g
- How to use my Craftsman torque wrech??
- tranny problems: B16 cable/hydro/quaife, etc.
- b16a sir2 swap into my 92 cx hatch
- Crower Cams with Skunk 2 Valvetrain??
- where does the wires for the vtec oil pressure switch go to?
- JE pistons stamped 81md4 on bottom, information
- Question about VAFC and no its not "WHAT SETTINGS SHOULD I RUN FOR BETTER VTEC"
- HELP!!! no spark after engine wash!!!!!!!!
- Using wrong oil weight
- auto zone lower ball joints
- How to tell the difference between B16b crank vs Type R Crank..?
- stock b16a head with ctr cams
- what should i set my vafc for boost?
- clutch and flywheel question ?
- Stock fuel pressure
- throttle cable sticking. please help
- Equus digital/electric Oil pressure gauge
- Help!..Does anyone have a DIAGRAM for jdm dc2 side markers?
- No Go on the hondata.
- Civic Fuel System
- Can I use my OBD1 GSR motor in 91 LS??
- SI wiring harness with VTEC?
- Oil Catch Can
- Need wiring help for H22A in my hatchback
- gsr crank pulley need help!!!!
- i need help look at this pic of a vtec solenoid...
- Could someone here explain final drive vs. close ration gears in Laymans Terms?
- issue with swap
- piston install ?
- motor bogs under any throttle
- Bad springs or bad shocks?
- What is the lift and duration of Skunk2 Stage 2 cams for B series?
- code 22 but i dont have a vtec engine?.
- SRR Tie bar w/ different swaybar?
- stock ignition wires with MSD?
- Ball joint rear view mirror BROKE!!!!!!!!
- o2 sensors ?
- Timing belt install gone wrong..help!
- Whats the difference between VTEC and VTEC-E solenoids?
- Quick question Does a GSR TB bolt up onto a single cam intake manifold?
- Brake problems after Fastbrakes Kit install
- eliminating vtec in a b18c1?
- ignitor install?
- 75 shot of O
- 97-01 Type R Diff, will it fit B16 YS21 Tranny?
- in need of help
- overheating issues, fans not coming on
- plx m300 wideband on jdm b16 w/ pr3 *searched
- Skunk2 drag springs
- Help !!!!! car wont start
- ls sleeves
- Accord / Torneo 1998 engine specifications help
- ¿which works better for head work?
- are used headers o.k.
- Flashing Check Engine Light?
- b20z head on b18a block
- Trouble shooting help
- b18c1 transmission gears fit on crv trans???
- disconnecting ABS on 93 gsr integra
- Bent valve symptoms?
- CAMS
- cam difference?
- strange axle/tranny question. help me out.
- just replaced axles car still vibrate.?
- weird start up today?
- Can I bore this block???
- Clutch problem (Integra GS-R)
- high voltage fluctuation, help me diagnose
- jdm honda P08-900 ecu
- help me please
- Engine building advice needed
- ? about ohms to injectors.
- Best Coil Over set-up for $1000 ....
- looking to have a itr tb bored
- oil starvation anyone?
- Any tips on installing cam, balancer etc. oil seals?
- tuning the engine.
- Parts information for F20B
- high idle comes and goes after b16 swap in 90 civic
- starting project motor question
- ARP B18A head studs on a B18B?
- Former toyota nut seeks guidance in the Honda way
- just a thought about running a chipped ecu...
- test pic again
- testing duty cycle for stock injectors
- Interesting thing happened w/ ground wires...
- Also, my book, Car Hacks & Mods for Dummies
- D16Z6 or D15B head?
- CX motor with a dpfi ecu?
- RHD Starting problems, Injectors not firing
- people w/ RC injector knowledge Please help.
- Question regarding axles. Please Help!
- seems like my transmission moved up 2 inches?
- whining noise from timing belt area!
- Plug confusion
- air/fuel ratio gauge stuck! on rich!
- Help! Car Won't Start!
- Fuel Lines
- Blitz Oil Temp Bl fitting Question not metric or standard
- mini me swap
- HID question about the brightness....
- VIBRATION!!!!!!!!
- Offset Question! 92-95 cx hatch
- huge problem with rear strut/spring!!
- Lower torque mounts...JimFab the only option? JimFab owners-How do you like them?
- Rotating wheel weight
- Brake Caliper Sticking?????
- Shifter and linkage question.
- vtec not working, not getting enough fuel?
- Diagnosing Check Engine Light
- Does VTEC slow you down?
- Used Motor sitting out and losing compression ( low engine compression )
- Need real advice! PRO ONLY
- Does catalic converter make exhausts sound louder?
- READ ME: Directs Hits Ignition Spark Plug System
- resonator restriction?
- Where to find a 2-way 12VDC solenoid valve?
- ITR vs. "other" DC trailing arms
- ABS & TCS warning lights illuminating... Why?
- gsr IM on b16 head (this is for real, I searched) ( ITB's)
- Honda Dealer adjusting my aftermarket valves?
- P72 on sohc
- What Oil To Raise Pressure. But Still Start n Idle in Winter? SAE40? 20W40?
- Asking Grade Logic Control in Automatic Trans
- Asking
- I Need Help ASAP
- will skunk2 cams for gsr work in b16?
- some transmissions q&a
- looking for some airbag suspension for my civic
- Backfire and rough idle issues please help....
- Wiring for Fuel injection Custom
- thinking of converting to boost
- Help with wheel problem.
- looking for the rigt head z6 or y8
- OIL PAN
- Explanation of "CRYO" treatment?
- fia
- Anyone wonder why Autos get EGR and not 5spd...
- mixing regular oil w/ synthetic in trans??
- Help... p72 ecu in a 00 civic Si...
- Map sensor question
- Starter stuck on flywheel
- How are you guys removing your Si Fuel Rail Plugs?
- Tuning... What should I buy to get into it, OBD1
- head swap major oil loss help!
- Car died while driving back last nite....
- Just installed walbro 255lph pump, pressure is 20PSI?!?!
- New Velocity Motorsports location in Palm Desert
- B16A2 problem, ITR pistons
- Apex'i N1 with 2.5" Piping? Will it Work?
- better street cams ITR vs Crane stg 2
- All motor B series how to build a dream engine.
- injector tests?
- Hasport mounts required for hasport linkage??
- converting map sensor voltage to psi?
- Hotter 192* Thermostat better for colder climates?
- high idle at startup
- Cam specs from gsr to skunk2 stg 1 (out of vtec) please read
- Exhaust
- S-1 Tranny JDM or USDM
- wiring connector
- Injector positioning ?? For those with ITB's
- Car not always heating up?
- MSD 6A install concerns (OBD2 D16Y8)
