View Full Version : Tech / Misc
- Blowing up input shaft bearings on dseries trannies
- Greddy Timing Belt?
- Newb Question on Final Drive
- Killed: My ears!
- jdm b16 cams vs type r cams
- What is this part? Vacuum related...
- Does anyone have AEBS headstuds on a b20 or lsvtec??
- i need help..i have a 2000 si coupe and im havin problems
- Rod bearings
- B18B timing advance question
- High Nox: Does the dyno fan really matter?
- Rotors for Legend Calipers?
- are exedy clutches good?
- coolant burning or something else causeing smoke?
- jdm d15b vtech piston rings
- head gasket which one to buy???
- ???smog ref a crx w/ 96 ls
- Timing question
- need tunning help
- whats up with my axle?
- Grounding system
- oil burning on new build????????help??
- integra tach problem?
- Pics of my valves... bent???
- selector shaft oil seal....help!!
- Idle Control Valve question........
- Anyone know the weight of a B20 head?
- HELP! Big Problem here..
- Anybody have any experience with Haltech e6h?
- F23 internal ?'s
- Grounding question
- Oil control jet
- mini me ????????
- Can a leaky booster cause high NOx?
- What to get for tune up
- Please Help!.......with my B18c
- Tuning Book
- b18c1 head vs. b16 head
- need quick anwser please. oil control orfice
- clutch swap in h22a eh2
- GSR Valves same as B16 valves?
- Is this way to much timing belt slack?
- itr spring on eg??
- B20 intake mani fits to B16A2 v-tec head????
- smog question?
- Help! How do you know when cylinder #1 is at TDC?
- d16y8 build
- Compression readings?
- /////help need to know how to make a poor man type r/////////////////
- coolant line pressure
- I need a guide to removing an h22a head! PLEASE HELP
- OBD0 CEL question
- gsr pistons on b16 rods?
- Help a girl out!
- car wont stall or move
- VSS cause car to run badly??
- What happened here??
- urgetn overheating quetions guys.. plz zhelp thanksss !!!
- '97 Civic Dx (light) ( D16y7)
- 2 different thrust bearings on b18a, which ones do i need?
- fuel in oil.....
- Reasons for 3rd grind besides syncros.....
- Ls/vtec Build- Oil Pump
- Are all b18b1 blocks the same? Even if they come out of an auto or manual car?
- Slipping Clutch
- Motor rebuild???
- Could someone explain to me how the plenum size affects an engines performance?
- Excessive heat seems to kill my Slave Cylinder, don't know why. Help!!
- aebs manifold question
- Milling, porting, polishing ???'s
- oil or fuel on spark plugs?
- full spool??
- valve adjustment
- gsr bogs down when shifting out of vtec
- Field VTEC controller wires
- Can running lean damage rings???
- cam springs retainers problem, please help
- How much brake fluid for a full flush?
- Comptech Springs
- tensioner loose for timing belt... now what?
- FWD vs. RWD
- ITR springs on EG9, is is possible?
- Good awys to find vacuum leaks?
- metal headgasket and Head bolts reusage?
- Anyone in SW Michigan have a wideband 02
- Failed smog...some help please....
- Still have idle/stall problems..help
- Testing a coil
- Fuel and Oil Pressure Gauges (electric)
- Power folding mirrors, Folding when turning the car on and off??
- tie bar question
- Kumho Ecsta 711 Tires. Any good???
- anyone know how to...
- Fuel injector identification (Enter gurus)
- PLEASE HELP I LOOKED EVERYWHERE...93 HATCH CONVERSION INFO FOR BACK DRUM -TO NON-ABS DISK FROM INTEG
- aftermarket for 87 honda accord carbureted 2.0 engine
- Basic ECU/wiring/sodering questions
- Burning oil, no power in vtec...
- where is the fuse that disables the fuel injection in a 1991 civic si?
- question about compression testing a motor
- JunII Intake Cam on stock valve train?
- Where can I find a Valve Adjustment Tool for VTEC B Series motors???
- O2 sensor ?
- tig and mig
- Which direction coolant flows thru rad????
- Is it safe to re-tap the crankshaft?
- upper radiator hose collasping
- 89'' crx changed clutch know it won't go.
- cutting out at 5000 rpm?..
- water temp issues... help...
- d16z6 into a 89 crx hf...what do I need?
- lowering discrepency
- Need Verified Honda Transmission Gear Ratios
- Oh SHIT!! Why my cams look like this!!!???????
- ABS question
- torque reading with long extension
- CRVTEC UPGRADE PARTS?
- help on installing ARPS on a ls motor
- i need help!!!
- ABS light
- Weird chattering from front of car
- competition clutch ...... anyone have opinions?
- good engine shop for ls/vtec near baltimore, md
- need help NGK GAP
- tach install (not 'which wire connects to what?')
- Non Honda: My Dodge Colt GT w/ evo1 brakes, evo1 fmic...
- How to do Ignition Key Cylinder Removal
- header & high flow cat
- integra dasg in an eg
- NGK gap
- Which Motor Oil Do i USE ?
- d16a6 bogging problems please help
- 3 grand rev limit, please help
- is aem uego controller compatiable with the Hondata for tuning?
- Placing of Oil Pressure Sensor...
- tie bars
- should I be concerned with the stem seal in this DA??? Advice Needed!
- what size fan do i need?
- Quick Q on wires and sensors for 0bd2 to 0bd1 conversion for ls/vtec................
- imediate help needed tranny related... vin provided..
- v6 timing belt issues
- to remove or not remove my cat..
- ABS Plastic Fabrication?
- braking axles
- fuel filter
- removing fuse when installing new part.
- power enterprise/greddy timming belt
- obd1 conversion problem
- transmission guru's input shaft bearing part number problem
- Rota C10 weight
- fuel cell mounting
- Skunk2 Vlaves: Standard vs. High Compression.
- a few ?'s about those that have a B16 Shiftlinkage
- OEM Throttle Body Question (B16A2)
- underdrive pulleys by ati with dampener? Has anyone used one?
- how to check codes
- cheap and reliable suspention
- D15 rebuild question
- Anyone had stuck LMA "Lost Motion Assemblies"
- Suspension question for my 99 EX
- Intake Manifold Hoses
- Do JDM ECUs communicate with OBD2 scantools?
- Resetting ECU with VAFC and various little problems.
- what spring or coilover is needed for..
- Axle Problems. possible answer inside:
- Engine shudder
- electrical connectors on hondas
- Problem replacing the input shaft bearing
- D16 hesitation
- I Need Help connecting spoiler light
- Suspension help
- Single Civic cooling fan VS. Dual Integra fan??b18c
- whats lighter ???
- Apexi S-AFC...
- car hesitates sometimes loss power in crx with b-16
- D series input bearing questions
- ID this LSD.
- timing gear keyway/key problem please look
- 1999 Honda civic si vtec engagement problem
- help with idle problem
- B16 Timing belt
- Faster Steering Rack
- Dyno HELP!!
- completed full engine build, now has milky oil
- My car idles low only when I step on the clutch...
- Cam Gear
- Traditional break in or like im gonna be driving it?
- How can you tell an auto p28 from a 5 speed?
- Power Steering and suspension Question
- Can you chip a....
- how much is it to resurface the block? ls vtec related too so plz read this see can u help
- HELP!! Bent Valves?
- Remoing lug stud from a drum brake (89 crx)...Quick help!
- What is the sensor in this pic (B16)?
- So I'm in uberdata
- B20 rebuild torque specs?
- worst possible situation when fixing a no vtec problem?
- Hondata software
- star on JDM p72 head?
- cable y1 with vss?
- Mother's Back to Black
- rod knock
- bent valves, can it cause rod bearing damage?
- vafc install ?
- Braided Fuel Line with a screw hole...
- how to's and general tuning prelude
- B16 intake and exhaust valve spring question?
- engine prep: cleaning
- WEIRD white smoke. Compression check GOOD!!!
- This one got me: axle clicking, replaced it still clicking!!!
- oil pump d16z6
- My oil pressure is crazy low, little help here
- Trying to determine which tranny I have on my car??
- B20B HP numbers??
- what wires should i use?
- What does a high flow cat look like?
- type r cam swaps
- Car overheating. Oil pump?
- Resevoir Radiator fluid
- Stupid mistake - rod bolt overtorque. [Possible to buy 1 ARP 2000 bolt?]
- help! bent valves?
- VTEC pressure valve CEL 22
- ignition timing on zc dohc won't go! help me please
- Testing a B&M fuel psi gauge out, does this sound right ?
- Clutch help
- engine dampner
- can i reuse my old pistons
- Headers, I need help
- B series Valve Springs/Retainers...Are they the same
- B20VTEC dowels
- fdf
- i think i messed up my motor or soemhting not sure...help..
- VAFC, can someone post there readings or pressure ?
- Just RCVD my suspenion kit for my CRX.
- Hondata S200 problem....
- Tourqe specs for a d15b7
- mechanical costs on oil pump seal
- What are the crankshaft seal diameters for a b18c1, post and flange ends????
- Oil pressure drops when vtec kicks in.
- 93' H23 BLOCK / 96' H22 HEAD / STOCK HEAD BOLTS - MAX TORQUE THEY WILL HOLD?
- Checking my Ignition Timing, VIDEO!!
- Timing belt problem
- autozone reman. axle: how long did it last on your car?
- powe steering pump question
- Traction bar gurus, your opinion on different types of driving?
- TPS help needed.
- firing
- clutch help
- heating up bent rim?
- Review turbo d motor on a d16z6 compared d15b7, just incase you have the choice.
