View Full Version : Tech / Misc
- longblock??
- easiest power source for gauges?
- EASY PRO 80B & SST 27SF512 chips ???????
- No first gear
- precision injectors question
- Hondata on OBD2??
- Clutch re engagement problem
- Car sounds like a law motor (changed headgasket).
- Postion of resonator in exhaust piping
- Need a h23 base map today!!! (UBERDATA)
- Injectors Do Not Pule - Read, Searched, Not a Noob
- looking to replace my stock clutch what is a good choice!!???!!
- will honda 5 wire o2 sensor work for wideband??
- Reverse Question D16Z6 Block with D15B7 Head. Which Timing Belt?
- Ignition Upgrade Help
- Valve stem seals not going on??!?!?
- cleaning write up 56K beware
- I need help!! Ignition errors with AEM on turbo 95 civic.
- obd1 vs obd2
- 240sx cooling system problems
- oil type prefered
- obx lsd pass. axle stuck...will not come out at all
- oil pump failure
- help with aftermarket radiator while utilizing ac fan (c&r )
- LS-VTEC Dowel pins
- Cometic Head Gasket Leaking?
- Help! obd0-obd1 swap.
- B16A harness and ECU
- Trouble with the MPFI conversion
- Need help revs funny after 5k
- Honda ROM Addresses
- Transmission Differential?? 94 LS automatic
- time for a new clutch....
- New O2 Sensors on a obd0 b16?
- non-honda help-WRX tranny fubar'd?
- GSR SWAP TO EG GONE BAD IDLE PROB
- b16 map sensor
- BDL fuel rail question
- Gsr won't start
- What's this in my transmission?
- any websites dedicated to engine parts and explanations
- battery dead?
- something you may not know about block gaurds
- Fuel tank drain bolt question; 94 civic
- 91 Integra won't start
- fearing the worst...
- engine gone south?
- Anyone Have Pics of Spoon Cams
- OBD2A and OBD2B
- SOhc problem
- Wrist pin question/problem???
- Stumped...Humming noise from front end.
- code p1259 and a lumpy idle
- 89 integra gears into a 91 civic tranny
- Y1 LSD Gearbox on D series engine
- whats headstuds do I use?
- OBD 1 Dizzy on OBD 2 Wire harness
- afraid to start B18C
- check engine light
- CLUTCH PROBLEMS!!!!
- Anyone tried this?
- Check engine light
- uneven ringlands? SRP 9.5:1
- Filtration rating of an OEM honda fuel filter?
- engine cranks for longer before starts? starter maybe?
- Power steering or no power steering?
- weight reduction question
- Gauge cluster HELP!!!
- obd-1 or obd-2 please help!!!!!
- line honing my mains? any problems i should watch out for?
- steering wheels play???
- Clutch type LSD users...
- 90-91 CABLE LSD INTO HYDRO TRANNY?
- Can anybody help me with this spring
- !!!!!!!!! FLEX A LITE AND FLUIDYNE HELP !!!!!!!!
- XSI lsd QESTION FAST!!!
- Compression test gone bad
- how to clean electrical sensors
- e manage help...
- >>Greddy E-manage trouble.. Help..<<
- How do you identify a transmission minus the vin plate?
- is oil seperator box on d16y8 same as jdm gsr seperator?
- Black box on the back of the block?
- piston size
- Vtec question?
- Can I put my catch can here?
- crx engine swap
- just to clear something about ls and b20 motors
- b16 oil pan gasket on a b18b?
- R*SR Under Axle To Close To Gas Tank A Little Concerned???????????????
- I hit my launch control while driving...
- front left caliper seizing
- what year starter do i need for b16 crx?
- How To Degree Cams
- is my head done with??
- Cam Cap order!!
- front end vibration when i'm on the gas??....
- white smoke (new headgasket)
- What Clutch??
- d16y8 to d16a6 IM swap problem
- M2B4 LSD H22A Tranny uses same parts as which USDM Tranny??
- Auto trannt upgrades
- neptune costs>>>quote for tuning for 700??
- B16 vs itr head ?'s differences
- wanted to buy/headers
- My Jdm ZC in my 93 civic is idling at 2500 rpm's and need to know how to fix it!!!
- is there any transmission for me?
- For the D-series builders...
- Misfire cel won't go away
- Why is it topping out at 4000?
- Opposite of what everone else is doing hybrid trans
- where is the best place to get replacement hardware?
- Ignition Preference
- Compression check shows 210 across the board. Is my motor healthy?
- GS-Rtranny reverse lockout problem?.
- Cable Clutch Q's
- Input on Porting an NSX Intake Mani
- How shitty could my car be running with the CEL on for the o2 and for the knock sensor?
- 89 Civic Engine Compatibility
- Is going backwards from H22A to H23 VTEC worth the trouble?
- can i use my stock EK half sized radiator with JDM GSR swap?
- Spark plug wires for a BKR7E plug to work in place of BCPR6E, D16A6 motor 89 SOHC
- electronic gauges vs. mechanical
- How to tell if a Circuitworx/Prodrive Pump Really is one?
- putting in turbo feed line
- Bad piston Rings??
- are 13" steelies too small to fit over integra brakes?
- b18b runs fine obd2 - wont idle right obd1
- FOR SALE TEGGY W/RHD
- grinding gear problem on new tranny.
- Lost all spark???
- has nayone ever herd of a vw with a honda swap?
- transmission problems
- y1 lsd trans issues
- greddy emanage question
- TUNERS ONLY!!! Which Wideband FEATURES do you like best? (not brands)
- my transmission went out HELP PLEASE!!!
- Timing belt tension
- Rapid air movement from cover, never did this before
- Ignition timing question.
- b16 idle problem
- need help on clutch problem! help please
- Camshafts XS POWER - Stage II
- starting problem need help!
- burning tons of oil!
- CLUTCH SLIPPING!! All b16 Clutches the same? Cable Adjust To Fix Maybe
- ECU problems, advice or help??? 98 spec JDM type r motor
- O2 Sensor OBD2A help !!!
- need help on my auto to manual coversion please asap
- Ticking only when decelerating
- any attempts on making wideband 02 digital monitor?
- ECU Question
- B16/B18 Headers
- Help: Where can I find a downpipe gasket?
- Intake Manifold - Golden Eagle wats ur opinion
- 88 crx b16 wiring problem
- crower camshaft question
- s300 p28
- d16z6
- Which Twin Pot calipers?
- does oil go bad?
- Hondata s300 Map Switch?
- obd-0 to obd-1 distributor ?
- GSR swap Cranks, No Spark
- ever done? ecu blinker code light in dash?
- leaning out help
- d16a6 head on d15b8
- dpfi d15b8 help
- Can you tune ITB's with Crome Pro???
- vafc settings ??
- turbo or all motor???
- I have 3 Problems with my TYPE-R tranny and somehow it still works!!! what should I do?
- Tuning 101?
- Can abs be removed???
- Any thoughts on ls/vtec with b18c5 head?
- Rev Tuning
- clutch doesnt engage..help
- Question about speedo
- Will crx brake pads and rotors fit ej8s?
- im in the process of boosting....
- breather can drain back
- d15b in 90 ef si not starting, HELP!!
- i got a question
- fuel and tuning
- CTR piston I.D.???
- METHENAL
- taking intake mani off. questions
- what torque for main studs?
- Dpfi to Mpfi
- Code 1 W/ Chipped ECU
- other than gaskets, pumps and bearings
- Smog!!!!?
- Tuning Injectors?
- Honda Civic Engine Light code
- help no power to fuel pump...
- swapping 4th gear and 5th gear into a B16
- A gas tank question
- ZEITRONIX + SAFCII RUNNING IN PARALLEL???
- !!Having trouble with GE Scattershield install!!
- engine swap question
- don't know where else to post this
- 92 Civic Wiring/Fuel Delivery nightmare...HELP
- After Oil Pump Install problemssss.......
- is the drivers side motor mount for a B series in a crx, the same as the stock integra mount?
- Anyone who has done JDM Integra conversion
- anybody have MR. gasket gauges?
- Need Help with A/C
- filling tranny fluid from the vss?
- help check engine light
- Im Not Rich-What u think of this
- B16 Head Thickness / Deck Height, Need to know if its been milled
- 5 CAP BLOCK GIRDLE
- **Blower motor sticking** (searched)
- project planning, need advice.
- Put motor in, no sprak, doesnt start?!?
- mating b18b crank with b16 rod?
- need help on rear disc breaks..
- How much to repair clutch?
- Tranny noise only when it's in gear searched help
- Quaife ATB LSD Lifetime Warranty: What is the true meaning?
- Electrical Experts Please Read!!
- Rough start at 50+ farenheit?!
- Need help with Timing
- Front main seals
- ARP rod bolts torque specs??
- Is this stage 2 clutch/flywheel setup any good?
- Need help will CEL code 10!
- How causes an engine to rev up?
- Help me choose which rod/main bearings to order!
- Sudden shutter from car and burning smell...
- RWD trans adapter ?
- Transmission full of oil! Need help ASAP!
- Weird trans problem.....searched but noone had same symptoms $$$$$$$$$$$$
- Jerry Built contact info?
- AFR Wideband Gauge Setup??
- Oil Control Jet - Installed Upside Down? HELP
- A/C system replacement
- prepairing car for storage
- Dropping the Motor
- b16 vs b17... if they are so similar, why would the compression be different?
- idle problem after obd2 to obd1 conversion. Please Help!
- my builder charging to much. help. itr-tps, throttle cable, also question on tuning
- Installed Hasport mounts
- New Stage 3 CLUTCH HELP!!!!
- swap experts- d-series dude going B, quick Q
- GSR Head & IM
- steering column
- b18 (gsr) lsd fitment?
- enigne suggestion?
- 97' VW jetta gt help
