View Full Version : Tech / Misc
- Problems with my Clutch
- Honda JDM H22A
- car running super duper rich....
- Prelude coil-over removal, and clutch master cyclinder replacement
- Exhaust valve stem seal sticking up
- crack on turbine housing
- What has to happen for the woodruff key the holds the cam gear to get sheared off??
- Tein SS or Koni/Eibach(/Comptech)?
- rebulding my b18b got some questions??
- Car having trouble starting
- injector spec
- Benen Fuel Rail with RC 310's: What FPR and accessories?
- Ever Seen a Built Motor That Did NOT Smoke?
- loud dragging sound after bottomed out... need help!
- opinions on ceramic brake pads?
- Tranny question?
- crank pulley damaged, need to replace?
- Anyone make an oil pump for the D's?
- brake ? make noises going from P to R
- import dyno tuners in DC/Maryland/Va. sector...
- head gasket ?'s (did search)
- Is MSD BTM worth running on turbo Ls?
- Meters
- shimming oil pump on d series.
- o2 Sensor Question
- Took car to the Honda dealer - bad O2 sensor
- Top speed vs AutoX TRANNY
- bleeding the brakes question!!
- Emergency brake light
- will a skunk2 95 GSR shortshifter & bushing fit in my 90 civic?
- Bearing Help Quick!!!!
- Safe compression ratio?
- Apexi V-AFC? Help.....
- Prelude Help (ECU codes)
- Apexi VTEC controller. Anyone know good/cheap store in Miami FL?
- i need brake pads and rotors!
- need help from someone in the ANNAPOLIS area asap!
- Call me an idiot
- pin # for O2 sensor
- rough idle
- Help!! Bent suspension
- What kind of resistor??
- quick suspension question
- Tein SS and Tein HA
- full race all motor ???
- APEX i Vafc
- How can you tell if cams are ITR or CTR
- Exhaust
- Koni Coilovers?
- Fuel Pressure gauge reads 0 at idle??
- What other honda/acura springs will fit an EK?
- "How to" check engine code for non-OBD PR3?
- Son of a........Rod knock + Valve slap = New Project.
- B18C1 Head Pics - 75k miles (thought you guys might like to see)
- intake manifold leak
- Are JDM/USDM ITR throttle bodies the same?
- cleaning pistons
- b16a2 knock sensor wiring
- Overheating...could I have blown my head gasket?
- Help air/fuel meter install
- Header comparison.
- Urgent: Are these ITR Cams?
- Tranny/suspension noise
- Website
- Ignition Timing Question
- 87 Si won't start...
- is this bull or what?
- in the shop!
- Interchangeable Parts
- b16a questions
- Cooling Ideas
- Clutch replacement
- HP loss with install of springs/retainers
- VAFC throttle setting detection...
- Nuespeed strutbar and FPR.
- Whats a good price to pay for a used Good Cond. Tranny?
- Oil fouling spark plugs
- anyone have pics of a coolant bypassed engine w/ the hondata gasket?
- b18c1....piston slap?????
- Anyone kan give me a semi decent n/a 12-sec. setup for an ITR.
- short shifters...who has one? do they work?
- replacing wheel studs on a Civic?
- Gear Rings for y21 gearbox
- Integra Type R headers
- squealing sound coming from driver rear side
- Gap distance for spark-plug
- obd-1 pr3 vs obd-0 pr3?
- question for LS swap
- Differences between jdm and usdm b20b
- ecu question
- SOHC Timing Advace.
- JDM steering wheel problem
- Mothballs in gas????
- flow of CRV injectors?
- Q: About Interchangability of Type R parts into B17a motor? Experienced Advisors , please help!
- b16 help?
- Honda Brake Fitment Guide
- Starting troubles 90 integra
- LS swaybar question.
- what oil pump?
- Highflow cat.
- Hondata Tuners in Northeast.....are there any and.......
- Code 22 - VTEC oil pressure switch - Help!
- First post, VX question
- B16A setup questions...
- 2nd gen teg front
- A/C problems
- how to check ECU wires?
- Transmission help.
- Miscellaneous shaving..
- question on rear camber with longer bolts and washer(s) method
- Is a 255 holley inline fuel pump too big for stock injectors on 9psi?
- will an 89 Si o2 sensor work on d15b8
- Black liquid & fuel smell coming out of exhaust?
- What is the life expectancy of Re-ground cams? (good deal on ones with 15k on them)
- just got car back from the shop..need advice
- HOW MUCH @ the dealer for................ITR
- Hood weight reduction......ghetto style. (Debate/brainstorm/converse inside)
- RED suspension
- Injector Size Question
- Chipped p72 and hondata...
- Camber Problem
- belts
- fuel injectors leaking
- Weber cams. ls/non-vtec?
- p28 chip recommendations?
- Coilovers arrived! Bag of "O" rings as well. Why?
- Camshaft specs...what do is all mean?
- Wire Harness Diagram
- 95 obd1 motor harness on a b16a2
- Help need advice
- throttle body spacer?
- trunk mod
- safc or vafc
- CRX turbo question
- coil over Vs. progressive rate springs
- Anyone running with upper timing belt cover removed?
- help me with some math please.
- Can't detach shift linkage coupling from selector rod on tranny.
- Higher FD in LS cable tranny?
- Clutch slippage
- Hondata tuners?
- Squeaky suspension
- mods to keep engine bay cooler?
- Hondata stage 4 (no boost)
- Wiring in peak and hold injectors?
- I need a diagnosis!
- oil filter cap
- What injectors for a fact plug & play in 96- Dseries?...
- what cc are stock 92-96 prelude vtec injectors???
- CEL code 15. Help!
- feeler gauges, whats what???
- Who's installed B16A Hondata IM Gasket?
- "D" Series Distributors Swap
- what distributor will work? please help!!
- puzzled on brake swap integra to civic
- itr intake manifold compatibility?
- ZMAX? Anyone use it, thoughts...
- b16a2 ('99-00 Si into 92-95 civic) mount question...
- damn c1 acting up? (need help)
- chicago area machiune shop?
- Exhaust Backpressure and Other Exhaust Pressure
- timing belt noisy after install????
- head bolt question?
- URGENT!!! please help you guys.
- integra rear mount removal
- h23 valve clearance
- shift linkage trouble!
- ways to increase compression on my d16y8
- did i installed my front lower tie bar correctly?
- 450cc injectors w/S-AFC in a 85 Si hybrid (D16A1) issues...
- code 41-02 sensor heater
- Ericks Racing ECU chips, anyone have one?
- b16a distributor.....how do these plugs wire up???
- Golden Eagle vs AEBS vs Darton
- gsr vacuum diagram?
- Question for ecu chipping experts
- Need Vacume diagram!!!!!
- I ran out of power steering fluid and...
- Any experience with Kamikaze headers vs. DC?
- WTF could be wrong with my car?
- B16a into 3g Integra can someone help??!!!...
- HKS Hipermax Damper II???
- good tech books?
- total seal piston ring = big mess (image intensive)
- how high can i rev and (hp guess)
- Theft prevention
- For those of you with Koni Yellows...........
- over reved 00 type r now engine problem
- need help removing front suspension parts
- Quick Question
- OBD0 - OBDI Question
- MAINT REQD blinks a few times once I start then it stops.
- Type R throttle body on B16 in CRX
- Serial Number Please.......
- mugen ecu prog.
- jdm b16a y1/j1 tranny
- CEL.......
- fuel injector cleaner: any thoughts?
- suspension set up
- Need help from engine builders.
- Why does many Honda drivers think that they are driving the best car in the UNIVERSE?
- erratic rpm gauge movement and car seemingly cutting off fuel *sputtering*
- sway bars
- URGENT: VAFC install help... ASAP!!!
- installing HCP front mount
- Tranny Fluid Question
- Any thoughts on a Dynapack?
- Just wondering
- would no A/C compressor affect fans?
- wideband air/fuel ration gauge. help please
- this noob finally going turbo, gauge help please.
- Engine idle up and down constantly after warm? What's ??? Where to start looking??? HELP!!!
- anyone know where to get engine codes
- Good cams for b20?
- 95 b18c1 motor in 93 civic coupe
- how to uninstall ...
- camber kit instructions?
- Cam gear install help...
- ACT 6 puck clutch price
- Q about crx cam in d15y7
- blow by
- help!! i need a new tranny
- vtec head
- 96 civic dx fuel pressure?
- 96 civic dx head to 96-00 civic sohc vtech head with mods
- how to change PCV valve
- Ideas about the lightened crank pulley fiasco (long)
- Iceman Intake Filter
- #2 cylinder not firing?
- 01 LS ECU pin-out needed!!
- 4 cylinder dual exhaust
- need quick help. how do you remove a wire from....
- GSR Rods -- no oil holes?
- Comptech problems (need help)
- GSR Gauge Cluster in a 92 HB??
- When boring block from 81 to 84+ mm, same for combustion chamber?
- Fuel Class? Any fuel expert??
- MSD blaster SS coil installation help?
- Gsr Skunk2 Intake Manifold installation problem!!! help plz.
- Help! Tell me what to do... Cylinder Misfire... ECU troub 71, 72, 74
- Auto Tranny/Shifting Hard
- b18c4...
- Has anyone done this YET
- code 14
- Worn out crank pulley?
- aftermarket steering wheel ???
- cams/crank at TDC, distro all the way back, timing still very advanced
- o2 sensor??
- Headgasket Installation
