View Full Version : Tech / Misc
- tailights, tag, intrument light not working. GOOD FUSE!
- 81 honda accord fails smog in nv
- what rear hub / bearing is this?
- leaking compression from cyl 2 to cyl 1??
- D15B block & D16Y8 head
- Coolant sensor location's? 1990 Acura Integra, Takes turn for the worst.
- Scanner Issue
- jumper harness broken pins
- need help upgrading2002 civic d17
- Wanting to build my 86 CRX need help!
- No ground pulsing at injector HELP
- A/C out on my '99 civic si, help!
- Injectors wont open
- 94 Honda Accord Speedometer
- Front lip fabrication tips
- civic eg hatch with b16a2 oem header question
- Independent Review - RAMAIR Universal Filter
- Skunk2 new LMA
- Multiple key turns to start??
- Headlight wont work
- S2000 wont rev past 6k? help!?
- s2000 failed smog High NOx
- 01 CRV won't idle after head replacement
- whats a good site for parts????????????
- fel pro head gasket kit w/everything? any good?
- cylinder head cover bolt missing.
- LS/vtec problems
- no fuel no spark battery light flashing!
- Anyone know ignition switch compatibility for an 89 civic hatch?
- Crosstour 2010 - Fuel gauge not getting to the "F" mark even when full
- What can cause this
- My civic gsr feels tired
- Ek Swap Troubles
- weird idle and misfire
- Sir sounds like a Cow! wtf!
- 99 accord v6 stalling and won't start (randomly)
- Igniter keeps burning after a month. Why? help please
- 2013 Acc Sport drifts to the right
- Alternator not charging at idle. Will charge at higher rpm
- A/C schrader valve
- is 10/60 millers oil to heavy
- Gauges on dashboard aren't working
- please help, Idle troubles...i know i know, ive searched..
- Civic missing and backfiring
- o-ring groove on block
- Clutch Issue
- B18c-r problems
- D series supertech issue
- Can someone please help me with radiator fan wiring?
- 97 hatch window problems
- HELP!!! Hit curb HARD!!!
- Effective impact speed for airbag?
- ek coupe question
- o2 Sensor
- Help! Car dies after starting
- swap sitting for 6 years. help
- Clutch pedal problems! Video inside!
- building up a j series brainstorm
- squeaky/vibrates fuel pressure regulator
- 94 Integra rear lights wont shut off
- Erratic idiling..valve noise
- A6/z6 crankcase vent spewing water but no water in oil?
- engine light on
- HELP
- cel code 4 after swap
- Maybe a bad Main Relay
- mpg's on a d16 civic
- H22 F22 Questions
- honda/momo steering wheel question
- b20b oil pump help
- Obd2 harness questions
- high compression gsr/b16 head fuel questions
- Auto-Manual Swap 96 Teg
- EMF Shielding
- B18b1 oil jet question.
- b20b obd2 swap
- A/C: desiccant replacement
- your honda parts ????
- Vtec fine untill 4th gear
- Stereo problems.
- Any VX owners out there? Past&Present!
- motor swap
- Intellitronix LED Gauge
- block cracked, fixable?
- Integra RADIO WIRING HARNESS QUESTIONS
- h23 timing issues!!!
- A note on Honda screws, or JDM screwdrivers
- Can I use a d16 ac compressor on with a b20b?
- civic 2000 wont rev up pas 4k
- p72 ecu + H22?
- '97 DX Hatchback - Lower Control Arm brace broken
- 2 Wire door lock actuator to SPDT switch?
- Crank chipped/worn out!! Will it cause issues?
- B16 ALL MOTOR BUILD ... NEED ASSISTANCE
- skunk2 pro1 cams question
- Airbag module location on 2007 Odyssey
- Switching stock shifter?
- Motorcycle exhaust on a honda car?
- 98 honda civic with 99-00 climate control help
- cruise control
- Cannot read the cars ECU?
- Arias pistons 391156
- 1991 acura legend two 4 wheels down
- Del sol has low fuel pressure in the mornings
- Where to source Wings west wing for EM1
- How do I VTEC?
- Skunk2 Pro-Series Manifold Idle Issues
- High Beams Light
- Defroster Problem
- PM's disabled, Editing disabled, can't access half the forum
- Broken vacuum barb
- Problems with Emissions, OBD1 B18B1 in 97 EK Body
- b20 vtec idle/choking up issue
- THE OFFICIAL FART PIPE THREAD
- anyone have issues with mishimoto thermostats
- Overheating while idling?
- Lines and fittings question *noob alert*
- 93 integra type r swap,Please help Identify this part near ecu
- valve stem seal question b18a1 ls
- Need Help With Racing Seats
- Overheating issues with civic
- B16a swap: code 3
- Engine wont start after wire tuck
- Easy way to Remove Crank Bolt
- Proper Idle Adjustment
- Noisy Front Passenger Seat
- 3 wire to a 2 wire idle air control
- New Member, Just bought Del Sol. Need Help
- help!
- Wire Gague
- Fuel tank mounting straps and J bolts.
- Gauge cluster accuracy
- Cleaning the PCV Valve without removal?
- Ac Clutch not engaging / Fan stays on Help!
- Two Options for fuse box & battery relocation
- fuel pump hot weather
- B16A Ignition problems
- B16 in EG swap help ( wiring )
- 200+/- Dry shot built H22 build questions
- Random leaky hose?
- chase bay vs rywire proportion valve relocate
- New HG and refreshed head - suddenly runs hot
- 1995 Integra GSR Steering/Suspension/Braking Issues Help!!!
- Why is this blocked off?
- How long til I can hit high rpms on a new build
- Need a few answers
- Need some pro input here - 89 Turbo Civic back from the grave... kinda
- Best Honda engine builders??
- honda dealership horror story again ...
- F20b DOHC to EG Hatch Swap
- B18B1 LS Engine Help
- GSR is bogging! help!
- 96 Civic IAT
- Speedmaster cnc modded B16 Cylinder Head
- harder to start when warm.
- 2003 Accord Ex
- I need help with my 2001 Civic!!!!!
- Fuel pump primes after 5-10 minutes of waiting
- 2005 element sensor ?
- V6 oversize valve availability
- car smells gassy
- h22 chipped cylinder help
- 2003 Honda Pilot wont start
- Adding interior lights
- Fuse keep blowing up please help
- 1998 Accord Wont Start?
- Random voltage loss 93 EG turbo K20
- Fix SRS 10-3 using 2.2ohm resistor
- B18c with b16 head
- Help: EG Civic with uneven parking light brightness.
- where do i find rare owners manual?
- K20z3 block a2 head??
- New Fuel Pump, horrible gas mileage
- 99 crv won't start
- stuck between omni or phearable throttle body
- 99 hatch B16 hydrocarbons
- Honda Accord 94 f22. Idle problems
- Obd1 b16a in 2000 civic si questions
- Half Shaft Stripped. Which helicoil or timeserts kit do i need?
- camshaft key way for distributer
- D15 differences?
- reputable shops in/near central jersey
- Gauges not wroking at all in DC2 cluster pls help !
- What CEL Code is this? * With Video *
- Stock Rod Width in Center?
- Blackworks Racing Products
- anyone had experience with these?
- Harness question
- Hello, Car Lover Here, But a Beginner
- Does Your Hood Act Up @ 120+ mph?
- obd1 b18b1 in an EK thermostat question
- Needing ac help quick
- Have I set up my engine block for failure?
- Benefits of backpressure?
- Someone tried to steal my car, destroyed the ignition-how do I hot wire it now?
- Kelford Cams
- Prepping headgasket mating surface
- Antifreeze got on pod filter...
- brake lights dont work on 94 accord lx
- 91 Accord will not restart after running for awhile
- fuel rail and injector spacing
- Blackworks Racing parts.....
- ctr cam ignition timing
- what can be done to a stock motor to improve power and efficiency?
- HELP! Problem setting idle and Throttle Position Sensor. OMNI Throttle Body
- Getting a professional inspection
- How to tell if AC Compressor "Grenaded"
- AEM fuel rail
- Swap questions B20 / F20B / H22 / H23
- Question about Lma's....???
- Unknown gasket
- HELPPPP
- Pitted Valves and Seats
- 01 TEG LS COUPE REAR SEAT IN 95 eg COUPE
- wiring glow gauges
- can compression drop from engine sitting for long time?
- DA abs compared to dc2 / itr abs - technical differences in hardware + compatibility?
- considering V6 swap
- Honda CRV sounds like car is
- Own a Honda CRV and need to know
- Prelude p0136 p0138 please help...
- 1st gear pull off methods
- bad b16 head? something was in there
- Q: for those who run SS an fuel lines
- h22/h23?
- Mirror
- OEM Parts v aftermarket
- Starting problem, and looking for a Honda shop in San Antonio
- EF Issues.
- Intermittent starting
- Jumpered my A/C compressor to stay on and it blew a leak!?!
- distributor troubles.
- wiring in extra sensors
- Crankshaft bolt
- What size air filter to get?
- 97 honda accord ac problems
- Reassembling top end of engine after refresh
- Going from Low imp to High imp, resistor box question
- b18c2 cams
- ge or erl
- airbag/seatbelt issue
- B16B conversion
- car running weird help
- Need Help With My 95 Civic swapped B18B1
- intake and exhaust diameter question...
- Edelbrock Manifold with Skunk2 Fuel Rail questions
- b series web cams
- crx si seats
