View Full Version : Tech / Misc
- finally opened my Fully built b20 block to see if whats in there is really in there.. help?
- pistons ?
- intermediate shaft
- Help!! Car Problem..
- WTD buy a new tranny or rebuild?
- Will these fit (TIRE SIZE ) ???
- CRX Trim?
- idle too rich,
- tranny poping out of gear & noise
- stock head studs for d16z6
- Transmission knocking noise
- Differences between, swirl pot, oil/water seperator & catch tank
- Fixable?
- Can water pump cause engine to run bad?
- NEED HELP QUICK : Alternator Power wire Question - Engine harness ..
- Tranny Help....
- d16y7 Valvetrain
- Do these clutches hold up?
- issue after changing differential in cable SI(PL3)
- OEM pulley
- should i
- Advice on chip for my b20
- oil wheight
- Stripped Allen Key/Hex Bolt
- What are some things that would make an engine run rich?
- What kind is it and how much life is left on this 6 puck clutch ?
- rebuilding questions.
- need boost controller help!!!!
- Head stud kit for LS-VTEC
- 2 to 2.5 inch?
- help with diagnosing my problem
- Surging problem after swap. Idle to 5000 rpms!!!!!
- type r throttle body help
- Neptune dealer list...
- Who did the D series tranny strip down
- Brakes are sticking, and master cylinder is leaking.
- --- novice tuner needs help in understanding fuel maps with s300 ---
- Need advice on distributor O-ring seal.
- Idle Issue w/Chipped P28
- Water in the cold air intake....ugh
- zc
- my car wont fire... wrong harness?
- ECU HELP FOR AN F20B
- knock sensor elimination
- Looking for stock B16 dyno data
- All b-series Clutch fit one another right?
- right turn and left turn noise
- YS1 cable tranny
- buying wires
- Mass State Inspection Needed!
- Car keeps dieing
- main bearing colors?
- b20 vtec
- *****Help!! GAS Doesnt Prime Sometimes?
- Weird Brake Problem
- sealing tranny casing
- modification of 92-95 traction bar to fit 88-91 ef
- engine building
- gsr swap-civic coupe issuses.
- Installed Walbro 255 fuel pressure too high
- ZC head flow. DOHC vs SOHC
- Help /w TB's how come the intake manifold is different on these 2 LS B18B
- Timing belt tension and valve lash...
- valve suggestions
- Broken water pump bolt!!!! HELP!!!!
- Soldering low voltage wires a nono?
- supercharger boost/timing question.
- reusing oem headbolts
- b16 intake mani on a b18c?
- stalling
- D16 problem.. repost from CRX forum
- Shed some light on Hondata for me....
- 90 integra o2 sensor in 91 crx with first gen b16????????
- Supertrapp muffler
- Aut to Man Conversion
- Transmission 5th gear problem
- CF Trunk Lid 99-00 EJ8
- k24a8 the name on my engine. 8 is a version?
- ctr crank pulley?
- B16a2 PCV valve replace DIY
- Looking for the Best Tuner....
- Engine Specs
- exhaust manifold gasket
- Moroso pan on Y7?
- help a newbie...engine turns, car wont start 94 civic
- DC2 runs really rich at idle
- which tranny do i have
- Crank - To balance or not?
- water temp gauge or oil temp gauge
- best oem honda/acura intake manifold
- USDM and JDM ITR manifold
- Fuel pressure question
- how to install Endyn breather kit
- Weird electrical problem...main relay, no fuel pump??
- trunk light is not working
- vafc question
- Engine Problem
- How can u tell wat kinda tranny this is?
- 97 itr cam ?
- anybody have p74 95 ls stock program?
- Any harm in running a virgin P28 on GSR B18C1?
- b18 head differant from b16 head???
- Conversion Harness????
- jdm sohc with 168hp???
- odd transmission code????
- main bearing clearences with external oil system???
- Check Engine on ITR
- obd0 problems
- Ls vtec smoking
- koyo radiator hose problem
- huge oil leak (transmission)
- stock D16y8 bin/rom crome
- Nitrous in my All-Motor GSR?
- Why When i go in vtec for alittle while I Over Heat
- how to find out if motor is legit?
- My car idles high after changing intake manifold
- How To Change Rear Main Oil Seal
- NRG engine damper preload adjustment.
- EF Hybrid Swap Vacume Leak Problem...
- has anyone EVER had a problem with CAI letting water/dirt into engine an f'ing it up?
- URGENT help needed from anyone in the atlanta area...
- diagram experts
- alternator problem, need help
- need resistances for: iats and coolant temp sensor...
- New Clutch installed, Cause change in RPM's for gears and shifting?? H22a4
- b16 cable tranny isb part #
- Quick question about Quaife LSD
- building a b18....
- SOHC JG camshaft spec???
- New Motor, fuel pump wont prime
- blowing ecu fuse
- Where to launch at?
- Just compression tested my GSR Need help with results
- *QUESTION: CHIPPED TEEH on toda flywheel
- knock sensor capabilities?
- watery motor oil
- b18b swap trouble wiring
- new product line avail. thru Apexi USA
- OBD2 scan tool..??
- GSR w/lsd tranny getting a lot of chatter. HELP!!
- collector match ups?
- Oil Pan Gasket Leak
- engine weight?
- Brake help - searched
- B16b rotational assembly
- B16a Valve Adjustment "Do It Yourself" (DYI)
- No Spark on cold start up - 1998 civic ex
- car wont go to gear when its running
- power folding mirror ?s
- ECU grounded out...
- Engine Assembly
- need some help/advice on my b17 tranny
- short shifter instal
- surging
- HELP weird cooling problem?????
- Code 43 wont go away!
- b20 vtec, vtec not working
- Compression/leakdown results
- When using OEM rings do you need to file?
- a few questions
- type r or gsr gauge cluster
- B20 sleeves
- solid cel,no battery light ,and no fuel pump????
- final drive
- tranny gears
- ABS removal in DA using stainless lines Questions
- need some advice on transmission stuff (d-series)
- Aluminium flywheel warping
- Special bolt, where does it go???
- Under hood is very hot!
- Torque Wrench
- Civic 96-98 diagnostics socket
- will a y8 map run a y7 if
- pr4 ecu + hondata HELP!!
- cylinder head question
- D16z6 Valve SPrings, are the exhaust and intakes sides different?? interchangable?
- Sparkplug brands on the DYNO?
- help with seat rails...
- Rotary engine...
- Will just an Aftermarket Fan Switch Solve my Problem?
- 4-wire o2 into EG CX
- small amount inside gas tank ?
- clinking in engine head
- i need a motor for a crx.......
- gsr head on 86mm block ?!?!?!
- Help! Problem with gsr bottem end! Rebuild!
- B16 4.4 and ITR 4.7 FD fit Ls trannys?
- stock sleeves? D series.
- question about turbo
- obd2 swap question
- Is this normal?
- fuel presure= free hp
- Turbocharger math and simple theory
- Engine startup
- need to fix sun roof on crx90si !!!
- LS oil pump question (VTEC engine)
- starter going bad?
- Anyone know what OEM LSD this is?
- High flow cat people!!
- 95 Accord EX problem..... :(
- Engine Builders: Help Me Select The Correct Bearing Thickness/Color Code
- how to adjust D2 coilovers
- Unbalanced axle?
- will 1000cc injectors idle on my D series?
- how do i tune y8?
- VSS wiring colors, would love some help.
- P28 Datalogging.... possible through DLC Connector with stock chip?
- b16a/ls valve seal
- I HAVE A WEIRD NOISE THAT GOES AWAY WHEN CLUTCH PEDAL PRESSED TO FLOOR.
- What could of cause this??
- 91 teg auto to manual conversion
- TUNEING MY B16
- sohc OEM LSD identification
- Help! 97 honda crv is throwing code 70 through cel, then code 15 through d4 light
- The Five Steps to Diagnosis
- P2T OBD2 b16 ECU running a mostly stock OBD2 GSR B18C1, okay?
- No Fuel! Please help
- To those with PR4's
- having my car tuned in phoenix
- help wit motors.
- Jdm ITR 4.7 FD in cable trans? Is it possibal?
- b series transmission question??????
- d16z6 rebuild
- which one of these are better?
- Codes 43 and now 15
- 1998 Honda Civic Ex - Trouble starting when cold?
- 500whp dyno graph ????
- b18c bottem end bearing replacement??
- Quick stupid question about Crome
- My set-up
- Vtec pins stuck
- Blown motor = Bad tuning HELP!!
- Does anyone know the thread pitch for B18C head studs?
- one injector not pulsing. 440, obd1 ecu,
- manifold sensor question
- K20 Swap Question
- Line bore? Cost?
- Qustion about using DIE tap kit
- valve adjustment gone wrong
- carburators on a d16z5
- Honda Chassis Codes
- Hardened metric botls?
- Ring Gaps On Hasting Rings 81.5mm w/RS Machine Pistons
- b16 tranny
- 2 questions
- Coolant loss -> Overheating, Good compression, Headgasket? (Pic of CC)
- Car in gear rpms just shoot up car doesn't move!!!! help!!!!!!
- A/C problems..
- WHAT ECU? OBD1 B16A, OBD2 CAR.
- ZC 3rd and 4th in the D series trannies Who has them
