View Full Version : Tech / Misc
- installing front camber kits????
- Rollin fenders??
- Help! I broke a header bolt...
- What does detonation sound like?
- Need help deciding what coilovers to get?
- valvespring question
- Is a Type R fuel pump better than a B16's or not?
- I need Help with my 95 Integra headlight adjustment? Please help
- What piston rings to use?
- What to do next to improve handling performance?
- timing question
- Rod/Stroke Calculator
- Engine swap help
- What U.S. trans is the same as a jdm y1 cable? Want to buy a lsd...
- my cars going CRAZYYYYYY!!!!!!!!!!
- Help DA ITR Master cylinder......
- quicky Q....heated o2 sensor
- Need specs on B-16/B18c........deck height, rod length etc.
- got a head from sohfast w/ missing cam tower #4
- Dart Blocks
- Anyone running Skunk2 cams in their car ?
- car won't start!!! help from all you knowledgeble people
- Engine harness/wiring problem (b20 in EK)
- Grounded my 2nd O2 Sensor - Is this Ok?
- Help! I need to get some shocks for some Ground Controls...
- Tranny Mainshaft Bearing Question
- I need some new wheel lugs / locks... Any suggestions?
- neuspeed vs comptech rear sway bar
- New brakes, pads, and lines=really soft pedal?!?!
- 95 GSR Motor the fastest out of all the years?
- Wierd Overheating problem....
- Looking for input on my B16 buildup??
- What kind of bolts and nuts for jdm header and carsound cat
- fuel pressure regulator question
- what aftermarket rods work fine w/civic type r pistons for a b16a1 block
- SOHC clutch question!!!!
- Testing Vtec Solenoid, and pressure switch
- noisy clutch ?
- B18A Head ...Need help
- Hondata question, regarding settings on final tune.
- O2 sensor question, Obd2??
- need parts info on integra rear swaybar onto 4dr 92 civic
- Cars stalls since i install my CTR intake manifold
- LS/Vtec info!!!!!..........
- Need info on LS/Vtec!!!!.............
- question about usdm type r motor and skunk stage 2's
- system to lean or too rich (code 45) and some more
- CTR or what?
- Automatic Seatbelts
- dont have spark b18c1
- a wideband thought?
- Anyone have a link or pic of a quaife ...
- Junkyards or Pick and Pulls in San Diego
- swap overheating
- b16a
- Poor gas mileage problem I can't figure out.
- LSD q's
- How much vacuum should I be drawing?
- Does my mainrelay look okay? (pics)
- ?mods=?mpg
- 92-95 Vx model?
- My gears won't go in easily. Would replacing tranny fluid fix the problem?
- Civic type R manifold install
- installing type r seats in 99-00civic
- What does a SAFC do??????????????
- Here's a list of OBD2 codes. (If anyone cares.)
- how to bleed brakes
- Idle Surging
- primary 02 sensor (wiring question)
- ARP Head bolts
- anyone use front and rear lower tie bars?
- integra gsr or 97 civic with gsr
- LS/vtec
- need ecu pinouts for obd2 asap
- tein hr spec questions
- are these good spring rates?
- Installing the VAFC on my 1998 ITR , where can if find the best step by step instructions
- Any1 who has the 96-00 Helms help please...
- OBD2 CEL code
- P08-1?
- distributor question
- 95 H22 not gettin gas or spark in 95 Accord
- Looking For a good machine shop in NYC or LI....
- will these plugs work for 12:1 compression NA engine
- CHICAGO Peeps: who has a wideband to loan me??
- Water In Cylinders
- Engine shutting off
- How expensive is wideband dyno time near you??
- .how hard is it to replace valve guide seals??
- 90 Hatch w/ B16a swap wont start... :(
- are the 94 ls and gsr oil pan sswappable?
- Weird whinning noise in all gears on acceleration only, please help
- tanabe df210
- tuned chip for prelude BB3 F20A engine (p11 ECU)ODB1
- Tps and Vafc.
- Modifying a D2S HID setup to Fit 9006 Housing
- d16z nos timing
- Plasma Booster??
- starting problems
- How big should I go? Exhaust...
- quick suspension question.
- is a ls distributer and a gsr distributer the same
- make a 97 ls distributer work for a gsr in a civic
- fuel regulator recommendations?
- special edition b16???????????????????WTF Taller deck height???????????
- Fuel Cut-Off In Del Sol Si???
- is it possible
- what car do i order parts for a b16a2
- Dead battery=dead fueal injectors?? please help.
- injector ?
- a hole in a gsr block and a question? hmmmm...
- ecu symptoms
- help lookinng at the block!!!!!!!
- VAFC installation Q.
- How do I check OBD1 ECU codes on OBD0 car?
- koni coilover??
- I have a b16a wondering what to do?
- What do you guys think of this setup
- Getting codes 4,8, and 9...
- code 45 and some more
- loss of power
- 1.6 vtec..honda civic...what kinda head?
- Where to buy crank pulley holder?
- What are the +/- of LS Crank in GSR
- Proper air pressure for forks on CB 400T
- Help please! Car Problems
- b16a2 aem pulley kit ??
- "Q" on fuel pressure gauge.
- what springs drop 1.5 in front and 1.3 in rear?
- LS/vtec + JUN III cams
- 99 USDM H22 distributor on 94 JDM h22
- cheap cai on ebay worth it?
- b18c1 wiring HELP!!!
- ecu symptoms
- Mini-Me Stalling?
- estimate for repairs?
- N/A Fuel management system ??
- need good DIY coilover install site
- Eg hb camber qusetions
- Tuning B18c
- Transmission binding problems
- ACT vs. Clutchmaster
- s-afc wiring diagram for 96 civic
- vaccum source for msd btm
- Eg hb idlen too low
- fuel pressure queston for b16a2
- What US heads fit on a JDM SOHC ZC
- Help with building b18c1
- difference between b16 int/exh valves and ITRs?
- Port and polish a head
- ecu numbers...
- where is that GREAT ls vtec sticky post at? help*
- Is this true about a mini me swap???
- Will the Snap-on valve seal remover tool, work for hondas?
- Coilovers
- definition/difference...
- Apexi VAFC for GSR???
- Type R ECU on GSR? USDM or JDM?
- where to buy exhaust flanges?
- WTF is a throttle mod...
- Camber Kit
- Which cap for external coil?
- dx motor with MPFI?
- what manifold gaskets to use?
- do you guys think i can still use this stufF? (56k ok?)
- How much louder will your car get with a high flow cat?
- need help nstalling front sway bar in non sway bar equipped car.
- anyone have knowledge on the 95 del sol a/c bracket
- Torque specs for lug nuts?
- No heat inside car after rad replacement!
- disassembling auto meter gauges
- TEIN HA rust provention
- DIY Comptech Ice box
- rsx enerygy motor mount inserts
- piece of my block cracked off. need help. long story
- Wiring GSR IM
- Suddenly hard to shift...
- Normal Air-fuel mixtures
- DA Brake problem, ITR master cyl and booster work on DA chassis?
- Prothane Motor Mount Inserts?
- any one tried the ENDYN oil breather kit ?
- TIMING BELT on ITR with Skunk2 stg II cams
- Wiring Problems - Help Please
- Burning oil motor smoking???
- ITR Internals in a b18A
- brake question...
- idle problems
- engine
- cable y1 tranny/axle seal
- weird question....NEED ANSWER!! sort of...not really
- Types of Grease...
- exhaust questions
- koni shocks
- Fuel Injector Order?
- Is it possible to make ITR shocks to fit a 96-00 Civic
- My exhaust expels a fair amount of water!
- check engine light comes on after sqeezing
- Honda Communications Protocol?
- D-Series Calculator
- Questions about OBDII Smog
- need wiring help asap
- EF (SI and EX) Engine Wiring Harness - Differences in Years?
- leaking tranny and CEL 43 for a b20 crx
- itr problems..
- 5th Gen Civic Brake questions???
- Can you run v-afc without the vtec wire hooked up?
- Anyone know the thread size on the top of the oem fuel filter???
- Can someone grab a file from tech2tech for me?
- Skunk2 Stage 1 Cams or not???
- shifter vibrating.
- Is there any way to tell the year of your engine?
- 'oo gsr w/obdII testpipe
- Tranny oil (lsd 1st gen)
- battery problems!?!?!?!? please help
- alarm problems
- parts needed for a 5 Lug 5 Lug TYPE R conversion ..
- Larger injectors, FPR for my new mods??
- My untuned dyno chart (ef-1 cams)
- Anyone running speedmaster SM-046 rims??
- >>Manual rack question<<
- idle problems yet again :(
- silincer removal tool
- Hondata or V-AFC?
- anyone want to make $5 from me?
- help!!! Need help on install of motor!
- je oil expander ring help
- how to check obdII check engine codes??
- Spoon Flywheel Question...
- Spoon and Ericks Throttle body question...
- GSR tranny
- Auto meter oil guage install
- any stand alone users???2.2 vtec turbo
- Need help with a pinout problem
- turbo guys vacum problem
- Help!! Hatch Studders in high rpm!!
- High Idle problem with no codes.
- help on cam id
- B series Tranny Rebuild How to????
- 1995 civic looking for some power
- Anyone know how to fix check engine light #91...Fuel Pressure Sensor?
- specs on stock b16 exhaust cam
- ignition start button
- Removing the clutch master cylinder with out rebuild kit?
- dust covers and coilover sleeves
- Cold SparkPlug For Race Motor
- OBD1 Ecu on OBD2 Engine
- b18c vs c5
- does anyone know the difference between the dohc zc and the d16a1(i think)?
