View Full Version : Tech / Misc
- Emissions question
- i need some help guys, tranny noise
- Flushing Power Steering Fluid
- Starter
- 5 lug + EG + DC2 MC&BB + DA PV = Problems @ 1 A.M.
- CR-V transmission and AWD
- b16a1 into a crx.. bracket problem!!!!
- problem adjusting coilovers
- Can a burnt out clutch effect shifting?
- Turbo LS Civic runs perfect but randomly shuts off
- Platinum plugs vs Iridium
- Need Help Quick/Burning Up...
- ? for people with the wilwood big brake kit
- Lost Motion Assembly Question
- a few cam questions
- i NEED HELP!!!!!!! DON'T KNOW WHATS WRONG
- Will a 99-00 Si tranny fit in a 00 ex manual?
- 1st gear bogging at vtec engagement (only first gear)
- quick coilover question
- 94 Civic sedan auto tranny replacement ?'s
- Audi A6 HID's, What Else Do I Need??
- B16 Valve clearences?
- Tranny rebuild?
- Heater Valve Cable
- Please help with my timing belt.
- little help please, B18C1 question...
- Map Sensor Question
- Oil Filter heatsink?
- Car hard to start/ Fuel pressure drops fast
- Are all 02 Sensors the same?? I really need help!
- Need some advice
- Engine Code Mixup
- MAJOR Hesitation...WTF
- engine stumbles at 3k?
- Need good Tire that wont rub in lowered setup
- I need all the help I can get!
- Is it worth it?
- what do the numbers on radiator caps mean?
- H22 coupe non - turbo vs Tubo NeonRT??
- starter problems?
- Custom piping+Univ.Muffler vs. Aftermarket Big Bucks Exhaust
- ported si intake manifold and 2nd gen TB
- dirty motor
- carbon fiber
- is my VTEC working?
- rev limiter.. and then off
- Any EF's using a OBD1 B16 ?
- help for tranny swap
- don't hate me for this question.
- 98 CIVIC EX EXHAUST HELP
- Gsr vacuum diagram
- White Stuff on O2 Sensor....
- Why won't the screws on the bottom of my sideskirts unscrew?
- Seller bent A/C line to ship it to me; is it OK?
- Acura Hood Swaps
- is there a marking on skunk cams to find out what stage it is?
- What is detination?
- what cams are these???
- Converting AUTO ECU into Manual ECU
- How in the Fawk do you remove the manual window crank in a 97 dx?I searched.
- CRV throttlebody???????
- 91'crx si fuel pump in 90'teg ls?
- ?? about 93 B17A distributor, it will not work...
- what air box to use?
- b20 turbo puffing smoke
- anyone ever have a ignition coil go bad (symptoms)
- oversized rod bearings?
- brake problem...got a answer for me?
- ECU Pinout Map
- ngk spark plug Q???
- speedo, tach, fuel and temp guage went out, a short?
- How-To on Power steering for GSR motor in EJ6 (97dxcpe)..?
- D15z1 Piston Dome Displacement Needed
- VAFC Hack | 450 cc Injectors
- Has anyone used aluminum retainers?
- heard of these shocks?
- Any one heard of Bear Alignment in SoCal?
- Horn does not work. Help.
- brake rotors . . . question.
- Quick N/A Teg question
- is it easy to replace wheel stud?
- 2000 civic SI Timing belt
- bench bleading
- Is there B15 sohc vtec??
- Help!! car keeps stuttering
- Removing power steering PUMP only
- nitromethane... why isnt anyone using it?
- just got my b18 swap into a 90 civic running but having big probs...
- Suspension set up
- Help with removal of pedal assembly
- Converting an obd1 distributor to obd2 ?
- Q's about weight of the b18c5 engine
- Distributor question...
- Help passing smog test - already searched!
- Throwing code 8, now throwing code 9. Please advise.
- sohc timing question. I cant get the light to light :-)
- Anyone running the Mazeire electronic water pump?
- resurfacing head...
- crank pulley
- Signs of an worn out clutch?
- Light Wheels : What are the benefits.
- B16a ob0 or ob1??? how would you know the difference?
- Best Bent wheel repair? Any suggestions?
- Uninstalling VAFC
- vin # search
- fuel pressure regulator problems, help needed
- engine codes?
- early 1.7 head
- new 03 si break in: fuel question
- Battery relocation / Bottle placement questions
- why am i overheating
- car not starting?
- Installing Hasport Mounts ( Quick ? on install order) One is coming up short!!!
- Right hand drive conversion questions?
- 93 si hatchback engine swap?
- can low profile tire be made of soft material?
- need someone knowledgable enough to help me identify tranny problem...
- what are dowel pins for?
- Possible to use a hydraulic tranny on a cable tranny car?
- Is a b20 head worth it?
- Need tech help with head
- dry oil filter?
- HP Gain with smalller pulleys??
- sensor identification in distributor
- AUTO ECU in a MANUAL
- Tranny question
- What the highest compression that can be safely ran on 91 octance gas?
- will ST rear sway fit on ITR suspension?
- 2 solid tire marks, start to stop, NO LSD?
- Lumpy idle - not the normal IACV problem
- Flooded car!!!!
- regular smog or test only
- any have a painted block?
- help!!!!!
- Uneven drop?
- Clutch alignment
- Help! car wont start!
- Could it be a problem with tranny? or clutch? HELP!!
- ANYONE KNOW ANYTHING ABOUT THE JDM S20 Tranny if so plz help me out with the Gear Ratios....
- what would cause a cricket noise from the motor?
- Front motor mount on a d16z6 same as 90 honda civic?
- Best lug nuts?
- Manual Tranny with LSD - what oil to use?
- o2 wiring (h22 EK)
- Car not starting - fuel pump not getting power
- fuel pump/kill switch prob.
- Clutch pedal movement
- What's a good tranny oil...?
- Octane BOOST............DOES IT WORK??
- 5th gear is popping out.......?
- rod bolt torque and stretch info.
- JDM engine specs measured using higher octane gas?
- good/inexpensive civic mechanic in seattle?
- What are these wires?
- In need of donut gasket for DC JDM 4-1 header
- Eagle Specialties...website addy?
- cant check the CEL
- Power steering fluid all over engine!
- Fuel pump question/problem
- Car/Tranny/Drive Train/Brakes/SOMETHING LOCKED
- h23 headgasket question
- code 22
- can I use a 95 b18c1 motor harness with a 97 motor
- brakes locking
- CHIP problems!! HELP
- H22a Map sensor
- first gen b16 in a 93 hatch.
- Replacing suspension arms: Bushing Preload? How to fix?
- {{{ What company makes these LSDs and do they ahve a website? }}}
- 3,000 RPM Hesiataion /Bog
- SRS and Horn not working...
- header dents
- TPS code from my ecu???????????
- spoon n1 sound clip?
- can i put on ONE new tire on my car?
- Not Satisfy w/ the dyno result!!!
- vafc hack with boost controller
- Quick Batronix/electronic questions
- Need info on how to remove header bolts from block?
- My B20VTEC buildup
- HELP ME !!! civic DX with LS swap.
- Need help with EF coupe! How do I check codes?
- help this noob
- Spark Plug ?
- tranny problems
- Jun headers? how good?
- Car is stuttering, hesitating already searched, (HELP!)
- please help before i DESTROY my car!
- quick tranny question for all you tranny people!!
- The awesome melding of import and domestic.
- d15b vtec
- CRX/B16 2 wires back of block in boot
- breaking in and maintaining motor
- GSR bogging down during takeoff...need help...
- Mugen Airbox for DC2 fitted into EK?
- can a 91 civic hb roll bar fit into a 92-95 civic hb?
- where can i get my B18C rebuilt?
- can a prelude head fits into d16y7 or d16y8? just the head exchange...
- i hate asking this but i need fo fix it.
- will my headgasket seal part II
- wiring and tranny questions.........
- unplug iacv= car dies, bad iacv?
- CTR Pistons in B16
- vtec does not work?
- anyone do motor swaps in phoenix?
- need fuse problem help asap..
- DIY Torque Wrench calibration
- What performance part are you looking for?
- Prelude H23 to H22a swap?? Need Help, Engine wont even turn over!!!!
- if i run auto ECU in my %spd will teh rev limit be lower?
- ECU's - p13 vs p72
- help. car wont rev over 3k
- Passing smog in California?
- Advise on tunning Jun 3 with high compression.
- so cal people......
- question on msd igintion box
- Could this be pinging/pre-det?
- Timing Question D16y8
- DYNO Pointers
- leaking coolant/problem with gauge cluster
- cig lighter replacement/repair
- Need Some ITR Torque Specs Please!
- need some info?????
- Which chip to BUY????????????
- FS: 92-95 jdm b16a sir-2 shortblock MUST BE SOLD TONIGHT
- no O2 sensor cause lumpy idle?
- Battery Relocation Problem !!! HELLPPPPP !!!
- HELP - I have a partially Stripped Tensioner Bolt...
- Are all B series exhaust manifold the same bolt pattern
- Compression and skunk stage2
- two questions: compression test and cranking the motor outside the car
- n00b question bare with me!
- Didn't know which forum to use for this question...
- Quick Question: Moly Lube on Cam Plate Bolts?
- What coolant is the right coolant
- Help!!! CEL 23
- d15b, d15b7....whats the difference?
- the most Bad Ass Suspension
- Widest Tires on Si Rims?
- How to take ceramic coating off for welding
- cat test pipe
- Cel Code 9 Assistance Please
- worth it or not??
- battery? alternator? please help asap!!!!!!!!!!!!!!!!!!!!
- Fuel Pressure Regulator problem???
- what fuel pressure
- Tranny mystery
- Would IT?
- difference between gsr and type r engines
