View Full Version : Tech / Misc
- Rings or Valve Seals?
- Need Power Figures!!!
- abs swap to 99 si
- Post your Compression ratio's and you compression readings.
- Can someone give me a 4 wire o2 sensor pinout(p75)
- what comp #'s are ok for a JDM B18C-R?
- Ractive FPR installed...some pics inside..
- re-wiring JDM dual o2 sensor to USDM single o2 sensor
- Going Through Alternators Like Water
- Anyone Run Quaker State Full Synthetic?
- Idle is funny and check engine light comes on
- ls/vtec head gasket
- VTEC not working, but electronics test OK
- Lower rear floor bar.
- powercoating wheel in southern california, anyone knows where?
- Crank Q???
- need to know asap MSD dis. cap
- Att/ hardore s2000 heads or honda freaks need sum help (u gotta peep this
- *NEED Injector HELP*
- IS mobil 1 not fully synthetic and CASTROL syntec is fully synthetic??
- which chipped ecu?
- swaybar install questions
- How is the Sol for a platform?
- code 21 with pr3 mugen chipped ecu question
- ITR piston install
- Question about ground wire kits?
- help with shock tower bolt!
- Help! starter problem?
- shortblock/longblock questions...
- *urgent* - will hydro GSR starter motor fit a B16A cable tranny?
- What will take paint off my headlight lense?
- CTR pistons on ls rods
- stock dohc vtec cams specs?
- Power Window problem, wtf?
- Civic is overheating even after new rad, thermo, coolant, water pump....why?????
- Hesitation at 5k rpm???
- climate control lights dont work HELP!
- i noticed my car idlee better when evap purge valve is disconnected
- B20vtec into hatch????
- ohlins suspension?
- b20/vtec???
- Stupid questions but need an answer...
- TPS possessed by Satan
- 1.8 (81mm) not enough for ef-1s?
- how do i wire up a 4 wire o2 to a p28 ecu
- Brembo Slotted or blank rotors
- how much could I get for this motor
- Trying to help a friend out, question to the pros on the board.
- Crower Cams?
- Upgrade Fuel System
- 11.1 compression
- weird problem with power supply and indiglo gauges. HELP!!
- CV boot part number#.....need help.
- RSX-S Wiring Diagram
- RSX-S/S-AFC Settings
- will a chiped p28 run RC370 injectors
- possible to sleeve a B16 to 84.5mm or more ??
- pretty stupid question
- Thinking about hacking my rear bumper....
- d15 head torque measurments
- How do I tone dowm my exhaust?
- 2003 Accord Commercial
- How to wire up a 4 wire o2 senor to a vx engine wire harness
- Radiator swap.
- CRV tech questions
- Help With Wiring Tech b16a Into 87 CRX Si!?!?
- 96-00 civic 2dr exhuast fit on 4dr
- 120 compression all the way across!?! need help!!
- ?'s on wideband o2 sensor tuning
- should I advance my ignition timing more or not?
- Exhaust Help
- HELP NOW!! jdm HIDS (wiring)
- Visibly telling a difference between a B18C and a B18C-R block...
- Are B-Series Crank Pulleys the same?
- Loosing oil
- Honda/Acura Fuel Pump Part Numbers
- What are some signs of bent valves?
- My new pipe bender....and problems...?HELP
- Buying right pistons for b16a JDM
- Honda/Acura ECU codes
- b16 vs b18c engine mounts
- Need help w/ the setting on a adjustable kyb shocks w/ vspec gen 2 coilovers
- replacing spark plug gaskets....
- Inlet Heater Hose/ Need To Find
- Tuning my d16y8
- integra temperature gauge problem
- LS/VTEC Dowel Pins
- srp pistons?
- NOS Plate for a B series
- 10 sec D15? with GX pistons?
- Changed Headgasket, Now bubbles in overflow!!! HELP ME!
- looking for lph specs on two fuel pumps
- CRX Upper control arms
- best way to treat a rust spot
- Car running like crap and CEL light came on!
- Simple quickQuestion
- Anybody know any good place in PA to do an engine swap?
- JDM ITR in to a EK?
- RS MACHINE!!! (some 56k unfriendly pictures)
- Where to get guage cluster fixed at?
- Best clutch for the money?
- DC2 LSD in an EK9 Tranny..Will it work?
- SKUNK2 intake manifold problems after installing, need help
- how do i wire up 02 sensor
- b20vtec, goin all motor.......who has one or who can gimmie some advice about em'?
- crank fluctuating sensor
- Just installed momo steering wheel...need help w/ horn.....
- Is this caused by detonation? pics
- What Boost Controller is everybody using?
- make auto p28 work for a manual?
- clutch and flywheel
- rebuild or swap??
- Exhaust question ????
- what TEMP does a vavle cover reach>?
- LCA shock bolt solution...
- bolt crossthread problem..
- CTR parts into B16A2
- Any one using Crower cams?
- Another Smog Question
- brake booster hose question
- C.E.L. came on while I was driving....
- bee r rev limiter
- Honda tranny codes...
- What is GhettoDyne?
- B18C-5 ............. Power est??
- WHAT PARTS TO USE TO BUILD A 1GEN NA B16A1 for at least 180/200+fwhp
- Guess Vavoline MAXLIFE does work:
- a/f guage splicing
- LS crank&rods w/gsr pistons in a GSR block
- How to tell JRSC mani is b18C1 or C5/b16?
- question about aem cai and bypass valve.
- "jdm hamp oil filters" the only thing about them are the color!
- HOW TO reattach molding on side of car???
- Anyone running S-AFC with 99-00 Civic Si?
- fuel pumps?? which is better for my r??
- How much does it cost to dyno?
- fuel cell website?
- b20 vtec info ????need it ????
- valve spring pressure rates
- Rear Main Seal???
- anyone running skunk2 valvetrain and crower cams??
- What's the advantage to an aftermarket LCA?
- Slugheads, need your help
- What size exhaust piping to a stock muffler is best for daily driving? and unbolted for racing?
- Non Turbo Skyline applications?
- Help with engine swap: B16A into A 1992 HB
- new toy...
- engine control module help
- short throw shifter installation
- Hurst SS Shifter... anyone have this or felt or seen one in car?
- HONDATA - program with stage 3 cams.. HELP !
- Stock JDM b16 Help....
- best automotive program in cali?
- need help: someone dropped in a pen IN my engine
- clicking noise???
- What is the best cam setup for a d16y8
- CTR pisonts in LS B18A. Need Help!!
- Best Cams for a 99 B16
- Injector question.
- What to do next to an sohc
- integra fuel pump and inhjector info
- 5th gen overheating problem
- tuning with afc, does it mess with ur timing?
- is thier a way???
- Timing is wayyyy offfffff.....HELP!!!!
- which sohc head: P08-3???
- where is good place to find a b20z short block
- wheres the starter
- 99 Civic front lower ball joint removal
- knock, knock. i have a problem
- necessities for reprogramming eeprom chips for ECUs...
- Reoccuring idle problem HELP!!!
- bad injector or seal?
- valve adj. when motor breaks in?
- Will 92-95 Civic si/ex brakes fit Mk2 CRX???
- i need a AEM base map for h22
- oil brand question
- '99 B20 into '96 CX..why do we move pin at A14 to A12 on the wiring harness?
- GSR skunk2 IM fit Type R?
- Quaife model question
- what fuel rail will work with a b18c
- almost done with my techedge WB....YAY
- ITR pressure plate/ Kevlar disk combo question.
- hydrolocked!! help me out!
- d16z7 semi-stock tuning suggestions for98 civic ex
- rebuild for high mileage motors
- wrong bolt stuck...what 2 do?
- What fuel upgrades for a 2.0 vtec dohc ?
- b16 gen1 vs.b16 gen2??
- Fuel Pump needed when swapping DOHC VTEC?
- distributor question
- So my brakes went out on me today...
- help: how do i prime oil pump
- weird gauge cluster problem.
- B16A Head have a small Dowel pin under middle cam cap?
- DSS axles from a y80 tranny (gsr tranny with typeR LSD) question
- What are the 3 plugs in the back of the block
- Alignment question?
- Three Unrelated Questions.....
- crank pulley help
- Flashoptions.com
- oil light still on!!
- Need help with swap
- HELP NEEDED - and FAST (New Engine)
- Breaking in MOTOR?
- basic OBD 2 scanner for laptop
- Help Car won't start, I have no spark....
- Quaife Problem: Installation/Fitment
- MAJOR Problems After Valve Train Upgrade
- steering rack?? help
- MSD ignition Vs. Vortech / MSD Ignition Boost Control NEW
- What's the drivetrain power lose of D16z6 tranny?
- cylinder head rebuilders
- WTB: 94-01 integra rear bumper and rear skirt 2dr
- Help: Moisture in sound deafening material in trunk... what should I do???
- is will b16a header fit on b18a head
- How can you tell you have an Si tranny? ( n00b question )
- apexi safc
- Decipher This Code?
- Help: Will a non obd d15 work in an obd1 car? *photos attached*
- problem after gsr swap, help needed desperately!!!!!
- will b18a IM fot b16a head
- assessing parts condition...
- My cars knocking what can i do!?!?!
- Guage cluster guru's...got a ? for ya
- Which helms manual?
- CEL question? 92CX
- Motor build
- Is there a way to wire Vtec to a shift light?
- the shakes
- HELP Which STOCK intake fits ek w/b18c1 swap
- vtec controler questions
- Race motor - metal head gasket
- can you do this?
- Roller rockers for honda?
- Waterpump question
- B16 PR3 Vs. PW0 ECUs
- oil leak help
- Difference between batteries?
- Steering column swap help from 93 EX to 92 VX
- Clutch problem help
- What do oil squirters do on B18C?
- Rod Bearings - Anyone Use These?
- need SAFC diagram for 00 Eclipse GT, V6. thanks.
- gsr block bore/sleeve results???
- BAD water pump?
- Rev limiter aaccuracy with Hondata
- Tranny leak, clutch housing has a seal?
- what catalyic converter?
- Should I Ziplock My Parts?
