View Full Version : Tech / Misc
- How do you tell p72 obd2a or obd2b
- Looking for some explanation about Ostrich - Real Time ECM Emulator an Crome Pro.
- Installation of AEM cam gear in d16y8
- lsd differential options for M2a4
- Willem enhanced burner question
- b18c with skunk2 valvesprings/retainers what RPM you running it to?
- b16 distributor question
- ARP headstud specs
- autometer elelctric oil gauge....need help!!
- D15B7 MOTOR TRICks???
- B16 ecu code 4??????????????????
- need help getting axle nut off, how long of a breaker bar?
- How to change EG steering rack?? need pics and detailed info please
- timing belt slipping on cam gears. Help?
- Vtech solenoid seal problem!!!!
- D15b2 throttle body question.
- zex safe kit?
- Will my car BLOW UP or no/HELP!
- 1.4l civic engine parts
- loss of power
- Weird brake question
- Fuel pump issue?
- v-tec question
- 2001 gsr shift linkage in 96 civic ex
- Carbon Deposits
- help 97 hatch
- AEM or PLX wideband?
- Any alternator experts here? Like people who work on them.
- noob help
- What is the best setup b-series turbo
- bracket?
- Car bogs, what's going on?
- Coil on plug setup
- Car shuts off/ almost dies every 30 seconds then runs normally again
- CRX front clip help
- reinstalling Head tips and pointers also Rear Balance Shaft Ques
- valve adj. screw stuck need help
- dumb question
- How to clean inside valve cover?
- where to find cable tranny ??
- Brake gurus - Having strange problems with just front rotors rubbing (getting very hot)...
- Car falls out of Idle?
- 440cc injectors in a R motor??
- Engine Trouble
- Ebdyn Block Posts, a horror story
- Mugen, Spoon, or Buddy Club head gasket? Tried searching...
- Timing belt runs off front of cam pulleys
- 2 cylinders low compression after stoping
- How can I tell what transmission a transmission control module is for?
- Slipping iron disc
- fuel pressure drops after priming
- Did head swap...now timing is off...
- HELP HELP i can't get my car to run!
- Idling in neutral with no tranny fluid?
- No Oil Pressure at idle - jumping gauge
- brake drag
- Code #1
- Valve adjustment w/ cam gears
- couple of questions for an electrical guru
- S2 Throttle body problem
- Legend 2-Piston Brake Upgrade on Accord
- Which a/c belt
- HIDs? how they work
- CAI Bypass Valve - ebay
- forged pistons
- peak hold injectors in saturated car without resistor box, what will break?
- swapping ls heads???
- stuttering issue
- Tach and stumble problem
- HELP. I have serious issues with my car
- Staking trans bearing into case?
- DOHC vs SOHC
- need a company that will give a ported head a "stock casting look"
- obd 1 code reading
- engine questions, headgasket, piston slapping head.
- Anyone know the fuel gauge sender resistance(full and empty?)
- how to check if valves are good with head off?
- No oil pressure in built H22, please help!
- Integra LS Cometic .74 Headgasket C/R
- Closer to starting the mini-me... weird starter problems
- turn signals help
- Crank Walk Question? K-Series ..
- Problems with 97 Civic EX w/ E-manage - error code 11
- GSR JRSC with Hondata Engine Codes 17 , 20 , 43
- obd2 to ibd1 distributor wiring problems
- will this ECU work
- skunk2 intake manifold
- replacing pistons? do i need new pins or can i use the old ones?
- Quick JDM ITR motor question...
- Setting base timing?
- Fitting an itr lsd in a GSR Trany
- Tuning Help!
- eliminate resistor box??
- Spark plug opening size?
- Trying to crank built motor over for the first time...but it wont crank..
- Mini me parts ant tuning write up.
- boost control and tunning
- Torque Plate for B-Series
- Need Help/advice, Shifting problem???
- Does this Valvetrain look normal (Pics inside)
- Nice ring compressors for building engines...
- auto trans.
- Starting/Fuel issues A6/Y8 mini-me
- lsd differential fit?
- Immobilizer swap?
- seating rings?
- Flywheels
- b16b + boost
- Car Dies out
- Piston rings upside down ?
- where to get a new y8 head for cheap
- Big Newbie Question
- ACURA ENTERING AMERICAN LE MANS
- obd2 scanner ..... which one to get???
- jDm Civic eg cluster problem w/ speedo
- Cleaning Engine Bays
- How much it will cost to ship out a set of rims
- Loose Timing belt and stuck Cam GEAR????? HT I need your help
- BRAKES FUQQEDD UP HELPP
- swap trouble..
- wtf....
- crankshaft sensor????
- bearing question i need some help
- Dart Block? What is the big deal????
- Flywheel noise? hum, whine...
- brakes get soft when its hot outside...
- Alternator wire Problem
- Chipped ECU boost options
- will an 'ODB1' magnaflow cat work on a '99 (obd2) vehicle? pass smog?
- Crack head gasket... Help
- Y1 tranny diagram
- VAFC or Chipped ECU?
- How much ethonol is in your gas?
- b20 and b16 tranny question. 4gear synchroniser swap?
- Are OBD2 TPS and Map sensors interchangeable b/w B and D series
- Valves first time, check my work pls ;)
- Cable or Hydro tranny??
- Injector wiring question
- o
- 70mm throttle body= no idle screw problem
- Help with ECU
- Will 99 ex exhaust fit 99 si?
- Piston ?
- Need Instructions!! Please help
- EVAP emisiions code
- oil clearence with Honda OEM bearings question
- IT STARTED!!! First build - *VIDEO* Wont Idle, Sounds Rough. Diagnose me
- P28 chipping, need advice... PLEASE
- LS/VTEC Problems With Fuel In VTEC
- clutch??? is this ok? help please!!
- JE pistons: Dont know C/R
- Help!! High Idle Problem-----LS/Vtec integra please help if you can.
- Changed fuel filter, small o ring?
- Chipping question regarding P72...Searched...
- please help, hot negative terminal
- torque spec on Eagle rods w/eagle 1.5 ARP 2000 rod bolts
- Engine Compression/Leakdown Testing While Out of the Vehicle?
- The difference between OBD2a and OBD2b???
- Edelbrock Victor X
- ZC cam
- Fujitsubo Legalis R, Is the resonator in the middle actually a chambered muffler?
- obd2 to obd0
- Timing belt: Is this normal?
- earthing out knock sensor = no cel 23?
- h22 crank in a b18
- Where to buy Magnaflow resonator?
- B18C 96 spec, having problem IDing, need some help
- emmision problems w/ jdm motor swap??
- Oxygen sensor help
- Cooling Fan wiring
- Shimming oil pump... How much is too much?
- Fuel pump not priming, no fuel in engine. I NEED HELP.
- ATTN!!! anyone who has bought a new OEM oil pump.......
- pistons/wall clearance
- No VTEC - B16a Help... I've tried everything I know !!!!!
- searched need help with o2 sensor
- whats this part called?
- will 94 DC power window stuff work in a 94 CX hatch ?
- puck clutchs
- Quick alternator bracket question
- Can someone tell me what Distributor to use w/ jdm H22?!?!?
- clutch question
- Acura 1.7 EL bumper
- Is this supposed to be like this?
- Computing Injector Size on RC Eng's site - What's PSIG
- Slave Cylinder not there??? It's missing! Please help!!
- looking for honda guru on alternators
- By RPM or TPS
- obd0 pr3 on poor man's type R?
- hondata tuning systems.?
- Air Temp Snesor location on Turbocharged Car?
- link to write-up for chipping a p28?
- Skunk2 Stage 2 crack
- Timing Belt Tensioner-When to Replace?
- Which ignition wires to go with?
- Everyone thats had an oil light read this
- Difference between LSD's? (i think my cusco i have is for cable) :thumbdown:
- P28 + Hondata S300 Issues - HELP
- Valve replacement - Choice?
- DEI HT silicone spray for exhaust? anyone use it
- want to try ENGINE RESTORER
- Mod legal issue
- Oil Pressure, WTF?
- 1st gen sohc vtec?
- Machine shop in PA???
- Help PLEASE!!!!SAVE ME
- could this pcv setup be affecting my idle
- Cleaning STD Exhaust Manifold
- z6 head on y7 block ?
- Can I drive my car untuned like this?
- What Boost Controller?
- valve lapping
- Okay... I need INPUT on this!!!!
- electric gauge ?
- WRITE-UP: Ultimate DA Battery Relocation
- Thermostat Change DIY???
- p06 to VTEC
- tranny out but in gear....
- Honda B-serise engines on wikipedia
- DC5 Calipers onto an EK????
- i know you hondata guys can answer this...
- HELP PLZ!*****Low Oil Pressure at Start-Up (NEVER DID IT BEFORE)******
- reusing my stock head studs???
- itr wing needs to go =)
- Will stock muffler hinder performance?
- Had oil in Radiator tank... WTF?
- getting bumper ready for paint at body shop
- building my b16a cylinder head
- Help with Valve Keeper Install
- civic wiring gurus please look at this
- D16A6 Troubles - Fresh Rebuild - Wont Turn Over... Crank... Crank... Crank *VIDEO*
- BENCH bleeding the Master..
- Anybody wanna share their stock Euro R numbers
- Rebuilding an axle vs. just buying a new one?
- auto to manual conv. wiring help ?
- Spark Plugs
- Impact Gun electric
- What is it?
- Leaking oil
- PLEASE HELP ME!!!! transmission question!!!!
- b16 swap major oil leak!!!!
- Air in coolant line
- need ecu for 99 integra automatic in dfw
- I think i sunk a sleeve
- shift linkage
- anyone know?
- EMANAGE help needed. injector duty cycle at 100% and no fuel added. please read and help.
- ICMs keep going bad on me!! Need some help
- problem with piston......from ef form
