View Full Version : Tech / Misc
- Exhaust manifold studs
- Power steering elimination kit (WTF)
- IAT/Ignition timing problem (possibly) help
- Injectors aren't injecting any fuel
- break-up around 5k rpm
- BIG PROBLEM car revs up to 5000k then it drops
- Random tach spikes while idling? Normal?
- Noob question sorry -- first B16 swap for me -- TPS related
- NEED HELP IACV already searched..
- gas coming out of exhaust tip.....
- Exedy Flywheel...
- b16a valves, a1, a2, a3, gsr
- Engine stand bolts
- How should I properly store a crank
- rod ratio affects piston speed............................................. ...?
- d16y7 perfomance????
- will 225/50/15's fit on my DC2
- Will these clear Volk Racing CE28n's - 16's
- Wideband wiring question/portability???
- how to check for bent/leaking valves..head is off car
- Car consuming too much gas.
- TYPE R LSD in LS TRANNY
- integra cluster into civic, cant display cel's?
- d15b vtec-e manual
- hondata 3b?
- lookin for upper and lower control arms
- Front alignment question!
- fitting size for fuel filter?
- Dipstick compatibility?
- tranny issue
- definition?
- question about honda pulley holder
- oil level gauge vs. oil pressure gauge..which one do i need?
- Need help to locate a problem..here are the symptoms.
- ECU Tech
- suggestion on plugging a hole
- Intermediate Shaft Tech
- is valve adjustment necessary after installing new valvesprings and retainers?
- Burning Oil No Leak No Smoke ! HELP !!!
- What happens if I run the car w/o a thermostat during the summer?
- tuning
- Oil Pan!!help asap!!!
- 1988 Civic D16Z2 fuel injectors
- Ignition failed, then worked, now failed
- what do i need to know before getting rod and main bearings??
- GSR head work problems..please help
- none V-tec 1.5 sohc to B16 swap, what do i need? (tryed search)
- tach reads to high
- Tranny gearing/swapping question
- ZC, port matching a D-series header?
- Slightly Rebuildin my a6, questions
- PLEASE HELP WITH B-SERIES
- help with cel code 9 on my eg
- car no starting. ls/vtec. ignition problem.
- ATTN BRAKE PRO'S! need help. abs light on, checked code, this is whats wrong.
- Questions about a Shift Light Install
- Quick question.. about Gas
- Differances between auto & manual ECU in EG?
- TRUTH BEHIND D15B CAM?? + BEST CAM 4 Z6 @ 10:1??
- SOHC, locking the rockers...removing LMA's.... any problems?
- Little help on a 91 civic b16a swap
- HELP......Ecu, VTEC, wires cut.....
- Electrical Problem 96 Prelude. Short?
- what size punch to use on bitchpin
- Coolant Overflow Nipple
- convert 97 civic to ob1 aem ems or use obd2a ems, na
- Fuel Problem
- Proposal: Titanium Valve Lash Nuts
- Oil Consumer Survey
- hondata s200 and knock sensor
- Clicking noise in 1st/2nd/reverse when releasing clutch in my 92 accord ex... bad motor mount??
- Weird Engine Problem, Idling Funny...
- Pros & Cons of a Type R.
- Eliminated my breather tube heater
- setting up basemaps for aem ems?
- Fixing 3rd gear grind - what to buy
- help with 02 sensor
- hondata with vafc
- chipping obdo pr3 ecu
- Starting to Ending offsets when programming chips. Here's where the numbers come from.
- What cams with Jackson?
- wiring setup
- Oil leak.. Pleas help
- Header promblems
- Quick Question: Distributor Guts the same?
- still got cel 14
- Clutch problems
- Best Build for Bottom End??Ideas please
- skunk2 s1 cams w/ portflow valvesprings and retainers
- Will a car run without a battery?
- Speedo jumping around, elec problem??
- LS compression of 90psi with new cp's ?
- Overkill? Valve springs.
- What O2 sensors to ask for....
- How to lean out VAFC
- cel #61 changed o2 and still CEL#61
- JDM GSR engine need JDM dist.?
- ls vtec headgasket
- Helicoil or Timecert a head stud thread in the block
- Clutch Market Research
- need info
- pros and cons ls block vs gsr block
- name of part that holds down the cam on d16y8
- need help ASAP, anyone out there???
- Problems with timing belt and Rocket springs
- HELP ACCORD OVERHEATING AND I NEED TO MOVE CROSS COUNTRY
- Replaced headgasket... now no compression... ideas?
- ls-vtec build going bad help!!!!
- ROMs needed
- slim jim proof and bullet proof glass
- HELP my VTEC
- why do people flip/rotate their engines?
- can you get by without the condensor fan while using the ac
- TPS Problem and Question?
- How important is preload when installing a diffirential? Need to know ASAP.
- intake cam
- Anyone use a ERL Superdeck block?
- hondata s200 4 wire lead question
- charcoal canaster lines??
- Program to run in/car that desplays engine vitals ect. on tv/dvd/indash??
- Idle bounces from 1200 to 300?
- B-series block deck heights
- How to ID : a Skunk2 @ Intake Mainfold
- Pusher Fan?
- Seller responsible for smogging before Sale?
- ITR HEADER ON A B16???
- when was vtec 1st introduced (research for school)
- AEM Fuel Rail Leaking ???
- need help on zc rebuild
- 00 ITR cams in a jdm B16A, what ECU program to run???
- High idle with no CEL
- valvetrain question
- Dirty clutch disc... what to clean with ? searched.
- Si Seats in a EF 4door.
- Dizzy wont go on straight
- APEXi Super Ground System makes 9 WHP !!!
- ITR Vacuum diagram
- PLEASE HELP!!! Car is making Strange noise...
- rear lca shock bolt destruction via dremel?
- need help with vafc2
- clicking and oil in cylinder?
- off subject-Modesto CA boxing
- Need some help
- CRX with LS swap pulling code 14
- Timing Questions (newbie needs help)
- chipping P08 ecu
- question...need some pro advice
- Breakdown on Cars
- EG doesnt start when its hot, which relay?
- a/c problem
- Which Exhaust Manifold for GSR B18C1 into 93 Civic?
- tune in nh. / ma.
- code 7 on ecu
- MSD Blaster 2 leaking oil ?
- HELP Stripped Head Bolts
- XL chambered mufflers
- h22 engine code.......
- Cam bore Question
- Shortest intake manifold for B16?
- vtec is busted
- C-12 vs. 100 octane
- Proper removal of FITV...
- Overheat and blown head gasket, how far to go....
- EK CIVIC-TECHNICAL DIFFICULTIES-SWAP
- freeze plugs for catch can on b18c1
- will a PWO powere steering pump fit on a b18c1
- B16 head internals?
- Looking for Blairsville, PA Wyotechers
- Lambo Door Question
- Vtec not kicking in for H22a
- High startup idle at 2k rpm and takes like 15 minutes to go down to regular 900rpm idle?
- h22 fuel pressure regulator tuning
- Need a Diagram of a B18a1 Block assembly
- b16a tranny rebuild
- Need help with Torque Specs and sequence!!
- A little help here BREATHER BOX / S1 J1 CABLE TRANNY
- How Muffler piping is measured
- wierd map sensor probs
- CTR OR ITR PISTONS
- parts for B20 block with b18 head non vtec
- help me get my NOX level down....
- Race Fuel?
- what is the weight of an entire b18 bottom end?
- Need Help asap. Valve Cover bolts Broke
- can different oill make ur car tick louder?
- micropolish crank decision
- CRANK PULLEY
- H22 dizzy Problem
- Stock: 1st gen B16a (jdm) spark plug gap? > Quick Answer <
- ITR Syncro/Sleeve PN's
- harness help
- SI GAUGE CLUSTER HELP!!
- jackson racing thermostats
- DENSO spark plugs?
- LS VTEC TURBO
- head stud and timing belt issues with a thicker HG (.125")!
- car wont go!
- b series crank pully
- victor x manifold
- b16 trouble.. help please!
- NEED HELP with JDM gauge cluster
- air rushing sound at high RPM B18C
- Accel 300+ ignition wiring problems
- gearspeed.com
- Auto transmission stall converter questions.
- itr intake cam in gsr ? please read doing today
- 99 si driver side mount install?
- aftermarket O2 sensor wires???what do i connect with stock
- repining integra cluster onto an ek.........
- Anyone in Maryland want to rebuild my tranny? Type R tranny
- does anyone know how to use a obd1 dizzy on a obd0 car? SEARCHED.
- Is this Type R camshaft OR B16?
- How far should msd be from ecu?
- almost spun bearing.. change oil pump?
- need help finding 3000gt motor
- Booster vacuum
- any obdII distributors fit on f22a1 non vtec?
- bad to drie with no secondaries?
- b16 problem..cel 14
- B16 swap in 98 civic dx...bogging,backfiring,help!!!
- Tranny question
- 1995 B18C1 Coolant Diagram?
- MSD Pro Cap doesnt fit? Help please!
- Open deck sleeve Vs. Closed deck?
- Running Rich!!!!!P0172 or code 45!
- big milling...... oe camgear?
- Clutch decision: ACT, Exedy, Clutchmaster, RPS, SPEC
- Help with my brakes on 92 Si Civic PLEASE!
- bypassing crankshaft flux. sensor??
- Help looking for a wiring setup
- h22 skipping
- do you have a good setting for my vafc ? my engine is a b16a2
- Removing Rom?
- Fully rebuilt motor ----- break in questions--- and other start off questions
- GSR into 93 Civic - Rear Engine Mount ??
- Stalling problems
- MUGEN POWER INTAKE>>>>>>>>>>
- Easy question...what's the vtec crossover on a JDM P30
- Question about my ACT clutch condition (loose springs)
- some hondata help
- Help a retard install an AEM UEGO gauge.
- shuddering at light throttle cruise, bucking at 2100RPM cruise
- resistor box?
- B18 engine problems .. over heating
- 30k ok to switch to synthetic oil?
- Vafc Tuning Questions
- CRX mini me
- rod bearing question.
- HELP!!!! Clutch Won't Engage And I can't Shift Gears!!!!!!
