View Full Version : Tech / Misc
- B16 trans + KAAZ dif ?s
- B16 Parts on GSR Head???
- Fixing A/C evaporator question...
- california smog issues
- Make 50 bucks via paypal if you can tell me what the problem is?
- Fuel delivery ???'s
- sub 2000 RPM bogging
- Squeaking clutch? Normal?
- installing ARP rod bolts
- sensor diagram?
- oil cooler question
- ECU SECURITY QUESTION?
- Clutches
- OBD0 and OBD1 TPS's the same?
- Some help...P28 ecu acting weird!!!!!
- Start issue... no fire. Symptoms within.
- Fluidampr underdrive question...
- Does lowering compression increase or decrease emissions?
- Engine Assemblers: Grease the backside of bearings?
- Problem with AEM CAI
- Help P28 chip?
- Timing belt change 2000 3.0L V6 - question on idler rollers
- Odometer issues please help
- Engine Block Options w/DA3 Trans ...
- does any body happen to have the vtec pinout for a gsr into ek ?? 97 obd2 gsr into 97 ek
- Deck got scratched ever so slightly by the dowel pin on the head
- clutch issue pleas help
- Crank Pulley shaved and balanced
- b16Head+ LS Block but without VTEC
- Innovative Mount Bolt/Nut Pattern Question?
- acura vin decoder (2000+)
- Good price on Pocket programmer 2 and romulator???
- B18C1 question.
- severe ecu problems, please help!!
- need help smoke out the tail pipe
- Advise on sleeves
- obd0-obd1 conversion dizzy problem pics* searched**
- why are b18 a and B spark plugs different?
- flashing lights?
- bearings
- ctr intake, itr exhaust, stock gsr valvetrain
- stripped head bolt
- electrical problem has everybody stumped!!
- what to go with?
- help rear disc brakes =/
- Question about timing belt
- Anyone have the MagnaFlow Muffler 4" x 9" 11" Body?
- transmision swap
- 89 Si crx problem (it skips a a certine rpm)
- Overheating b16 please help
- CTR cams VS. buddyclub spec III's
- Transmission question
- H22 - how much intake cam advance before vales hit the pistons?
- Swapping Out ABS for NON ABS
- Tuning equipment
- bad timing
- Anyone know how to wire up ignition switch with a start button?
- Problem with my A/C...
- gear oil for use with Spoon LSD??
- Apexi VAFC.... wide throttle and narrow throttle?
- Individual cyl egt ???
- AC/ Fan Unit not working
- Possible bad ground??
- wideband O2 sensor ideas...
- Stock GSR Clutch capabilities
- VSS Problem (speedo doesn't work)
- V4D JDM GSR Tranny with stock LSD
- need harnes help plz how to make my own harnes
- Anyone with experience with anything similar to this?
- I think somethings seriously wrong....a question for the wise
- DIY hone/deglaze of cylinders?
- Cusco LSD Help
- part # request: d serise valve cover\spark plug o-ring.
- code 9 and vtec pressure are related???
- IS THIS OIL??????????????????????????????????????
- Refinishing your oem syncro sleeve
- Radiator Problem Car Overheating...
- Is it possible for clutch to slip alot more when warmed up?
- Transmission shifts weird
- which head??
- Wht is my ecu out of :S
- transmission help
- need help torquiing down d16a6 head
- 1994 Civic EX coupe: clutch pedal to the floor
- engine cooling
- Mobile 1 or Castrol Syntec?
- Stupid: oil changes....?
- b16 skunk2 intake manifold, will it fit a 2000 GSR head?
- All greek to me
- tech question..
- Will a '94 EX trans work in a '90 CRX Si?
- Where to look
- LS Engine Burning Lots Of Oil...
- Torque specs on JDM JSD
- 2nd Gear Binding
- cutting the engine mount
- DIY 1.8 stroker kit
- BACK UP fuse blows
- b16 Tranny.....Axle Popping Out
- Tuning Question
- o2 simulator problem. Katman HELP!
- hondata tuning in upsate NY
- HELP WITH VAFC DIAGRAM (OBD0)
- cheap ebay exhaust headers
- what kind of pistons are these?
- Anybody know how to get the Horn to work on a Sparco?
- help with cam tuning and EGT's
- AHHHH!!!!!!
- ecu's
- *****92-95 rad fan in 91 crx help!!!
- Which transmission gauges for monitoring the H22's M2B4 tranny(pressure or temp or both)
- four door hood on coupe
- REV LIMITER PROBLEMS!!!
- bleeding p/s system and slave cylinder
- Is it possible to fit a B16/LS Hydro Diff into a GSR Case?
- 3 Hondas in the Diveway
- Hesitation while cruising
- bell housing has oil in it, okey?
- have a question.
- any experiance with a gsr crankshaft having to the reground??? +or-
- normal oil temp?
- Checking ECU?
- itr lsd
- OBD0 b16 Code help
- car is boging and not starting.help
- can u chip a p75 with uberdata
- Breather ports on the back of a B series
- H22a1...need help Help Help...timing belt...cant get it over the cam gears cause of auto tensionor
- ZC Dohc Vs. b16 (any Gen)
- re sleeving? what material do they you for the sleeves
- ZDYNE instructions?
- Not sure what I messed up!!
- JDM B16A fuel pressure
- Spray can primer than paint with paint gun?
- Getting tranny cryoed and rebuilt.
- Error codes
- Help! No power @ ecu or relay !! Stalled yesterday ? short ?
- MAP sensor pigtail
- GE and ARP head studs: lube bottom threads or not?
- Tap/Die for AN fittings?
- the Honda/Acura with the best balance and handling
- msd..
- transmission pops out of gear???
- good data logging program?
- Would EK side skirt fit 92EG94DR
- Stalling?
- my car cranks but wont start! *searched* HELP!!
- k in a insight?
- sohc question
- Toda ITBs and Hondata S200 on a Type R motor won’t run right
- GSR rear disk same as 00 Si?
- programming on s200b???????????
- GSR clutch assembly in 96-00 civic?
- B18A/B Manifold & Throttle body compatibility (No map sensor)
- crx gauge cluster melting???
- jdm b16 dist. cap & rotor
- any place that re-sleeve engines?
- hondata s200b ??????????'s
- battery relocated to trunk
- Oil can leaking
- awd civic swap?
- Rough grinding feel from clutch
- Tuning
- Top Line Engien Rebuild Kit
- building an ls wondering what oem pistons fit
- Cooling addatives. Yey or ney?
- belt noise?
- Comptech Exhaust
- Able to burn chip, timing question
- b16a vs b18b
- Conversion to CFC-Free Air Conditioning
- crx To B16
- Cold plugs?? where to get them??
- Problem with new motor
- Engine Overheating- what should I check
- Injectors
- my last problem... idle issue... please help!
- Distributor bearing seized?!?! ripped the teeth off
- Trade OBD1 P72 for OBD1 P28?
- s300 help
- Group purchase of Sylvania Xenarc Kits
- MSD 6AL?
- h22 in 94 teg
- How do I do this?
- Erick's Racing PAR gears?
- what check engine code is this? (searched already)
- Willwood 12.2 brake kit and spoon sw388 15" will they fit
- Double clutching
- need help with my d16y8
- Are P13s and P28s "hot swappable?"
- i serve?
- obd0-obd1 conversion harness question
- Head Gasket?
- iVTEC vs. VTEC
- trying a ls/swap need info
- Possible Tranny Problem or Just Bad Driving??
- K20A general maintenance
- failed smog check... a little advice please
- Which washer would you pick to prevent cam gear slippage? Link inside...
- Tranny Question
- JDM B16 Head+GSR BOTTOM END QUESTIONS
- Trans problem 91 Accord, auto
- SCE copper head gasket?
- torque specs needed plz.
- hand held vacuum pump
- newbie question
- brake line insulation....
- hoW DO I ADJUST VTEC WITH HONDATA.
- (ELD) ELECTRICAL LOAD DETECTOR?? Code 20, wtf is that? HELP
- inedntifying cams
- Does anyone have any experience rebuilding BOYA Auto Transmissions?
- HONDATA QUESTION, PLEASE HELP ME . AHHHHH
- adding boost option to Hondata s200??????????
- gross polluter...can someone help?
- Do I need special O rings for AC lines? Pressure test instead of vac. test?
- need help with sk2 stg2 cams b16
- please healp
- Engine help
- Lose of Motion Sensor?
- Home made motor mounts
- HELP!!! How bad is my ECU fried!!??!!
- 4wire o2sensor into 5wire o2sensor hx civic?????????
- alternator belt?
- rsx injector question
- Valve Cover Torque Specs
- reliability questoin b16a / typeR
- Time controlled Temp Gauge...
- whats a normal water temp for a B motor?
- cycl #4 missing
- TEST PIPE TO REPLACE CAT
- weight difference between b18 and h22?
- Max Power w/ GSR Head?
- HELP! VTEC NOT ENGAGING!
- increasing hp on a 94 cx hatch
- GSR cams VS b16 cams
- need resurface?? [pics]
- Over Heating only on the highway.... help!!
- Forgot to put the flatwashers on the head studs...
- a/c condenser
- smoke...???
- BLock Guards
- ERL Performance did their homework for the k24's, check this out!!!
- can you mix r12 and 134?
- 90 accord stalling unless gas is pressed and held
- driver side window wont roll up...HELP PLEASE!!!!
- what do i need to install msd 2 step?
- ES TUning
- Steel Braided line....BROKE!
- MY LOSS YOUR GAIN 1989 CRX b20 vtec 13,000 spent this yeatr will take 1/2 of that
- Help me diagnose this problem.
