View Full Version : Tech / Misc
- GSR oil pan same thing as B16?
- Any problems with KYB AGX + Skunk2 sleeves combo over time?
- Whats CLUTCH 2 Use????
- need help! where are they?
- Poormans ITR Tranny: B16A Tranny (S21 or Y21) with ITR LSD
- replaced axles, still noisy. why!?!?
- VIS vspec II coilover install quesion?
- Need Help/Info About MotorSwap Emissions,Ecu,Etc
- LS/VTEC reversed to install on b18c block?
- s2ooo gauge cluster conversion.....
- Disconnected 02 sensor, major problems?
- A B16 Head on a GSR Block??
- NEED HELP car won't start
- 99 Civic Hatch Rear LCA / Sway bar help....
- Automatic transmission experts please!
- Will a ECU socketed for s100 work on s200?
- Help on TAIL/PLATE light FUSE, need SUGGESTION BIG TIME!
- Rebuilt engine wont start
- tranny question
- fuel and spark but no start
- Weird noise (while moving; not suspension/brake related)
- Help: Motor Turns Off When Hot
- Tranny question
- HELP: car starts at 2500 rpms and keeps rising!!
- cable tranny line?
- Help on 93 Civic EX Coupe motor swap
- IACV hex
- Why won't it pass smog...
- storing a tranny - wet or dry?
- Throttle body question
- All those bored engines.....
- the ups and wons of a B18 or a B20
- got the shakesss??????
- Zero Out at VAFC - Pass Smog
- ARP head studs should I retorque?
- This is really weird, come read this please!
- Jap Import Engine Question/Discussion
- Headgasket question
- Fuel Pump Failure
- help settle a debate: is this safe to drive with?
- Chicago engine builders!
- Header gasket selling locations.........
- new brake rotors??
- pro-shift questions
- strange steering problem
- Shift Kits? Where can i find some - really simple answer
- P34 ECU Help
- Any Conquest Owners? Question about main fuse box.
- nrg quick release
- pr3-3?
- Ignition cut out
- New Car (5th gen prelude) coolant or water?
- Radiator question
- becoming a honda mechanic?
- Replacing Steering Rack
- Quick master cylinder question (well two)
- mini me mystery
- b18c1 swap into 92 civic HB
- does a gsr engine have a knock sensor?
- hellp plees
- gsr motor in 92 civic cx cant get the speedo to work!!!
- anyone have any tips on getting wheel locks offa tire? Wheel lock key is lost thank
- Can I do this??? *Tuning Related*
- Help needed...Please....
- Need Help: Car won't start, everything is normal
- Gen 4 Accord
- NEED HELP: Wont go into gear
- STR issues
- Vacumm and Coolant lines for LS/VTEC
- question, Doing b18b1 swap... Some parts dont seem right? Need Help!
- Sway Bars & Traction Bars?
- GSR block girdle into an LS ?
- High Comp, Big Shot, Daily D, Ultimate All Around Thread!!!!
- which ecu
- Code 73 ( cylinder 3 misfire) possible causes and solution?
- similar symptoms of a blown shock?
- PLEASE HELP ME !!!
- AWD Civic??
- throwing eld code and no fuel past injectors., also no oil pressure
- motor for my hatch
- Z10 plug, quick question
- Rpm Needle Jumping-How do i fix this?
- rattling shock/spring?
- Help me with reverse gear!! Im a noob on trannys
- ..installing a shortshifter into a '95 CX hb
- HELP!
- where to purchas oil pressure sending unit...
- NYC Timing Belt Cost
- Input shaft bearing?
- where can I order an OIL pressure sending unit...
- '91 civic hatch timing belt trouble
- spring seats
- HELP ME PLZ.....
- F20B parts?
- Piston Design....
- Got a problem.
- D16Z6 power?
- Doesn't Start.
- P07 VX ECU pin outs?
- Still too Low Voltage after new altenator and battery, a little help?
- Cooltech Rotors
- Cleaning the catalytic converter?
- Help..Fuel System??
- Lowering spring from a 95 civic coupe into integra 1992??fit??
- 92 ls tranny comp. to a 90 jdm y1 lsd help
- gsr harness in my ls???
- ANYONE USING NIPPON RACING T-BLOCK SLEEVES??
- Mushy pedal / brake problem help please
- GSR ecu w/ a B18C5
- Knock sensor on B16
- Knock Sensor & timing retard
- LS CRANKSHAFT AND RODS ON B16 ENGINE????
- 93 Cable GSR tranny wont fit! 91 LS bolts up fine!?!
- Reading Spark Plugs...need help
- Resonator
- quick question...
- ls crank in gsr block?
- Ground Control Springs
- ls/vtec burning coolant
- d series axles
- Wheres Dan Benson??
- fuel pressure safe?
- STR throttle body on H22
- roll cage
- Recaro Brackets
- 02 sensor
- code 29?? umm
- cam break-in period
- Where to buy cheap B16
- beating a dead horse.. another no start problem, got fuel pump, got spark, no spray
- Required Maint light blinking
- CHECK ENGINE LIGHT IS ON
- greddy evo vs evo 2
- automatic trans history lesson needed
- Any one have pic of F-R traction bar bracket welded to 99-00 Si LCA?
- mixed up valve springs!
- Where does that ground wire go?
- Rear Quarter Rust: How did you fix it?
- Suspension Techniques SpeedTech Sway Bars - Quick Questions
- Differences in B18 Series Blocks?
- All Honda Experts - Diagnose this symptom...
- Disk brakes imperative??
- Ignition Timing
- *sigh* another clutch question...
- Knock sensor in D16Z6 block - anyone done it?
- How to pull check engine codes in an element.
- Cast iron manifold weight (B-series)
- Part numbers for JDM ITR shocks and springs?
- Clutch problem?
- Excedy clutch installed, now have problems
- CASTER!!! WHat do you buy to adjust it??!!???
- Codes 21 and 3 on obdo jdm b16 ecu
- Energy Suspension Bushings In Canada?
- Autometer Nexus Gauges and Control Unit
- carb questions...
- VTEC
- What lines need to be tee'd off? AEBS typhoon install.
- D16 header question
- 195/50/15 comparing to 205/50/15 tire????
- 89 CRX converted to obd1
- D16 oil pump on a ZC?
- Does 88 CRX SI have disc brakes??
- larger valves or no?
- Jdm cluster question *searched(well kinda)*
- Need MAP SENSOR HELP ASAP!
- Will it hurt my engine...?
- MY CAR IS IDLING WAY TOO HIGH
- Aem Fuel rail, rc 550's 95 gsr
- need some diagnostic help. compression test results inside
- rebuilt b16 head, now have low compression in #4 cylinder
- Stuck valve cover
- Which block to drag with?
- install exhaust
- Redline for fully build B20-Vtec Turbo engine????
- bore size on stock si motor(b16a2)
- Need help! My car died on me!
- LSD owners: Is your car easier to drive in bad weather?
- will a 2000 gsr starter fit an 95 ls engine?
- ground wire kit
- has anyone ever dc2 lsd into cable ys1 ?
- H22 Idle Problem
- CAM SEAL QUESTION????
- gapping the rings tight or loose??
- Drag3 Turbo?
- Plz help
- Speed Sensor Rust and buildup on plug terminals!!! Everyone should read this.
- STR throttle bodie adjustment
- re-tourqing head?
- caster affecting camber
- b18 block and b16 pistons
- oil leak problem
- Cusco lsd 1.5way, lsvtec!?
- CKP Code 4 EXPERTS!!!
- Help me clarify this issue please...
- valve springs off center under retainers BAD RUBBING - BIG PICTURES
- cusco oil catch tank
- Del sol no start
- GSR with prelude injectors?
- H22 into a 92 Accord DX
- change these parts??
- damit JIM !! Stripped a Frezze plug on the block???
- vtec dependancies???
- Binding Noise in suspension....
- bad suspension?
- help with my CRX LS tranny and engine
- Power Steering Motor???
- engine building school
- ? for alignment techs
- SKunk2 Manifold vs JG mani--- b16a2
- No start. OBD0-0BD1 turbo b18a in 91 civic std
- what is a better spring rate for daily driving 10/8 or 12/10
- Apex'i N1 height adjustment and preload
- Engine Rebuild for FI
- smog obd0 to 0bd1
- Shocks & Coilover replacement..
- H22 into acura cl
- question about a check engine light on my moms van
- any tips or trick s 4 the linkage pin
- Aftermarket lugs on stock steelies
- wiring the vtec on my p28 ecu
- Transmission Oil, anyone tried Motul 10w40?
- d16 ARP Head Studs, can z6 ones be used for a y8??
- VAFC question(s)
- EG&EK Civic - Brakes - Help / Info Needed
- Timing belt replace
- Possible Tranny Fix$$$? (b16)
- Non V-tech to V-tech
- OBD1&2 issues
- Need help about Bseries halfshafts.
- axle problem.....need input
- I'm electrically stumped. Digital Speedometer?
- H22 TB on D series IM.
- did i really just bend the valves on this car?
- ECU QUESTION?
- uberdata help
- EG8 CV-AXLES IN AN EJ1?
- obd2 to obd1 question???
- tranny making spinning sound
- Wierd noise...axle,ball joint related...???
- CODE 15
- The CORRECT S1/J1 gear ratios
- Bent Valve????
- +45mm or +40mm 15x6.5" On Lowered Civic??
- DID YOU FEEL THE DIFFERENCE
- i need a good place to tune ecu
- Toda 2.0 L piston kit
- head swap for bseries need help
- help on engine swaps
- Autometer Oil Pressure Gauge Help
