View Full Version : Tech / Misc
- need some advice
- to install autometer tach in 96 dx
- What do Vortech or other superchargers like ?
- New Serious help "ENGINE"
- will a gsr distributor fit my b16 sol??
- Mechanical oil-pressure (where to tap besides factory oil-sender)
- Need an engine
- Car Stalls...
- Please help with brake bleeding/pad, rotor, SS line install (G2 integra)
- Weird Sound From Right Rear Section of My CRX.. Help Please!!
- Is the Matrix lower tie bar any good?
- power stering
- clutch
- can someone tell me about injectors ??
- Racing automatics
- S1/J1 tranny same gearing as type r????????
- lsvtec leaks oil?
- obI b18c1 or obII b18c1???
- engine won't stay running
- Really need dust boot for shocks?
- clicking noise.. what is it?
- H&R vs. Eibach
- 50k tune up....
- question about H22
- Please look at my ecu and let me know if this is fixable!!!
- Mugen Front Strut bar
- what pistons for NA B16
- just proves expercince isn't everything!!
- porpor valve
- www.jgenginedynamics.com -- JG - good idea h22a4
- headlight condensation
- Product review wanted: DC TCS
- how do i adjust my camber without camber kits
- How hard is cat back install ...
- Anyone know what The O2 sensor reading should be? Looking to tune with multimeter
- check engine light
- Bet you guys didn't know (Some LSD tranny tech)
- WHY IS THERE OIL LEAKING FROM MY HEAD?
- Clutchmasters Light flywheel makes cool sound?
- How many Horses for these MODS???
- Please help me choose the best cams for my crvtec???
- ARP head bolts or STOCK?
- engine code 13
- Anyone know the offset of 17" Team Loco 142 wheels????
- Thermostat compatibility
- Tough decision... Type-R parts and engine or my built GSR engine...? Help!
- what's the best way to....
- Torque specs for Skunk2 cam gears?
- draining freon
- Can anyone tell me what there TPS readings are off thier AFC?
- Getting TODA Spec C cams
- ??? difference in hydro and cable halfshafts ???
- HELP on ecu code 8
- Best shop in Florida for engine tuning and mods/work on honda
- About Clutch Master Cylinder
- mini-me swap (tech post)
- Valve Springs
- single wet fogger
- JIC-Magic SF-1 quality?
- tire weights - where to find them (or if anyone knows)
- Engine Install on Mitsubishi
- ATTN: All ECU gurus and those with OBDI P72's.
- prelude keeps killing
- LS VTEC W/NOS
- B16a1 parts questions
- Headlights, have low beam no High beam
- Need help w/ITR intake manifold with first gen B16
- electrical problem or alternator
- One F'n problem after the other......part II
- Gasolene Octane Numbers
- Transmission VIN Codes for EF Si Transmission?
- Camber kit: kmac or skunk2?? Screw Ingalls!
- 98 civic cx hatchback
- max size I can bore out a GS-R TB ?
- 96-98 hb w/apexi n1
- Skunk2 Stage 1/2 with Portflow inner/itr outer spring combo
- whats the flow rate of s2000 injectors
- Larger single piston caliper vs Smaller dual piston calipers?
- just got my 15" konig heliums and now i need tires? help!
- for sale
- Anybody have a custom exhaust made from mandrel bends?
- Tach not working??
- Tranny Problems??
- interesting theory I have - anyone with knowledge of head flow & mixture quality, please help
- Need help on integ coilovers for my civic.
- wrist pins??????
- Help with wheel offset question.
- taking head to machine shop, some questions
- argh, car won't start now.
- condenser fan?
- what is code 17?
- Supercharger?
- Leaking radiator?
- Am I screwed?
- Crower Valve springs/retainers for H22a, good or what???
- ls vtecin crx
- Just got my car back from alignment.. -tech questions
- h22a vs 6th gen accord V6 swap
- best lubricant for sway bar
- Z Max.. anyone used this stuff?
- Serious help needed
- NEED HELP! Are OBD 1 and OBD 2 injectors interchangable??????does anyone have obd2 injectors in thei
- 97 Civic rattle from engine when cold...
- K&N Filter Cleaning
- for the JDM guru's
- PRELUDE idle Drop
- will 92-95 civic springs fit 90 integra
- broken stud on the head replaceable?
- Thinner head gaskets?
- CRANK PULLEY BOLT
- Knuckle Help
- Aluminum piping good for intakes?
- piston to head clearance ??????
- I could have sworn someone asked this? Bleeding Brakes
- How good is this stuff?????????
- Are GSR Intake springs stronger than JDM ITR intake springs?
- wiring ls to vtec
- Am I SLOW????
- Removing manual tranny
- AYC for Honda?
- Head Gaskets
- a couple of questions regarding mods to civic
- Starting problem
- heavy 16" wheel vs. ligher 17" wheel?
- CEL #67?
- Complete Turbo Kits?
- 2000 GSR wiring harness question................
- Senior Citizens and manual transmissions..
- possible main relay failure? no ecu code
- which layer of the headgasket do you remove?
- what will happen if my clutch and pressure plate is bad ??
- timing question
- ARC box/Zspeed powerairbox
- The infamous Tornado.....
- Cotter Pin Question
- Hydrolocked H22... rebuild... what?
- fuel pressure.
- putting on the B&M FPR any thing i need to be wary about
- JDM question
- question on installation of sideskirts?
- Help: B20/VTEC problems(long)
- quick question
- Ignition timing with no markings on crank pulley???
- Cam questions???
- Which motor??
- car stalls when cold..... :-( help
- No fuel when warm
- Ls turbo?
- Big puff of black smoke out of tailpipe
- New cam, need change on v-afc ?
- 2nd gen b16 block with 92 ls head?
- itr ecu
- how do you measure piston to deck clearence??
- Well....My Jun 3 cams broke....Pics inside
- HELP! need to know which TRANSMISSION will bolt onto my engine (B16A2)
- PROS NEEDED!!!! striped block thead
- Need help!!!! Quick!!!!
- Please stop the rough idle =(
- Flywheel Vs. Wheel
- I need link for wheels and tires
- Aftermarket fuel pump, not the intank one
- droping a lower year motor.
- Matrix Motorsports - Edmonton Alberta Canada
- Need Explanation on Technical Matter
- just changed my oil...still low?!
- misfire 304
- Which Computers control power windows/locks in 2000 Civic EX??
- Will ITR valve springs and retainers hold 9k?
- Oil in the Intake manifold .,.,.,.,HELP
- paint job in Northern Va?
- engine swap info
- suspension??
- 4 wire o2 sensor
- Oh yeah, Got tax return...1700...tranny going to be rebuilt, need a LSD which one good idea?
- no more days to try cyl.head one by one
- Has anyone else notice the FD in the new Si?
- Has anyone fine-tuned their cam gear settings for N/A H22A?
- HELP: Just put in new motor and....
- Head work
- drag 3 turbo kit?????
- Code 45....
- Can I use 5w-30 Motor oil in Tranny?
- question about size of tire 215/35/17
- 40HP for $1000
- ignition coil????
- runnin with slicks and a cheap clutch?
- B18B has a sensor that the B20B doesn't have. Will my car get Check engine light?
- need advice!!!!!!
- [ Si or Hybrid? }
- Spun bearing? i hear this sound at 4k rpms
- Trumpet-like noise coming from intake manifold?
- Need assistance with OBDI B16A vacuum hose routing in '92 GSR (PICTURE DIAGRAM INSIDE)
- still can't idle, honda stumped, please help!
- Do I need alignment after installing shocks?
- help...another timing question...
- alignment questions
- Fuel Pressure
- complete rebuild on gsr motor what whould you do
- how long for oil to reach optimum temp?
- Tranny for Swap needed.... Opinions welcome
- port and polish?
- Aeromotive Fuel Pressure Regulator
- Will this starter fit on my tranny?
- Y1 Tranny With LSD
- need advice on builbing b18c (rods) HELP!!!!!!!!
- setting the ignition timing
- ECU help
- sohc power
- Replacing cover for passenger side airbag on 94 integ dash
- A real techie questions about Speed limiters??
- what offset do i need for this tire size: 215/45/16
- offset question
- headbolts...
- EGR VALVE??
- chip burner for ecu's
- no more BS how do I reprogram LS OBD2 ECU
- anyone here have apexi world sport exhaust??
- Throwout bearing making noise. Loss in performance?
- if i go turbo will i HAVE to upgrade fuel pump?
- what size tires?
- Ok guys fan still dont work..what now??
- dc header
- Damn, Pulley bolt is too powerful...tricks to removing it?
- Easy way to seperate tranny from block?
- Vibration under acceleration after new axle install
- difference from coil-overs with shocks and a COIL-OVER KIT??
- cam seals
- How do I a cam?
- tire and rim size
- GSR head....
- ECU wiring
- D-series alternator and B20 Crank Pulley...
- help! my trannny. 5th gearslips.
- wiring harnesses and soldering
- B17 Crank with: 85mm B17 or 85mm B20 ?????
- which eagle rods for a b17a?
- my car is failing emissions inspection! help!
- greddy turbo question
- PLEASE READ and tell me if i got the wrong ECU for my car (throwing codes w/ new ECU)
- Honda Dual-Core Radiator?
- urgent: broken oil jet bolt
- Steering Rack, rebuild or no?
- Springs....Is it possible?.............
- JDM Type-R final drive in 90-93 LS tranny
- field's controller(wiring)
- WHAT ARE MY CHANCES?? TIMING BELT PROBLEM...HELP
- What spark plug wire and spark plug combo should I buy for my Si ?
- Smoke issue...
- i found the problem!!! timing belt
- Help
