View Full Version : Tech / Misc
- help plz confuzzed
- Measuring Tool List for my C1 build
- transmission reverse idler gear washer
- Cluster not working
- LS/VTEC Integra CYP Sensor?!?!
- any way to hard wire an obd1 distributor to work on obd0 ecu?
- VTEC subharness wiring
- anyone in germany
- Need a shopping list
- Car takes 3-50 turns of the key to start
- oil pressure question
- Turbo ROBBING oil Pressure.....HELP!!
- *Wooosh* sound when I shut off the car!!
- engine oil questions?
- Rebuilding k20a3... I have a question.
- How can i Make my Hasport Mounts Vibrate LESS?
- Removed Heater core, temp is all over the place ? ? ?
- What else would I need to complete this?
- Check Engine Light
- HELP car won't start
- Acura J32 Engine
- what would no knock sensor do?
- ek9 lsd in b16 box
- Toda Spec C Cams
- A/C question, b series in an eg, need to know what parts will work!!
- My distributor cap melted ! ? ! ... WHY ?
- LS to GSR tranny... wow.. but
- LSVTEC problem: bouncing idle
- axel ?
- need info on shops in sofla
- where to order ss clutch line
- wire tucking
- 0BD1 to 0BD0?
- 2001 civic ZC Swap question about Crank sensor
- Tranny guru wanted... different differential=too much play
- ls swap in an EF HB
- flex hone or 3 stone hone
- b20z2 head torque specs and order ( searched, i promise)
- converting obd2 p75 AT to MT
- please help asap
- did obd2 to obd1 conversion harness on automatic car no 1st gear working
- 94 gsr hatch tach not working
- o2 sensor
- Installing s40-k4 tranny onto d16y8?
- LS rev high
- B18B wont start + white smoke from intake
- P30 piston rings on ls pistons? are they the same?
- clicking/clinking noise from driveline
- thinking about b20vtec
- ys1 with a hydro b16a gear set question
- Nitrous Switch??
- HELP PLEASE!!!--- b18c1 cylinder wall honing limits???
- vtec screams like if motor is about to break is that bad loses power at top end
- Floor jack
- Best Place Online to Get Edelbrock?
- OBD2 Scanner with USB cable who makes one?
- is it a starter problem???? help pleaaasssseeeeeeee!!!!
- Rage header
- Im Gonna Kill My Car!!!! (ignition problem... starts when it wants)
- 01 civic will not start and i am lost
- Using a map sensor in place of an EGR sensor
- Down Pipe Diameter
- ????automatic transmission????
- How can I tell where my YS1 transmission came from?
- 1992 Acura Vigor transmission problem? Please help.. primary car
- electrical problems in and ef
- i need information
- Need help finding a m12x1.0 35-40mm long bolt
- Highest Final drive Ratio?
- Countershaft won't line up?
- Please help me find this post...
- Typical bore required on 250K mile motor?
- New clutch, oil film on backside of flywheel... do I need a main seal?
- End gap issue w/ new ring in fresh overbore
- oem parts... balancing?
- Performance Internals for my k20
- LS wiring harness on B20
- b16 header question
- Compression
- Dist no spark
- Got engine back from machine shop - piston scratched?!
- Finally getting rid of my 97 Civic EX...
- Tuning a VAFC2...
- Hard to get out of Reverse (borken shifter?)
- YS1 gearing vs. S80 ITR gearing
- greddy emange ultimate
- Clicking noise coming from tranny
- Why the b16?
- oxygen sensor problems. CEL 41.
- b16or ls tranny????
- tuning VAFC2
- How do I/can I de-pin harness connectors?
- AFC neo problem
- OBD2b to OBD1 harness
- notching a d16y7 block
- antiJDM's billet AVID engine motor mount review VERY detailed
- obdo b16 to obd1, p28 ecu?
- how many times can you resurface flywheel? any specs?
- Noob Question but can you help me????
- KA24 problems need help
- New exhaust on D16Y8 (EX 99) ?
- Nissan 240SX KA24 engine wont start.
- Exhaust question.
- OBD2b - OBD1 Conversion & Tach doesn't work
- B18C1 Intake Runners
- Clutches and Transmissions
- Trying to find a 5th gear...
- h22-ek core support
- Need help,Clutch
- 1991 Honda Accord LX Idle Surging Only When Cold!
- ls-vtec power steering
- ISSUE HELP!!!!!!!
- What to do? Burning oil!! Smoking bad...HELP
- d16y8 intake mani w/ p28?
- Which OBX LSD?
- Oil pan drain plug stripped... what to do???
- Motor faster when cold?
- Vtec problem...please look.
- timing belt slip
- Need advice, help, and opinions. I'm very pissed off right now!!!!!
- new swap.
- VTEC solenoid
- shopping for a new transmission
- how to make my honda faster for cheaper...
- OBD2B ecu in OBD2A vehicle.
- gauges
- Battery Relocation Wire Gauge
- How do you tell if a honda B-series Transmission is LSD???
- HELP!! 95 CIVIC D15Y7 SOHC motor - engine locked up
- uego
- ANYBODY KNOW IF CRX SI GEARS WILL FIT 95 CIVIC TRANS
- Lower torque mounts, necessary????
- port and polish help
- AEM pencil coil????
- compression test FAQ clear up
- exhaust
- Took head to the machine shop, big problems. Head Milling Questions
- SEARCHED: P06 vs. P75 fuel maps?
- Idle Revs Up, Revs Down
- Replacing H22 rings question
- need help with b16
- Smog car with OS PR3 piston in gsr
- brand new clutch shudder?
- HONDA CIVIC SI THIRD GEAR SUCKS
- HOW DO I GET THIS BOLT OUT!! w/pictures
- want to install a girdle on the b20
- gsr/b16
- HELP!!!
- Vtec/Oil pressure GSR Problem, PLSEASE HELP FOR THE LOVE OF SNOOPY!!!!
- How will a hydro-to-cable converted tranny hold a stage 3 clutch?
- NO POWER TO STARTER
- Aftermarket MAF
- My Car, some Pictures, and Modifications
- HELP What sensor is this?!!
- speedo problem
- A 2000 Si parked for 4 yrs.
- Wastegate install help
- OBD2a vs. OBD2b Distributors -- Any Difference?
- WHAT TO DO - Warped brake rotors after only 17k miles??
- Trying out my new camera phone but need help to...
- Distributor and CEL problem....
- gsar swap mount help!!
- Differential Question - what is the difference between a centre diff (4wd) and a standard diff
- Logic ground reversed. Problem?
- h motors online location
- where is the b20 knock sensor at?
- which throttlebody is this??????
- key in ignition beep when cranking car?? Also no lights at all.
- Probelm with Engine.. really need inputs
- Major downsides of Not running a rubber dampener?
- A/C clutch woes
- Need tips on removing sticky/stuck valve cover.
- Edelbrock vs Skunk 2 pro series
- whats wrong with my ls engine
- Questions about Honda Peak/Hold injectors.
- Will hondata S300 run more then 1 map?
- Early 1988 D16 crank snouts - unorthodox pulley
- warped head?
- Weird noise after Rear DC2 Brake conversion on EG4
- Need some help with my Hybrid trnasmission swapping LS>B16 hydro trannys
- Is there anything wrong with useing used rings??????HELP
- Probe Honda B20B rod bolt tourque
- What do you think about these compression test results??
- just bought a msd setup up for my gsr hatch and need info 2 install the resistor
- Hondata S300 installed in P28 throwing code 23--Knock Sensor
- Hondata in 96 JRSC GSR, P28-obd2b S300, high or low imp. injectors?
- timing light question
- rebuilding hydro b16 tran w/ oem parts question
- ARP rod bolts for a gsr, need help asap!
- power steering removal question
- What is your favorite gpt site?
- i want to know everything about chipping and tuning an ecu...running chome and all.
- A click when braking
- ls crank
- Idle PROBLEM... H E L P !!!
- why does my car makes that auto launch sound when i step on the gas?
- Quick question on a ecu ground for lc1 o2
- is my engine gone?
- B-series oem crank pulleys interchangable
- 92 dx
- Brake issue
- What Retainers are these?
- 1720 vtec conversion
- type R transmission guts into LS case questions
- How makes sensors for AEM
- How Do I Bypass the Heater Core?
- Getting rid of that raspy exhaust noise- Put a Cat on, or put a resonator on?
- 2000 CRV transmission problem
- CHECK ENGINE LIGHT
- 2003-present Accord Transmision Clutch Removal PICS
- Stripped drain plug in Insight
- HOW-TO: Swap B-Series Camshafts - VIDEO
- OEM dizzy with MSD blaster coil?
- ZC cutting out at 3000rpm
- Vtec just stopped working? Please look..
- Building The Ultimate NA transmission
- Alternator belt keeps flying off, what to do?
- Are these p72(GSR) rods or Type R rods?
- Moates Burn 1 , need HEL:P!!!!
- piston to wall clearance
- any videos to help learn how to tune?
- Use cam lube on a used cam/head?
- PureONE or Fram?
- Workin on a new wideband, looking for your opinions!
- Integra Differential Bearing Question
- need to know! tranny question
- tuning w/ an aftermarket cam
- Another weird noise thread (clutch related)
- Question?
- Need help with H22 wiring
- my transmission is slipping out of 2nd?
- radiators
- transmission pin linkage connector
- rebuild kit for 95 gsr
- Twin Trac Lsd?
- 92 civic doesnt start
- GSR bogging after vtec??
- HELP HELP HELP!!
- DIY Throttle Body Cutout -A Cheap Alternative
- B16 Head Repair
- Brands for accessory belts matter?
- Inquiring minds want to know: Did Honda publish incorrect valve clearance info?
- Crank shaft oil seal
- B18 Eagle H beam rods RPM rating
- used hondata s200 on p28 question
- Shifting issues
- ACL and Plastigage?
- ABS Prop Valve?
- heat tollerance
- EFI 101 tunning class, anyone here attend it before?
