rear camber
Old Nov 24, 2003 | 02:25 PM
sleepyEK's Avatar
Default rear camber
i was wondering what size washers will add how many degrees to shim the rear arm: 1 ?.?mm washer=?.? degrees + camber. i know ingalls sells a shim kit with longer bolts for the rear but does anyone know how thick the washers are or are they just generic washers that i can buy at home depot? thank you
Old Nov 24, 2003 | 02:43 PM
sleepyEK's Avatar
Default Re: rear camber (sleepyEK)
eh
Old Nov 24, 2003 | 06:07 PM
static_signal's Avatar
yes there just plan old washer.... I used 4 on each side to get the camber back right .. did an extreme drop 2.5 in rear and 3.0 in front
Old Nov 25, 2003 | 09:27 AM
doublejz's Avatar
Default Re: rear camber (static_signal)
i just used 1/4" sheet metal and cut out 2 square pieces for each side and i dropped about 2.5" and im all good
houa-kage
Honda Civic (2006 - 2015)
Oct 29, 2010 11:21 AM
pinks11
Suspension & Brakes
Dec 7, 2007 06:43 AM
revolt_allmotor
Suspension & Brakes
Nov 6, 2005 09:04 PM
Valvola
Sep 10, 2005 08:45 AM
91_hatch_si
Dec 30, 2002 09:15 PM
