View Full Version : Tech / Misc
- Digital tachometer
- Humming/whining noise !! is it the bearing? what is it?? Help
- Which Dizzy fits what?
- is this a 97 cx harness?
- B series (stock) cam specs....where to find them?
- Measuring D16 Crank For Bearing Clearances. How? What Numbers Mean What?
- HELP!!!Rev probelm
- which sensors can be reused in obd0 to obd1 b16 manifold
- b16 won't start
- Management with Nitrous can I use a Chipped Ecu?
- H23 transmission questions
- crank holder?
- conversion from automatic to manual conversion
- ls/vtec guys....HG question....
- Automatic B16 swap
- HELP!!!!!! I do not know whats going on
- my compression
- autometer 3 bar
- Burping/Bleeding Coolant System
- sleeved/bored b18 b20 question
- will this ITR part work on a LS motor
- Water pump install help
- EF dash wiring harness...
- D15 Head tolerance questions
- hondata
- vtec sohc head... how can you tell?
- H22 Tranny Part Number, HELP
- throttle bracket
- s21 good or bad
- Electromotive B series crank trigger system...
- External Coil Question
- DIY: Obd2a to Obd1 Wiring Diagram
- is my oil pan bashed in ??
- exhaust question...
- any honda transmission pros online?
- Civic Hatchback EK
- skunk2 valve springs..... can you install themm upside down???????
- Power Washed My engine bay now nothing works!!!!
- which o2 sensor to tap for jdm b16
- Need helpful advice regarding spark plugs & drop in mpg
- Clutch speedbleader part number
- civic chips.
- Recently purchased.. wondering about more HP..
- HOW TO: install SRR ignition switch??? (searched already)
- Where to buy Willem chip burner?
- HELP! Car bogs only when at WOT....Not TPS
- Help with Oil pressure gauge install
- type r gears into gsr case ?
- Does any know how to read Codes??? NEED HELP ASAP
- Strange CEL 3; not the typical MAP sensor problem; electrical gurus please look
- BROKEN, What piece is this that snapped on my shipped block?
- Nitrous tuning help?
- Quick Q - b16 water, oil pump, oil pan, and oil pickup works on B18A/B?
- Anyone with a FPR and vacuum manifold mounted on firewall
- Where to buy Ethanol in So.Cal????
- What transmission cases are interchangeable with a 92 gsr trannny?
- VTEC not running as strong as it used to....need help!
- loofa sponge?
- Intake Manifold Porting - Skunk2 D16 Unit
- Tuning
- Any Repair Shop Owners Willing To Help A Scammed Guy?
- ecu swap "p3y" to obd-1
- So if I need a "valve job", what else should I do at the same time?
- custom mandrell bent exhaust
- motor idling weird with p08......
- LS swap or mini-me? which would be better?
- TILTON TWIN-DISC!!! HELP!!!
- electrical failure
- Tranny rebuilders... any thoughts?
- syncros?
- Ls/V-tec setup--what to need??????????
- oil leak ??
- what is this???????????????????????
- carb eo number help!!!
- octane help
- Not a honda question..But Mustang 5.0...(auto to 5spd swap)
- bogging/full throttle problems
- I just install a high flow cat in my obd2 car.
- Odd electrical starting issue...'91 LX 1.5...please help
- New but not. big n20
- Soldering or Butt Connector?
- anyone know where I can find an electric temp switch (not a fan switch, but similar)
- Help needed with TPS and Hondata
- how to use a micrometer?
- why no vtec oil press-switch?
- itr head??
- ls swap problems
- Accord suspension
- ECM problem
- any autobody tech's or painters in here?
- ECU problem
- vtec not engaging
- tread wear rating
- 99 Si alternator
- Where did you get your ecu from??
- Dyno Days
- Which injectors?
- S2000 tranny on b18 ??
- Flowbench Numbers???
- Hondata S200 with a P28 Ecu brand new for sale $650.
- Swapping TPS wires, eliminates 1/8th throttle stutter!
- How can you tell what size Walbro fuel pump?
- D16 OVERSIZE PISTONS
- a/f ratio question
- Help, Weird engine noises with built freshly built motor.
- help w/ ls motor swap
- stupid car is acting up...
- Lower profile tires?
- For all those people gettin payed the big bucks.......
- What size of injectors do i need.....
- replacing drive belt on 03 accord
- Debatable Transmission Question - Please help
- Calling all electrical engineers - help me figure out Op-amps.
- Yet another "smoke out the tailpipe" question...
- Tranny swap?
- Which O2 sensor do I need??
- Vapor/ moisture in hose from catch can to intake manifold?
- Need A Mechanic in The Bronx
- Which timing belt?
- ECM ECU part # for 98 civic EX automatic from Canada (LX for US)
- where is a good site to buy axles?
- LS engine swap questions
- Reverse LS-VTEC / B16 NO-TEC Technical Discussion, B16 Block LS Head
- Can I trust RPM NYC to tune my car???
- picture of cam gears
- Cam Gear Adjustment
- idle/decelerating problem
- R/s ratio question b16a vs b16b
- starter crank noise
- Does anyone know how to kill the Check Engine Light?
- A6 Motor + Y8 IM + B16 TB????
- need help with quaife lsd please.
- Limited Slip Differential for Civic V-tec(ee9) '91
- Hey Everybody! Look at this new shifter! Please everyone look and give opinions!
- Caught with a swapped engine...
- Heated O2 sensor ohms?
- D16z6 vs. D15b7
- Car Problem
- sleeving or what else should i do to my engine?
- were are all of the vaccum line locations on a 2002 civic ex
- Aftermarket steering wheel (srs light) disables passenger airbag too?
- ls vtec stroker rods help!!!!
- valvetrain help!
- How do I wire these injectors??
- b20 info...?
- E-Brake Adjustment
- Who makes a billet MAP sensor block off plate????
- LS/VTEC won't start...maybe dizzy?
- Toda flywheel resurfacing
- Chipped P28 or Chipped 0BD2 ECU with VAFC2 ???
- ecu shipped question????
- flange that similar to crx hf manifold
- Affect of engine on on engine performance??
- smog with a skunk2 im?
- Condensation in Valve Cover???
- My ITR swapped VX is EATING ignitors!
- time for a new engine
- my tranny broke at the track
- Filing rings
- Please help-white smoke-very odd problem......
- V-afc II(again, I know)
- 88-91 CRX Suspension fit onto 92-95 Hatch w/ ITR LCA's?
- What exactly is considered "smog equipment"?
- Weight difference on the OEM underdrive pully?
- USDM tranny on JDM motor
- I NEED HELP BADLY
- Install new cam gears.....have a question though....
- D.O.T. approved drag radials
- Inspecting a cable tranny
- not sure if vtec is working (did a search)
- 93 D16Z6 O2 sensor thread size?
- Distributor Problem?
- Timing Belt problem!!! please help!
- Turbo B18C Setup Question
- Valve Covers
- whats a good intake manifold for my ls b18b1
- Q: Assembling a motor?
- Smog help (ive searched)
- Should I rebuild my transmission
- HELP!!! Burning too rich after header swap d16y7
- damaged valve guides?
- what size throttle body for my setup
- HELP, key wont turn in ignition! car is stranded
- Check Engine Light came on.... Code 7
- fuel pump isnt coming on/wanting to hook up a fuel cell
- Price to get ecu chipped?
- Stewart Warner Guages - Which is more accurate and better? Mechanical or Electric?
- 00 civic si check engine code 3 obd2
- 1.5L help!
- Assembling, Vitara Pistons -> Eagle Rods <help> *PICS*
- Second set of injectors on top of the Stock 4...yes that means 8 total
- Differences between B Series VTEC and NONVTEC oil pans?
- HELP!!! poor gas mileage after my Mickey Mouse job! d16y7
- wheel bearing problem
- h22 oil pump setup
- Honda Injector Question?
- CEL code 43
- Running rich
- B16 woes...really pissed too...please help...i searched
- distributor king dizzy?
- G-Tech Pro accurate?
- idling problem
- HOW TO TAKE OUT VALVES?
- 4-1 VS. 4-2-1
- B17A w/ ITR 6-spd
- safc specifications..
- wont start after accident
- 29c256-12pc / 27c256-10 any good for uberdata???
- Nitrous solenoid question
- Fuel Filter
- charcoal canister and O2 sensor??'s
- my type r set-up in crx
- gear box torque limits
- rsr es oval apexi ws q's
- Looking for Honda HP2 oil in the Netherlands
- I need HELP with 4 wire o2 sensor wiring
- DIY: Red out your tails, or any color...
- crvtec, which head?
- cam seals and dist seal ???
- headers glowing bright ! wtf???
- Grinding noise when shiftin to 3rd gear
- should i buy this h22head?
- Should I buy another Helms Manual?
- water pump question
- Gsr tech help
- please help me identify this part
- d16y7 to d16y8 from 00ex to 97cx i have searched
- engine swap from del sol to crx
- SAFC wont turn on
- ecu swap question
- How to use header wrap?
- LS/Vtec oil tap questions
- which ecu for 92-96 jdm h22 in ek?
- CRX MPFI Problems, Plz help!!!
- B16A2 oil pump gear broken oil pick up found in pan.
- Can someone help me with my vtec controller
- D16y8 tranny and ZC 3rd and 4th will it work??
- nyone else?
- Crank pulley, harmonic dampener question
- 4 puck or 6
- Parada Spec II's road noise???
- Need vacum line diagram for b2 sohc
- Clutch Squeak/Whine
- are all d-series dizzys the same?
- High HP fuel system question
- Want to buy a dyno.
- Help, CRX Si engine stutters.
- Lower Radiator Hose Question
- proper a/f settings???
