Help-- Idle issue
Old Nov 24, 2003 | 03:04 PM
karpieldisco's Avatar
Default Help-- Idle issue
Ok- I know there are lots of posts about idles but I have read them and I am still having some real issues...
Here is what i am having.. 94 accord Lx.. Manual I am not sure of the engine code. ( sorry) .. When I start the car it has a fluction in the idle that revs from about 1, 200 to 3,000 in a smooth pattern and then once the car had warmed up a bit it reverts back to the normal 700. Situation is not complete yet... It runs great till during normal driving until I hit gridlock. Once that happens the engine rpm's to 3000 and idles there till i geting moving at highway speeds agian and then only sometimes will it fall back to normal.. That is the situation and here is what i have tried...
I do have an AEM CAI and had to have my radiator replaced 'cause my other one cracked.. I don't know what kind they put in. It was a rush job since I needed it the same day..
I have replaced the Map sensor, and the IACV ( I believe that is what it is on the back of the throttle body and I took off and cleaned an additional sensor ( forget it's name) on the back of the intake manifold that has 2 12mm bolts and a black cylinder that projects to the right and a plug at the bottom.. When i cleaned this part it initially worked great no idle issues. but i drove into the DC area and in traffic it all came back again.. Please help.. I am not a cheap scape but i really hate giving the dealer 80.00 to plug in a obd and say oh you do not have a CEL so we can't help you.. I want to extinguish all avenues before I take it to the dealer..
Thanks again ..
Old Nov 25, 2003 | 04:18 AM
JimBlake's Avatar
Default Re: Help-- Idle issue (karpieldisco)
Air bubbles in the FITV - that is, if your car has one... It's also alongside your throttle body somehow, & it has coolant hoses.
Cleaning the AICV doesn't always work. Sometimes the valve is just screwed up...
Old Nov 27, 2003 | 09:42 AM
Default Re: Help-- Idle issue (JimBlake)
How much is a new IACV and how do I know it the valve is just messed up?
Old Nov 27, 2003 | 10:07 AM
polymath's Avatar
Disconnect from the harness, and pulse it to the battery - it should click.
Old Nov 27, 2003 | 10:19 AM
SilentWrath's Avatar
Default Re: Help-- Idle issue (Coyote1800cc)
what exactly is meant by pulse it to the battery??
sorry if its a dumb question, but im not sure i understand
Old Nov 27, 2003 | 10:22 AM
polymath's Avatar
Default Re: Help-- Idle issue (SilentWrath)
cut two strips of wire, and touch them to the battery neg and pos. I can't remember off hand which one is negative, so check first in a service manual (i think the terminal closest to the clip is pos).
Thee_Antic
19
Apr 7, 2013 07:00 PM
oly488
Nov 26, 2012 06:58 AM
casper.hughes
Feb 6, 2009 08:39 PM
dinko
Aug 21, 2007 10:39 AM
mafay2
Jul 4, 2005 06:35 PM
