View Full Version : Tech / Misc
- door
- Hole drilled in block B18B1 for future LS/VTEC swap, can the hole be fixed?
- Civic VX electrical issue
- Old Honda HRX Commercial
- Oil loss mystery...
- Some H and F questions......
- BVTEC valve springs colors...
- Miss/Bog/Hesitation during VTEC crossover
- CR-VTEC running lean & stalls, I really need help
- HELP...ROD BEARINGS PLZZZ HELP ASAP
- Pressure Sensor Placement?
- mph gage not working
- will p75 run a d16 for a bit
- Oil in intake, clogged PCV?
- raising rev limit b16 using greddy ulimate
- Coolant line rerouting ok for daily driving?
- Intermediate Shaft Bearing Replacement
- b16a2 hesitates when vtec hits.......
- Code 7 tps.
- Can I use a honda intank fuel pump as an inline fuel pump?
- How can I shorten a honda steering rack?
- RS Machine Pistons w/rings..
- oil pan problems searching not helping
- ECU Wiring Help
- b18c hard to start?
- Need confirmation on info z6 block y8 head
- help my car wont start, fuel or spark
- TWO QUICK QUESTIONS
- eg discs + ef hubs?
- injector problems help!!
- o2 sensor problem...
- b18b head tq sequence and tq specs
- WTF Clutch Slave Cylinder??????
- Car shaking when driving
- civic no start ???? timings on, got spark, got fuel...
- cleaning valves
- H22a vtec wont engage
- b series parts
- cluster problems
- s2000 ap2 coolant gauge k-lin converter
- ZC SOHC VTEC HEAD N P28ECU HELP!
- b20 vtec question...helppp
- ECU n Dizzy questions
- 95 civic ex, problem with radiator fan!
- auto to manual wiring problem
- My stick is not stiff enough.
- State referee ticket question (SO-CA)?
- b18b1 into my Ek
- what t bracket is this
- Stuck Oil Rings vs Worn Oil Rings
- ls vtec timing.gsr cams,head milled/.5 p30 pistons
- 2 wire IACV?
- over heating issue
- 95 civic engine swap complications
- obd1 ecu, obd2 dizzy...problem?
- Drill holes in window?
- Polycarbonate window
- Sleeve Question
- Best machine shop in NW
- Wont Shift !!!! please help
- Civic AC Issue
- boost?
- Engine swap CEL help
- 92 accord stall problem
- can you boost a built c5
- Who has the most miles
- Mystery B16 Harness Plug *PICS*
- cel 3 Map code from h3ll? HELP!
- What key will remove these centercap locks?
- skunk2 stage 2 cams
- My experience with Innovative Mounts
- If you ever built a B16 bottom end using ACL B18A/B bearings please chine in
- B15 Turbo Bottom End Question with ARP and ACL
- Lsvtec first startup issues lil help pleeezzze
- torque settings for b20a cam caps
- Prelude Calipers on EG with gsr suspension
- clutch pedel really soft?
- Genuine/fake Mugen B-series rocker cover??
- INSTALLING kill switch tips on a 98 ek hatch dx
- Taillights not working. Fuse questions 99 ej8
- How to install Hondata IM gasket on b16a
- Chicago PPL and emission testing areas..
- proplem removing cruise control from 98 civic b16a
- troubleshooting vtec
- ect wire in dash
- b16 cel
- Fine vs course stranded wire
- Piston to deck height question with ctr pistons in b16a2
- Bee R Rev limiter installation
- question about JE Pistons website and B Series Calculator
- Stripped MAP Sensor Screw How to Remove?
- 3/8" or 1/2" Torque Wrench
- which a/c and ps parts to use
- drop engineering motor mounts
- tranny seal
- painting valve cover.
- Engine Braking
- warm start problem w/ sputtering/stalling
- Twisted or warped crank what would cause this
- help me please
- ls vtec turbo problems
- windshield wipers work randomly
- AT to MT swap ECU question
- j1 trans and clutch
- Replacing Fuel Injectors
- HKS B-Series Products?
- what dose heat soak of the ignitor or coil mean?
- b18 ls obd1 wire harness help
- Brake Pedal Sinks
- msd rpm pill problem
- Rebuilding Power Steering Rack?
- Maybe someone here knows....
- another car wont start question after swapping dizzy
- B18B Dowel size
- F'ed up my timing
- Wiring diagrams?
- Which Supertech valve springs (h100dr or h1002d) to use with CTR cams?
- LS tranny won't go into gear but will when off
- running last night, wont start today?
- DID IT MYSELF pnp LS head.
- Custom Wiring/ Data Acquisition Services
- mini me AGAIN
- Check Engine light issue P28 ecu
- 93 DX Hatch, Tucked,H22a NO FUEL, NEED HELP PLZ.
- ecu help
- need help with jdm d15b! sucking lot of air
- Gator axles????
- RS MACHINE PISTONS
- starting problem
- vtec solenoid help
- i need help for a connection
- Water in EGR port
- Pipe for exhaust sizeing problems. HELP PLEASE!
- My Honda Statistics Study
- Secondary O2 sensor in an EG6?
- Anybody else having trouble idling with A Blox Throttle Body?
- need help with my new b20v swap
- need some help guys crank sensor???
- 00 si with 00 gsr problems
- rebuilt ls motor
- AVID RACING MOTOR MOUNTS
- JRSC B18c FPR Boost/Vacuum
- Noise When I Shift
- Rear Disc Conversion Help?????
- Push Fan on A/C Condenser Question - I've searched
- cylinder compression ? Car stalling out/ won't idle
- Running at 84ºC 184ºF ECT is bad for engine?
- s2k cluster in dc HELP
- 90 Honda Accord engine swap
- Engine only revs to 3000rpm
- How to remove the whole entire crankshaft on a b16a2 ?
- Where can I buy a single p30 piston new?
- obd2 injectors on obd1 harness
- EG Hatch B18c1 Running Hot
- CRX /w Walbro intank, Bosch 044 Inline PROBLEMS! HELP!
- H22 problems
- Anyone ever dealt with MIKETURBOINC?
- 2000 civic lsvtec chipped p05 issues
- Honda USA Tire Buyer
- any one know how to wire a toggle switch to a radiator fan?
- B16 no spark
- ATL, i need some help finding a good shop!!
- injector clips into injectors
- is the nrg quick release kit the whole thing or do i still need a short hub?
- Misfire problem help!
- LS into ek running on two cylinders help!!
- Colder Spark Plugs
- MSD Ignition Install
- Automatic Tranny
- Need quick answer gotta buy a radiator today
- Problems with ignition need help!!!! h23a dohc vtec motor
- EGR Fails continuity test!
- 1996 EX 4DR rear disc swap?
- will an obd2a harness fit on obd2b engine?
- Civic/Integra changeable parts - Exhaust
- engine block/head/transmission degreasing tips ?
- b18a into EK
- Need Help (knock sensor questions)
- tranny problem richmond spool
- my first big build ::lookin for advice::
- Power Steering Bubbles
- 2003 Honda Accord Door Lock Actuator Replacement
- alt. differences: b18a <-> D15b2
- dumping to much fuel on a gsr do i need a tune?
- H22 ACCORD TURBO ACTING UP!! HELP!!
- Honda Pilot Fuel Gauge stuck under oil gauge
- Way too much fuel, wont start
- Bent Valve Ok just to replace one valve?
- Can somebody please help me?
- Driver Side Door Woes
- Check Engine Light P0131
- Clutch Help?
- timing problems.. missing.. need help
- Removing orings from GE Block
- b18c advice/help/ going 220+
- Windshield Heater problem
- fittings 4 f.p. gauge?
- OBD2 Conversion
- My distributor gear cracked!!!!
- gsr help
- f22b swap problem plz hel!!!!
- which bearings to use?l
- 00 Si splash guards
- MSD Coil/6al HELP!
- 88-91 honda civic wagon fanatics ( look here )
- need help indentifying flywheel
- need help with rpm gauge on civic ex
- indentify these cams. SEARCHED!!
- 99 Ford Escort Rally
- Please help! PS on swap car?!?!
- was this B16a head ported and polished?
- cel code 14?
- GS-R intake manifold question!!
- what do you think this is worth?
- How much is too much? Head milling: B18C1
- Knock sensor INFO/Help
- Glowshift Gauges
- need help finding arp rod bolt
- Laskey Built With Stock Specs to Pass Smog?
- HELP! FUSE PROBLEM!
- Phormula KS-Pro on Honda
- b20/vtec question
- 95 civic no power to fuel pump
- HELP!!!car dies/fuse pop when vtec enage
- obd2-obd1 00si missing a/c signal
- Transmission seals installation tool
- Map Sensor
- 96 civic harness for race car need info..please......
- ls/vtec help pleas
- distributer question
- driver door
- K Series into a EM
- b18b rod caps
- F22A?
- D16y5 ecu help plzzzzzz
- Nitrous + S300 = No workie?
- Extremely low warm idle - Yes i've searched.
- tial 44mm flange size?
- b18b1 into 92 integra
- d16z6 blew need answers about mini me
- what will cause main bearings to spin
- Using a jack stand at its minimum height?
- plenty of spark , still no fire
- What catalytic converter???
- LS/Vtec build question
- Distributor conversions
- New member here with a question
- info about act flywheel
- What is the best distributor?
- B18C Block Salvageable?
