View Full Version : Tech / Misc
- will it fit?
- cutting the valve cover
- Show me your oil pressure gauge!!!
- battery reolcation/ HOW-TO hooking MSD?
- slicks, what will break
- IAC problem on my b16a1 in my CRX Si... Please Help
- valve adjustment specs for gsr with itr cams?
- Distributors
- Fuel pump
- rod and main bearings?
- Belt tensioner....any of you use it ?
- flooded spark plugs
- Desktop Dyno that has B16A
- Clutch or tranny mount????
- b18c or c5
- B18C?: Dished (stock-R) Valves on the Intake side/Flat 28.5 valves on the exhaust side... ideas?
- Cant we all just get along???
- block girdles
- tech question on lashing cams with adjusted settings
- Where is the O2 sensor?
- valve lash specs! on spoon cams
- odd q.....
- Tech Question for the guys with ITBs
- The Shop called Pit Crew in San Gabriel CA
- HELP..my car won't start
- B18B headwork
- Im doin my clutch this weekend
- Fuel Pressure Question!!!
- Oil Filters....
- Need SERIOUS brake help for a 88 CRX.....Pleeeeeeeease help...
- b18c w/ jrsc (6 psi) and type R cams
- Greddy guage question???
- Weight of vehicle and wheel sizes
- timing question...anything bad possible here?
- compression after rebuild?
- EMERGENCY HELP!! radiator fluid everywhere!!!
- VTEC Solenoid - where to get at a real world price?
- MSD or hondata rev limiter ?
- Using Easy-Outs
- Radiator fan doesn't turn OFF?!
- ES Motor Mount Zip Ties -- what else will work if the oe ties break?
- Aligning Crankshaft before putting head on??
- EAST COST help - H22 into 89 CRX Si
- B18C knock sensor? Where is it?
- RSX S 5300-5400 RPM surge
- Bay area...DSR good place for dyno tuning?
- How do you correctly clean a Throttle Body
- speed bleeder for civic rear drums
- ls/vtec question
- B16 with B18C5 LSD?
- Exhaust leak?
- Seats? and else
- Removing the B16A intake manifold ?
- feild vtec controller question: Fuel Delivery Maximized???
- Car Problems!!
- Missing cam cap bolts.......(pics included)
- So what clutch do you have(ACT, Exedy, etc.), I need advice need new one soon....please help me out.
- Anyone have the part number for standard size CTR pistons
- Theoretical 0 lb flywheel
- gsr pistons in an ls ??
- Need help quickly Question Concering Suspension
- 6.3L equals....how many cubic inches?
- sqeaky noise
- quick question easy answer im sure. just im unaware :)
- How do I tell what transmission I have?
- Voltage
- Civic front sway bar upgrade; QUICK ANSWER NEEDED
- head differences
- A/C conversion R134A kit question
- Tech support over AOlLInstant Messenger
- Car won't shut off?
- Please help CRX guru's
- Now it's a CEL code 5! help!
- Need technical advice for my '97 Accord EX 5-spd
- Flywheel help ...
- new engine question--forged internals
- what the difference between GSR, LS , prelude injector
- who has LS rods in a d-series
- O2 sensor
- ACT clutch
- D16Y8 Won't start!!!!
- Lower Ball Joint Grease
- Drift animation!
- Help with Cam Tuning After Adding Exhaust
- Dynos of diffrent parts
- Dyno Questions..
- 95 Civic coupe with turbocharged GSR...need help!
- fuel pressure on itr rail and stock itr reg..with itr inectors
- Water Pump??
- Cam gears ???
- how did the distributor mess up?
- I'm gonna kill my car.......*help please*
- Converting OBDII distributor to OBDI??
- Resetting the ECU
- What pcv for B20Vtec catch can???
- Alignment??
- YS1 transmission oil lines? Help!
- Jim McFarland on detonation....
- check light coming on at WOT
- adjusting timing problems
- electrical guru's
- knock sensor ,secondary butterfly?????
- Any body know?
- Stake your axle nuts Y/N?
- Has anyone actually used GSR cams in a stock 1st gen b16?
- Louder after a TIMING BELT?!?!?!?!
- Carsoud Cat 94006 for OBDI question....
- what in the hell!!!
- Can the Vx wire harness affect the ecu of a gsr?
- throttle body sizes
- code 3 on CEL (b16a2 motor)
- Is this vtec head repairable?? I might buy it but not sure...
- what to do with these codes?
- Plug gap & Crane ignition... Big gap or little gap?
- need help with smog
- Greddy Turbo *Blue Box* Need wiring
- basic tuning help/advice?
- Does cam overlap affect a/f ratio?
- Ignition Coil testing?
- Schoks worn out like crazy!
- Valve adjustment and power
- suspensions for s2000
- vtec controller
- engine managment light
- Manual or auto engine
- help with hondata
- Engine revs when I pump the brake?
- here is you pro-techers i hard problem
- 90-91 Si Final drive in a 2000 DX tranny??
- Flowmaster 60 series muffler for imports????
- headwork
- tps voltage
- Which distributors are the same?
- CEL Code 6 & 7
- knock sensor engine code what to do???????
- Clustor instrument lights and taillights not functioning properly...
- Just curious - How does the ECU decied to go into closed loop?
- Nachi throwout bearing, B or D series??
- coil overs HELP
- VTEC rod bearings on my non-VTEC d16a6
- using a purge canister from a 95 gsr
- CEL 54??
- B and D series tranny's, can they be mixed?....
- where to buy a valve spring compressor for a b-series motor?
- anyone ever solved honda's infamous idle problem??
- valve springs removal
- GSR Obd1 ecu + B20VTEC?
- '99 Civic Si-turbo... blow by (smoke) problem
- One leaky valve....
- Problem; help... 95' EX
- tire question: will 205/45/16 tires fit a 98 gsr thats been lowered 1in
- WHERE on the crank pulley is the harmonic balancer?
- Help with Haltech.. Need experienced tuner's advice.
- Moroso breather can on a B20???
- buying a motor
- runnin with out a MAP sensor
- Need help with b&m FPR, Having trouble starting the car
- Tech HELP!!
- "out of car" comprsn test...?
- vx to gsr O2 sensor`
- Engine Ques?
- CLutchmaster flywheel surface plate
- what brakes to buy??
- how do you read honda ecu codes???
- are skunk2 cams for an h22a engine any good?
- carbon fiber hood
- not changing the washer on the oil drain bolt?
- help on b16a or b20 vtec
- are skunk 2 coilovers good, for a del sol
- looking for a fast street setup (pistons, rods,etc)
- red coolant ?
- Discard Rotor Thickness?
- half shaft/intermediate shaft
- idle control system low
- exhaust question
- bottom part of ITR rear seat wont fit?!
- anybody with a y8 replace their knock sensor?
- prelude TB
- OBD: How to Identify I vs II ?
- Is this true or something that will create problems...
- ACT 6 puck questions
- exhaust diameter?
- '00 GSR - Stalls Idling after Valve Adjustment.
- my spark plugs
- are you retarded
- ? ? ? Sway bar considerations ? ? ?
- Tricks to seat chrome rings?
- Done installing new engine, problems (pics)
- B16 Shift Linkage Problem
- oil coming out of my exhaust
- vafc and 440 dsm injectors???
- My car overheats at idle..why??
- Cam question
- kinda a dumb question bout burnouts...
- How to change idle on a 96 dx motor???
- B20Z internals?
- disabled vss
- What spark plugs for high compression b20vtec???
- Why valve guid seals go bad
- Damn! I separated my mid joint on my drivers side transaxle--HELP!!
- NGK Plug differences
- blowing white smoke.....what could it mean
- odometer stop working
- Ls teg, questions for those with turbo
- Best Decision?
- 1995 Integra need help with turn signals they (dont work)
- thought i blew my motor but.....
- Interior plastic SCRATCH removal?
- engine mounts????
- temporary noise after clutch/flywheel install
- CEL code 13 Help
- kioll switch install
- Handle to dipstick broke!
- New parts
- My car did not pass smog
- Tuning my VAFC, Whats the best RPM to set the Vtec at? Is 4600 Safe/Reliable?
- brake light comes on when I accelerate???
- what's the most afforable and durable camber kit for EK9?
- Super AVC-R
- DOHC 1.6l starter issue into 91 crx si!!!!!!!! Please read!!!!!!!
- B18b interchangeablity?
- how long can you crank w/o oil pressure?
- B18c1 block with B16a1 head: WTE?
- What ECU to run for the B20???
- Loss of brake pedal pressure, no fluid leakage!
- what too do u guys use
- Radiator rattle
- VSS , where?
- LSD: How does it work or where to find info
- Death by water - what to do now?
- B20/vtec questions
- Knowing when your motor has had enough.....
- question about grond control koni adapter
- HELP! Idle Surging ('93 EG)
- b16a Y1 tranny syncros
- what could cause this engine rattle under narrow throttle only?
- help i need to know hw to put on an ac belt for a 93 ex
- Chassis Codes
- Wiil it fit??
- Whats a good temp to get on a EGT/Pyrometer
- 10 000 rpm
- Need suspension specialists - SPI or Bullish Racing good in NJ?
- When i'm ideling....
- Rear disc brakes grinding?
- Who would have ever thought the insides were so small? (question inside as well)
- Compression gains
- Temp gauge drops after warming up
- backfiring??
- h&r spring installation question
- Milled H22A head question
